Oldbaldguy Posted June 22, 2024 Posted June 22, 2024 (edited) This project makes so much sense that you have to wonder why they didn’t give it a try back in the day. Edited June 22, 2024 by Oldbaldguy I think, therefor I yam.
wingman777 Posted June 22, 2024 Author Posted June 22, 2024 Sepp, Alain Gadbois, Martinnfb and 1 other 4
wingman777 Posted June 22, 2024 Author Posted June 22, 2024 Sepp, patricksparks, Martinnfb and 2 others 5
wingman777 Posted June 22, 2024 Author Posted June 22, 2024 Sanding, did I mention there would be sanding? Lots of C/A, accelerator, Milliput and sanding. Shoggz and Martinnfb 2
wingman777 Posted June 22, 2024 Author Posted June 22, 2024 Ya gotta stay flexible and be creative. The two sheets of styrene I had were either too thick or too thin, so I grabbed this old For Sale sign and it was just right. I've also decided to change out the four .50 caliber Brownings for 20 mm Hispano cannons. The Westland Whirlwind was the first twin engine, single seat fighter for the Brits and I'm seeing similarities between it and what this aircraft could've, should've, would've been like. DugyB and Martinnfb 2
Alain Gadbois Posted June 22, 2024 Posted June 22, 2024 With the new engines and lowered kit nacelles to fit, this Lightning is going to look very sleek! wingman777 and Martinnfb 1 1
wingman777 Posted June 22, 2024 Author Posted June 22, 2024 Landrotten Highlander, Martinnfb, Phantom2 and 1 other 4
wingman777 Posted June 22, 2024 Author Posted June 22, 2024 Got both Merlins seated and "Frenched In". I've sanded the entire kit with the hundreds of oversized blisters (rivets) and just blending the mismatch panels. It should start to progress fairly quick from here. The protrusion from the nose is one of the fishing, pyramid weights sticking out. Martinnfb and Oldbaldguy 2
wingman777 Posted June 22, 2024 Author Posted June 22, 2024 Martinnfb, Alain Gadbois, Sepp and 2 others 5
BradG Posted June 23, 2024 Posted June 23, 2024 Great work so far mate, it really looking different. Martinnfb 1
Oldbaldguy Posted June 23, 2024 Posted June 23, 2024 Shame you don’t have two sets of props. Give it counter rotating propellers a la griffon powered spits. Martinnfb 1
DugyB Posted June 23, 2024 Posted June 23, 2024 Hope you jigged those nacelles, otherwise this critter will be wanting to porpoise up and down, and all over the sky…. Martinnfb 1
wingman777 Posted June 23, 2024 Author Posted June 23, 2024 No jig, I'm using the TLAR method of alignment and measurement. TLAR is universal for "That Looks About Right". As mentioned earlier, this is not going to be one of those award-winning, spectacular builds that many of you seasoned builders have impressed us with. I'm just producing a down and dirty prototype to give us all an idea of what it would likely have looked like if the Brits would've received the P-38 / Lightning Mk I and given it the same treatment as it did the P-51A or Mustang Mk I. The next images will show the progress of cutting down the lower turtle deck of the fuselage pod so that it will receive the P-51D bubbletop canopy. This will improve visibility and allow for an easier way for the pilot to enter and exit the aircraft. Also, I'm going to switch the prop pitch on one of the engines so that they will be counter-rotating. Martinnfb, Shoggz, artoor_k and 1 other 4
wingman777 Posted June 23, 2024 Author Posted June 23, 2024 patricksparks, Martinnfb, Shoggz and 4 others 7
