Furie Posted April 12, 2023 Share Posted April 12, 2023 Thanks a lot for the explanation duke_ , as it's a product I'd heard of before but never used before. When you say that it will be sanded before the riveting phase, I imagine that you will make it smooth before painting? Or are you sanding it until it disappears completely? I noticed that it makes the micro-scratches of the plastic disappear and indeed the surface condition of your model before painting should become perfect with this 1500 surfacer. And congratulations again for your Fw190, it will be absolutely superb. duke_ and Derek B 2 Link to comment Share on other sites More sharing options...
MikeMaben Posted April 13, 2023 Share Posted April 13, 2023 11 hours ago, Furie said: ...Does the surfacer 1500 bring other advantages than a primer like MRP for example? Nope, they're practically the same thing. Both lacquer based , the 1500 has very fine pigments just like MRPs fine primers, both fill extremely fine surface imperfections and leave a fine sufrace for other paints adhesion, acrylicsor enamels. duke_, Derek B and Furie 2 1 Link to comment Share on other sites More sharing options...
duke_ Posted April 13, 2023 Author Share Posted April 13, 2023 15 hours ago, Furie said: Thanks a lot for the explanation duke_ , as it's a product I'd heard of before but never used before. When you say that it will be sanded before the riveting phase, I imagine that you will make it smooth before painting? Or are you sanding it until it disappears completely? I noticed that it makes the micro-scratches of the plastic disappear and indeed the surface condition of your model before painting should become perfect with this 1500 surfacer. And congratulations again for your Fw190, it will be absolutely superb. Hey Furie, i said ''during'' riveting not before but thats ok . To make it simple and so you don't get confused surfacer has nothing to do with riveting. Ii just decided to rivet the model after applying the surfacer, so it makes sense that the primer will go away with this whole process thats all.. Furie and Derek B 2 Link to comment Share on other sites More sharing options...
duke_ Posted April 13, 2023 Author Share Posted April 13, 2023 and speaking of riveting there is some progress Memphis, MikeMaben, Gazzas and 10 others 13 Link to comment Share on other sites More sharing options...
Derek B Posted April 13, 2023 Share Posted April 13, 2023 (edited) Kalimera Spyros! Very impressive work. I can see that you are pushing your own (already considerable) modelling skills even further- good luck my friend. Derek Edited April 13, 2023 by Derek B Sasha As and duke_ 2 Link to comment Share on other sites More sharing options...
duke_ Posted April 13, 2023 Author Share Posted April 13, 2023 7 minutes ago, Derek B said: Kalimera Spyros! Very impressive work. I can see that you are pushing your own (already considerable) modelling skills even further- good luck my friend. Derek Kalimera Derek! thank you for your comment! Yes, i thought it was about time to try this. Is not the easiest model to rivet because there are so many rivet lines on Fw190, but now i have to go all the way,. i am planning to. finish this task today. it's not perfect , but its ok . I just wanted to have a comparison between recessed rivets and positive rivet wet transfers Cheers! Derek B and Hoss FL 2 Link to comment Share on other sites More sharing options...
Sasha As Posted April 13, 2023 Share Posted April 13, 2023 Great job!!! duke_ 1 Link to comment Share on other sites More sharing options...
Hoss FL Posted April 13, 2023 Share Posted April 13, 2023 7 hours ago, duke_ said: Kalimera Derek! thank you for your comment! Yes, i thought it was about time to try this. Is not the easiest model to rivet because there are so many rivet lines on Fw190, but now i have to go all the way,. i am planning to. finish this task today. it's not perfect , but its ok . I just wanted to have a comparison between recessed rivets and positive rivet wet transfers Cheers! I’m looking forward to your assessment between the two techniques. Your project looks great so far. duke_ and Derek B 2 Link to comment Share on other sites More sharing options...
duke_ Posted April 14, 2023 Author Share Posted April 14, 2023 20 hours ago, Sasha As said: Great job!!! thank you Sasha! Link to comment Share on other sites More sharing options...
duke_ Posted April 14, 2023 Author Share Posted April 14, 2023 16 hours ago, Hoss FL said: I’m looking forward to your assessment between the two techniques. Your project looks great so far. Thank you Jim! of course! I'm also looking forward to seeing what it will look like in the end... S. Link to comment Share on other sites More sharing options...
duke_ Posted April 14, 2023 Author Share Posted April 14, 2023 οκ, I thought it would last forever, but I think I'm done.. I have gone over the entire surface with a black marker and then removed it with a cloth soaked in isopropyl alcohol to check the riveting depth and uniformity.. I could have done better, but since it's my firs attempt , i am satisfied with the result chrish, LSP_Kevin, Gazzas and 13 others 16 Link to comment Share on other sites More sharing options...
Furie Posted April 14, 2023 Share Posted April 14, 2023 It's simply superb, bravo to you. I have to have half as many rivets to put on my 109 and I find it complicated already, so my hat is off to you. Well done! duke_ 1 Link to comment Share on other sites More sharing options...
duke_ Posted April 14, 2023 Author Share Posted April 14, 2023 (edited) 28 minutes ago, Furie said: It's simply superb, bravo to you. I have to have half as many rivets to put on my 109 and I find it complicated already, so my hat is off to you. Well done! thanks Furie! don't worry only the first 10000 rivets are the hardest part , then you get used to it.. really , now after this task , to me, riveting an 109 looks like a walk in the park.. don't think about it , just go for it, even if you make mistakes thats ok .. you 'll do it just fine! Edited April 14, 2023 by duke_ Furie and Derek B 1 1 Link to comment Share on other sites More sharing options...
Jaro Posted April 15, 2023 Share Posted April 15, 2023 Great job on the rivetting. I do appreciate your patience and attention to detail & precision. I'm pretty sure this is gona be a great model. Keep going Link to comment Share on other sites More sharing options...
Gazzas Posted April 15, 2023 Share Posted April 15, 2023 Excellent riveting! Link to comment Share on other sites More sharing options...
