Ayovan Posted April 9, 2022 Author Posted April 9, 2022 Got the cowling glued up today. I think I'll start getting the landing gear together and painted next. LSP_Kevin, daveculp, Greif8 and 1 other 4
Ayovan Posted April 10, 2022 Author Posted April 10, 2022 After getting my own cowling glued up and into place, and reading Bill's (Citadelgrad) build log, I now understand what he meant about moving the engine mount on the model. There must be at least a 1mm step from the cowl to the fuselage that shouldn't be there. Doh! I'm going to follow Bill's lead, and cut the mounting surface off of the model, and move it south to get the cowling and fuselage to line up correctly. (I knew this was going WAY too smooth, lol). coogrfan, daveculp, mc65 and 5 others 6 2
Juggernut Posted April 10, 2022 Posted April 10, 2022 (edited) Don't forget to add the saw width styrene plug or your engine will set back too far which may or may not present issues. Edited April 10, 2022 by Juggernut added a qualifier to my statement. mc65 1
Ayovan Posted April 10, 2022 Author Posted April 10, 2022 (edited) 1 hour ago, Juggernut said: Don't forget to add the saw width styrene plug or your engine will set back too far which may or may not present issues. The way the engine, cowling, and cowl flaps go together, they make an entire subassembly with the cowl flaps part attaching to, or becoming the firewall. the width of the saw blade made no difference in how far the engine set back. You made me check though. Thanks, I hate do overs. It was a much easier fix than what it looked and sounded like. (at least to me) I cut the stub/mount off and moved it 1mm down and reattached it with some CA. Easy peasy. Edited April 10, 2022 by Ayovan Landrotten Highlander, mc65, daveculp and 7 others 9 1
Citadelgrad Posted April 10, 2022 Posted April 10, 2022 Yeah, me, too. I was really worried, but it was a simple cut and glue and it was over. Great work so far! Ayovan 1
Ayovan Posted April 10, 2022 Author Posted April 10, 2022 (edited) R 2 hours ago, Citadelgrad said: Yeah, me, too. I was really worried, but it was a simple cut and glue and it was over. Great work so far! Reading over your build log Bill, has helped me a couple times now. Your model is turning out fantastic. I can only hope one day I can obtain something even remotely close to quality of your build. Edited April 11, 2022 by Ayovan Greif8 1
Citadelgrad Posted April 11, 2022 Posted April 11, 2022 5 hours ago, Ayovan said: R Reading over your build log Bill, has helped me a couple times now. Your model is turning out fantastic. I can only hope one day I can obtain something even remotely close to quality of your build. Wow, thank you for the kind words. Much appreciated. Ayovan and Greif8 2
Greif8 Posted April 11, 2022 Posted April 11, 2022 Great looking work so far man, and good fix on the engine mounting issue. I plan to build this kit sometime in the future so I am taking notes. Ernest Citadelgrad and Ayovan 1 1
Ayovan Posted April 11, 2022 Author Posted April 11, 2022 5 hours ago, Greif8 said: Great looking work so far man, and good fix on the engine mounting issue. I plan to build this kit sometime in the future so I am taking notes. Ernest Thanks Ernest. The information available on this forum has been invaluable, as far as helping me build a little better model with each new build. Lots of very talented folks here, willing to share their knowledge. Citadelgrad and Greif8 2
Greif8 Posted April 11, 2022 Posted April 11, 2022 2 hours ago, Ayovan said: Thanks Ernest. The information available on this forum has been invaluable, as far as helping me build a little better model with each new build. Lots of very talented folks here, willing to share their knowledge. Very true my friend. I have certainly learned a lot and had some great fellowship along the way! Ernest Ayovan and Citadelgrad 2
Ayovan Posted April 11, 2022 Author Posted April 11, 2022 2 hours ago, MARU5137 said: Ayovan, Very nice work progress. Thanks Maru. Very much appreciated.
Ayovan Posted April 12, 2022 Author Posted April 12, 2022 On 4/8/2022 at 8:31 PM, Citadelgrad said: Oh, yeah, yours looks fine. Mine protrudes a lot more. Ill have to see what i can do. ps, this reminds me of my least favorite part of this build—the cowl seams run right through the large cowling latches, those were a bear to get rid of. Save some time and make some out of scrap pe or fine styrene sheet. I did it the hard way… Bill, I tried to do the cowling latches the way you suggested. PE didn't conform to well to the compound radius, so after several attempts I gave up on that. The styrene seem to work well with just a tiny drop of CA. I think with a little sanding to take the edges down some it will look ok. Greif8, LSP_Kevin, MikeMaben and 2 others 5
Citadelgrad Posted April 12, 2022 Posted April 12, 2022 1 hour ago, Ayovan said: Bill, I tried to do the cowling latches the way you suggested. PE didn't conform to well to the compound radius, so after several attempts I gave up on that. The styrene seem to work well with just a tiny drop of CA. I think with a little sanding to take the edges down some it will look ok. That looks excellent! What a shortcut to the 6-10 fill sank CRACK fill sand cycle I was in. It really looks good. Ayovan 1
Greif8 Posted April 12, 2022 Posted April 12, 2022 Good looking scratch building on the cowling latches man! Ernest Ayovan 1
Ayovan Posted April 13, 2022 Author Posted April 13, 2022 (edited) I got a little progress today. Glued the engine, and cowling to the fuselage, got some color on the cowling, and prop, and assembled the flaps (not installed, just test fitted). The wife went with her sister to the Disneyland resort and left me home. She told me to fend for myself for dinner, and go to McDonald's or something. Yeah, right...I cooked for myself instead. That'll teach her to leave me home alone...LOL EDIT: sorry Maru....... Edited April 13, 2022 by Ayovan Landrotten Highlander, Citadelgrad, LSP_Kevin and 6 others 8 1
