Phil Smith Posted January 3, 2022 Share Posted January 3, 2022 Superb treatment. I am now inspired to consider a WWI-era subject for a future build. Well done. Link to comment Share on other sites More sharing options...
sandbagger Posted January 3, 2022 Author Share Posted January 3, 2022 Hi all, The upper wing fitted, Mike KUROK, monthebiff, scvrobeson and 3 others 6 Link to comment Share on other sites More sharing options...
sandbagger Posted January 3, 2022 Author Share Posted January 3, 2022 (edited) On 1/3/2022 at 8:57 PM, monthebiff said: Fantastic build Mike, out of interest why the blue rigging as I'm very intreauged? Regards. Andy Hi Andy, For whatever reason, some of the French aircraft had their rigging and metal fitting coloured blue. I don't think any other nation followed this trend, Mike Edited January 7, 2022 by sandbagger monthebiff 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 3, 2022 Share Posted January 3, 2022 Looks great, Mike! Kev Link to comment Share on other sites More sharing options...
sandbagger Posted January 5, 2022 Author Share Posted January 5, 2022 Hi all, The twin flying and landing wires are now fitted, as are the incidence wires between the interplane struts.. I still have the two drag wires and two side bracing wires (each side of the aircraft) to fit. Now the 32 separate infill strips between the flying and land wires to do, Mike LSP_Kevin, patricksparks, monthebiff and 4 others 7 Link to comment Share on other sites More sharing options...
sandbagger Posted January 6, 2022 Author Share Posted January 6, 2022 Hi all, The tail unit is done. That includes the rudder and elevator control cables, the twin bracing wires for the fin and the fin and tail plane support struts. These twin wires, like the flying and landing wires, will need infills and wrapping. Mike Landrotten Highlander, scvrobeson, LSP_Kevin and 1 other 4 Link to comment Share on other sites More sharing options...
sandbagger Posted January 8, 2022 Author Share Posted January 8, 2022 (edited) Hi all, I've fitted the linen wrapped infills between the pairs of flying, landing and fin bracing wires. I tried my previous methods of using baking parchment paper and 0.2 mm thick plastic card strips. However, the length of these pairs of wires are long and they flexed too much. Therefore, I cut strips of 'Aviattic' CDL decal to 1.75 width of each pair of wires. The water I used to release the decals was cold, as this tends to release the decal in a more rigid state than warm water would. That made it easier to position the decal strips onto the wires. The decals were laid centrally onto the top sides of the wires and left to allow the residual decal adhesive to grip to the wires. I then applied 'DACO Products' strong setting solution across the top of the decal strip. As the decal started to soften, I teased the edges under the wires to fully wrap them with the decal. Not easy but I think it should look OK once I've painted the decals. This is necessary as the decal is thin and the blue rigging wires shown through. Then it's onto finishing the rigging (drag and side wires), Mike Edited January 9, 2022 by sandbagger chukw, patricksparks, Jaro and 4 others 7 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 8, 2022 Share Posted January 8, 2022 That looks amazing, Mike! Hard to believe it's "only a model". Kev Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 8, 2022 Share Posted January 8, 2022 Most excellent! Link to comment Share on other sites More sharing options...
scvrobeson Posted January 10, 2022 Share Posted January 10, 2022 Very cool idea for doing the infills and wrapping. I will have to squirrel that one away for my own future Salmson build. Matt Link to comment Share on other sites More sharing options...
sandbagger Posted January 12, 2022 Author Share Posted January 12, 2022 Hi all, At last the rigging is complete. I've added the side bracing wires from the fuselage to the underside of the upper wing. Also the upper and lower drag wires from the engine bearer frame to the underside of the upper wing and leading edge of the lower wings. The flying, landing and fin bracing wire infills have also been painted with the same colour as the undersides of the wings and fuselage. I chose CDL as it's difficult to know if these infills were CDL or blue (as for the rigging wires. My assumption is that blue would has stood out too much against the camouflage surfaces, so I opted for CDL. So now it's onto the four wireless wires from the cabane struts to the underside of the upper wing. Also the fuel tank vent pipe, Mike Uncarina, Landrotten Highlander, LSP_Kevin and 3 others 6 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 12, 2022 Share Posted January 12, 2022 Brilliant! Appreciate you posting larger photos too, Mike. Kev Link to comment Share on other sites More sharing options...
sandbagger Posted January 12, 2022 Author Share Posted January 12, 2022 Hi all, I've added the vent pipe from the fuel tank, using 0.4 mm diameter black tube from 'MFH'. Also the four wireless wires, made from annealed and twisted 0.2 mm diameter copper wire. Now onto the front end parts, Mike chukw, scvrobeson, Squizzy 78 and 4 others 7 Link to comment Share on other sites More sharing options...
sandbagger Posted January 13, 2022 Author Share Posted January 13, 2022 Hi all, I've now added the pilot's Vickers machine gu ('GasPatch replacement), gun sight, ring site, mirror and coolant header tank. Also the wind driven pump/generator, with pipe from 0.4 mm diameter black tube from 'MFH'. Just the ailerons and control cables wind screens and observers weapons to add, then it's onto the figures, Mike monthebiff, scvrobeson, chukw and 8 others 11 Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 13, 2022 Share Posted January 13, 2022 Just LOVELY! The close ups prove how nice it really is. Well done man! Link to comment Share on other sites More sharing options...
