BradG Posted July 8, 2021 Posted July 8, 2021 Great work mate, I will add you to the gallery. chrish 1
Out2gtcha Posted July 8, 2021 Posted July 8, 2021 Awesome man! The tri-color does look really nice on the Trojan. The prop hub shaft is a bit long, but that's an issue with the kit itself and takes away nothing from a stellar build. Great work!
chrish Posted July 8, 2021 Author Posted July 8, 2021 1 hour ago, BradG said: Great work mate, I will add you to the gallery. Thanks! 15 minutes ago, Out2gtcha said: Awesome man! The tri-color really does look really nice on the Trojan. The prop hub shaft is a bit long, but that's an issue with the kit itself and takes away nothing from a stellar build. Great work! you’re right! I was aware of that problem but forgot to correct it. It is notable on the build and kind of robbing from the lines a bit and may be worth revisiting to try to correct Out2gtcha 1
chrish Posted July 8, 2021 Author Posted July 8, 2021 I'm back.... so knowing about the prop shaft length and having not dealt with it (because I forgot to earlier) I popped the prop out of the engine chucked the hub in my Dremel (oddly a perfect fit) and turned it down to the diameter that fits into the engine front, then cut off some length and refitted it to the engine. Now looking better. Hopefully that's all I need to amend. Thanks for bearing with me. jgrease, Landrotten Highlander, John1 and 10 others 13
John1 Posted March 24 Posted March 24 On 6/26/2021 at 11:24 PM, chrish said: Thanks for looking/ commenting. I can't take much credit for the instrument panels, all I did was paint the pe. front face and add some white/ blue background behind the film. As of quitting time tonight, I have glued in the cockpit, wheel bays, engine and closed up the fuselage the seams have been cleaned up as well. Thanks for looking Reviving an old thread - Chrish, if you happen to remember - how did you glue the Aires cockpit tub into the fuselage? I'm using this set but there doesn't appear to be many position contact points to ensure the tub is fitted correctly. Nice work on this kit by the way, your build turned out awesome.
