Citadelgrad Posted June 14, 2021 Share Posted June 14, 2021 7 hours ago, dennismcc said: Thank you for that and no the PCM kit is a very different animal to the Revell/Special Hobby kit which is a lot newer and a better kit, I've got the Special Hobby version in the stash. Unless you like ancient 60's and 70's kits I would leave the PCM kit alone. However I am very pleased with the result, it looks very much like a Tempest, graceful and brutal looking at the same time, purposeful may be a better description. Cheers Dennis You SHOULD be very pleased. Amazing finish. I really like this build. Great job. dennismcc 1 Link to comment Share on other sites More sharing options...
dennismcc Posted June 15, 2021 Author Share Posted June 15, 2021 On 6/14/2021 at 5:25 PM, Citadelgrad said: You SHOULD be very pleased. Amazing finish. I really like this build. Great job. Thank you very much it is really appreciated. Cheers Dennis Citadelgrad 1 Link to comment Share on other sites More sharing options...
dennismcc Posted June 26, 2021 Author Share Posted June 26, 2021 Nearly there, the wing tanks have been giving me grief, though it's my own fault as usual, it took a while to get the clear fairing frame decals in place, then I had to paint the areas were I was short of one decal. Then I decided to dirty the tanks up a bit so I held the tanks with clamps on the clear fairings while I did this. Fair enough, it went well but when I removed the clamps I also removed the decals that I had so carefully applied, so out with the paint again, not a great job but it will have to do, it's shame as the PCM decals for the tanks are better than the HGW Wet transfer versions. I also decided to drill the wing and fit pins to the tanks to fit them to the wings rather than just glue them to the wing, it's not accurate as the fuel pipes were at the rear of the tank on the real thing but never mind. I don't normally do things under wings but the Tempest tanks are so much a part of the Tempest story that I had to fit them. I also realised that I had forgotten to remove the masking disc from the various underside lamps so it was nice to remove them and see the finished results. And the corresponding holes in the wing. Then the radio aerial, it is showing on the photo as black but it's steel in real life as I believe they were stainless on the real thing. And the gun barrels, for this I used drilled out plastic rod painted with metallic black. Test fit of a tank, not the greatest fit, but no one will see it apart from me, and you lot. And the IFF aerial, again painted with steel And the semi finished state it is in at the moment, I am rather pleased with the result as it looked a bit iffy if I would finish it at all at the start of the build. That's about it, I'm just waiting for the varnish on the other tank to dry before I can fit it and then I'll take some more photos for the RFI. Cheers Dennis Troy Molitor, LSP_Kevin, Gazzas and 9 others 12 Link to comment Share on other sites More sharing options...
Gazzas Posted June 26, 2021 Share Posted June 26, 2021 Very nice, clean....almost result! Link to comment Share on other sites More sharing options...
Citadelgrad Posted June 27, 2021 Share Posted June 27, 2021 Again, i really like this build. Very nice. Link to comment Share on other sites More sharing options...
dennismcc Posted June 27, 2021 Author Share Posted June 27, 2021 9 hours ago, Gazzas said: Very nice, clean....almost result! 5 hours ago, Citadelgrad said: Again, i really like this build. Very nice. Thanks guys, all done now just finding the time to get some photos taken for the RFI. Cheers Dennis Link to comment Share on other sites More sharing options...
Chris Wimmer Posted June 27, 2021 Share Posted June 27, 2021 Wonderful! Looking forward to the RFI pics! Link to comment Share on other sites More sharing options...
dennismcc Posted June 27, 2021 Author Share Posted June 27, 2021 Thank you Chris, just about to post the RFI photos now. Cheers Dennis Link to comment Share on other sites More sharing options...
dennismcc Posted April 6, 2022 Author Share Posted April 6, 2022 Thank you Maru, I was very pleased with this one, it is now one of my favourites. Cheers Dennis nmayhew 1 Link to comment Share on other sites More sharing options...
dennismcc Posted May 13, 2022 Author Share Posted May 13, 2022 Once the Spitfire is out of the way I think that this will the next project while I am on a PCM roll. Cheers Den Out2gtcha, LSP_Kevin, MikeA and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 13, 2022 Share Posted May 13, 2022 Lovely build Dennis! I think PCM put out some truly lovely subjects, and this one really came out nice. Link to comment Share on other sites More sharing options...
MikeA Posted May 13, 2022 Share Posted May 13, 2022 That's come out beautifully! Love to see these PCM kits in their realised glory. I hadn't realised they had clear bomb fairings. Good luck with the Reggiane - one of my most challenging kit builds but it does make for a very impressive finished product. Cheers, Link to comment Share on other sites More sharing options...
dennismcc Posted May 14, 2022 Author Share Posted May 14, 2022 13 hours ago, Out2gtcha said: Lovely build Dennis! I think PCM put out some truly lovely subjects, and this one really came out nice. Thank you, it was a challenging build but very satisfying in the end, and yes PCM certainly put out some very impressive subjects that no one else had kitted, a lot of them are still the only kits in town. 11 hours ago, MikeA said: That's come out beautifully! Love to see these PCM kits in their realised glory. I hadn't realised they had clear bomb fairings. Good luck with the Reggiane - one of my most challenging kit builds but it does make for a very impressive finished product. Cheers, Thank you Mike and yes it did turn out nice in the end, apparently the Air Ministry was not impressed with Hawker designing their own wing tanks as they had lots of their own tanks in production. The Reggiane will I am sure be as challenging as the other PCM kits and I have re read a few build threads so hopefully I will be prepared for it. I have quite a collection of their kits and it is no use leaving them mouldering in the stash, better to build them. Cheers Dennis Link to comment Share on other sites More sharing options...
Suresh Nathan Posted August 29, 2022 Share Posted August 29, 2022 On 5/14/2022 at 5:44 PM, dennismcc said: Thank you, it was a challenging build but very satisfying in the end, and yes PCM certainly put out some very impressive subjects that no one else had kitted, a lot of them are still the only kits in town. Thank you Mike and yes it did turn out nice in the end, apparently the Air Ministry was not impressed with Hawker designing their own wing tanks as they had lots of their own tanks in production. The Reggiane will I am sure be as challenging as the other PCM kits and I have re read a few build threads so hopefully I will be prepared for it. I have quite a collection of their kits and it is no use leaving them mouldering in the stash, better to build them. Cheers Dennis Lovely work, Dennis. I'm building this now. Why were the fairings made clear? Apologies if it's already been answered. Link to comment Share on other sites More sharing options...
dennismcc Posted August 29, 2022 Author Share Posted August 29, 2022 6 hours ago, Suresh Nathan said: Lovely work, Dennis. I'm building this now. Why were the fairings made clear? Apologies if it's already been answered. Good on you building a PCM kit, there must be lots of tham sitting in stashes across the modelling world, they are challenging but generally build up into nice representations of the real thing, I'm on the finishing stages of their Spitfire IX at the moment and it's looking good despite my howlers. Never seen it mentioned about the reasoning behind the clear fairings but it would seem logical for leak checking and ensuring that the connections were made up correctly, I'll have to ask over on Britmodeller maybe the Typhoon and Tempest expert Chris Thomas has an answer. Cheers Dennis Link to comment Share on other sites More sharing options...
