Juggernut Posted August 19, 2022 Author Share Posted August 19, 2022 1 hour ago, Uncarina said: Congratulations on finishing this Tim. For such an involved build I salute your perseverance! At the same time I see no shortcuts, and your build is exemplary. Well done! Cheers, Tom Thanks a lot Tom, much appreciated. There are a couple of mistakes here and there but nothing that I’d consider major. Uncarina 1 Link to comment Share on other sites More sharing options...
Brett M Posted August 19, 2022 Share Posted August 19, 2022 That turned out sharp. Nice work! Link to comment Share on other sites More sharing options...
CShanne Posted August 19, 2022 Share Posted August 19, 2022 Great job Tim! It looks fantastic. Link to comment Share on other sites More sharing options...
Juggernut Posted August 19, 2022 Author Share Posted August 19, 2022 13 hours ago, Brett M said: That turned out sharp. Nice work! Thanks! Link to comment Share on other sites More sharing options...
Juggernut Posted August 19, 2022 Author Share Posted August 19, 2022 5 hours ago, CShanne said: Great job Tim! It looks fantastic. Thanks Chris, I'll do another Panther but in 1/35 and without the interior... LSP_K2 and CShanne 2 Link to comment Share on other sites More sharing options...
josebagasteiz Posted August 20, 2022 Share Posted August 20, 2022 Hola Tim. En primer lugar, los felicito por la culminación de este gran proyecto. Solo por eso te mereces todo el respeto. En segundo lugar, les diré que la apariencia final del tanque es impresionante, ¡simplemente me encanta! Es uno de los Panther 1/16 más geniales que he visto. Su esquema de camuflaje más los efectos de suciedad y polvo contribuyen a ese aspecto que tanto me gusta. He visto detalles admirables en su Panther, como la textura de acero en la cúpula del comandante, las líneas de soldadura, etc. Pero tengo una duda, el cañón del arma principal, es el de plástico o el de aluminio torneado? Espero que no tarde mucho en construir un nuevo modelo en 1/16. Para mí, la escala 1/35 muestra poco interés. Saludos y felicidades de nuevo!! Uncarina 1 Link to comment Share on other sites More sharing options...
Juggernut Posted August 20, 2022 Author Share Posted August 20, 2022 (edited) Hi Jose, Thanks! The barrel is the plastic one. If I had used the metal one, I would've had to keep it in the travel lock to prevent it from sagging to it's maximum depression point. Edited August 20, 2022 by Juggernut LSP_K2 1 Link to comment Share on other sites More sharing options...
Juggernut Posted August 30, 2022 Author Share Posted August 30, 2022 (edited) I was not happy with the way the tracks were sitting (they were much too loose/saggy), so I drilled out a track pin and removed a link from each side and reinstalled them. Now I'm much happier with the "run". When I took the photos, the left and right sides were different but after inspecting the model, I discovered that on the right side track run, the drive sprocket wasn't fully engaging the track. I corrected that minor problem and now both track runs are the same as shown in the top image below. I didn't take an "after" photo just because it was already in the case and didn't feel like removing it from the case again. Both runs were acceptable as contemporaneous photos show but not on the same vehicle. My advice to anyone building this kit is to leave a few sets of track pins loose so you can adjust the track tension as needed. You can't adjust the idler wheel so it has to be done with the tracks. Edited August 30, 2022 by Juggernut LSP_K2, LSP_Ray, Greg W and 6 others 9 Link to comment Share on other sites More sharing options...
josebagasteiz Posted August 30, 2022 Share Posted August 30, 2022 A joy to see new photos of your Panther. The truth is that it is very cool!! Juggernut, LSP_K2, Ryan and 1 other 4 Link to comment Share on other sites More sharing options...
Juggernut Posted August 30, 2022 Author Share Posted August 30, 2022 13 minutes ago, josebagasteiz said: A joy to see new photos of your Panther. The truth is that it is very cool!! Thanks Jose! Much appreciated. Ryan 1 Link to comment Share on other sites More sharing options...
jeroen_R90S Posted August 31, 2022 Share Posted August 31, 2022 Very cool, Panzers are not my primary interest, but this one, though a tough journey for you perhaps, was very interesting to follow from this side of the screen. It's also nice to see a lightly weathered tank rather than something that looks like it drove through a swamp and then left outside for 20 years. Nice work and congratulations on finishing the beast, it'll surely make an impression! LSP_K2, Juggernut, Ryan and 1 other 4 Link to comment Share on other sites More sharing options...
Juggernut Posted August 31, 2022 Author Share Posted August 31, 2022 7 hours ago, jeroen_R90S said: Very cool, Panzers are not my primary interest, but this one, though a tough journey for you perhaps, was very interesting to follow from this side of the screen. It's also nice to see a lightly weathered tank rather than something that looks like it drove through a swamp and then left outside for 20 years. Nice work and congratulations on finishing the beast, it'll surely make an impression! Thanks for the compliment, much appreciated! jeroen_R90S and Ryan 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted August 31, 2022 Share Posted August 31, 2022 Track tension certainly looks good to me. Nice job. Juggernut 1 Link to comment Share on other sites More sharing options...
Uncarina Posted September 1, 2022 Share Posted September 1, 2022 Thanks for the tip, and excellent work on the correction. I love the colors you chose for the camo. Cheers, Tom Link to comment Share on other sites More sharing options...
Juggernut Posted September 1, 2022 Author Share Posted September 1, 2022 10 hours ago, Uncarina said: Thanks for the tip, and excellent work on the correction. I love the colors you chose for the camo. Cheers, Tom Thanks Tom, I’m glad I can pass along some good info. Link to comment Share on other sites More sharing options...
