LSP_Kevin Posted January 8, 2021 Posted January 8, 2021 Great to see this one back, Chris! That is some amazing engineering work. Kev Chris Wimmer 1
Chris Wimmer Posted January 11, 2021 Author Posted January 11, 2021 On 1/8/2021 at 5:15 PM, Kagemusha said: One thing else to be gleaned from the video was how sloppy the spinner spirals were, obviously didn't use a mask from Eduard. Nice work on the prop and fan. If Eduard masks were there- I'm sure they'd have used them! Thank you for the kind words! On 1/8/2021 at 7:56 PM, Alain Gadbois said: I love the work on the fan gearing! Very impressive! Alain Thank you, Alain! Can't wait to turn the prop on the finished model. Hope it works to my satisfaction... On 1/8/2021 at 8:20 PM, RadBaron said: Mate that is bloody clever!! Love it Thanks very much! Very appreciated... On 1/8/2021 at 9:39 PM, LSP_Kevin said: Great to see this one back, Chris! That is some amazing engineering work. Kev Thank you, Kev! I'm happy that you like what I'm doing with my trainer. Still hoping you'll get back to yours one day! RadBaron 1
Chris Wimmer Posted January 11, 2021 Author Posted January 11, 2021 (edited) Focussing on the engine now. Many things need to be fixed up after it has been lying around for years. In addition I have cut off the device mount for further detailing work. Inside the red circle you can (or can't) make out the now black painted gearwheels. Thanks for looking in! Chris Edited January 11, 2021 by Chris Wimmer KiwiZac, Greg W, Fanes and 8 others 11
Chris Wimmer Posted January 23, 2021 Author Posted January 23, 2021 (edited) Hi again! The space in front of the engine looks a bit empty as the Revell kit doesn't provide an oil tank. I found a couple of good pictures of a Fw190A-3 tank, not sure whether it's correct for the A-8. Anyway this is the point where my efforts on serious modelling come to an end: The kit engine is placed much more forward than the real one. So all I did was to create something that gives just an idea of all the things that should be there... More to come soon, thanks for looking in! Chris Edited January 25, 2021 by Chris Wimmer thierry laurent, LSP_Kevin, mgbooyv8 and 9 others 11 1
Chris Wimmer Posted January 24, 2021 Author Posted January 24, 2021 6 hours ago, LSP_Kevin said: Superb work, Chris! Kev Thank you, Kev. LSP_Kevin 1
thierry laurent Posted January 24, 2021 Posted January 24, 2021 These vacformed parts are terrific! Chris Wimmer 1
mgbooyv8 Posted January 25, 2021 Posted January 25, 2021 Hi Chris, I’m catching up on your thread. Very good work and an ingenious solution to the cooling fan gear! keep up the good work! Cheers, Peter Chris Wimmer 1
Padubon Posted January 29, 2021 Posted January 29, 2021 On 1/7/2021 at 12:51 PM, Chris Wimmer said: Happy New Year Everyboy! It's been a while since I made my latest post, but this doesn't mean there has nothing happened in between. So I have to tell a little story first: Years ago I reworked my stone-old Hasegawa Wuerger and backdated it to a Fw190A-2. Back then I didn't want to attach the cooling fan to the prop again, because on the real aircraft the fan rotated with about triple prop speed! I wanted my model to do the same, so I came up with a simple gearing by using gearwheels that I found at a model-railway shop. These were quite big, about 20mm in diameter, but that didn't matter because the engine section was to be sealed up anyway. Well, the gearing works nicely today and generates an enjoyable "WOW!" everytime I invite a guest to turn the prop. I have made a video to show you the effect. Added a bit airshow sound and also Count Basie's "April in Paris", because I found it suitable and because I love brass... Check it out here: https://www.youtube.com/watch?v=Os5O3g3OKWY Of course I want to add this gimmick to this build as well, but as I want to display the engine, partially at least, everything has to be smaller this time. The model-railway shop doesn't exist anymore, so I made an attempt by using small sized nylon gearwheels, as you can see in the following 2016 pic. Unfortunately this configuration didn't work at all, maybe the gearwheels were to small and soft and also the gear ratio wasn't right. Finally it turned out to be this build's ticket to the SOD... Thank god LSP has always been my greatest mojo-source, so here is what I did during the past weeks: Prop-shaft made from 2mm brass rod, soldered to a 20 teeth gearwheel. Fan-shaft made from 3mm brass tube, soldered to a 12 teeth gearwheel. By using these gearwheels I will achieve a transmission ratio of about 2,75. So this means that the fan will turn a little bit too slow. I'd rather prefer 3 or a bit more, but this finally depends on the gearwheels you can get and I think I can live with it. The newly prepared housing: Gearing in place... and covered: My little intervention should be barely visible once the engine is finished... Thanks for looking in! Chris I wish I have your patience!!! Chris Wimmer 1
Chris Wimmer Posted February 27, 2021 Author Posted February 27, 2021 (edited) Hi Everybody, time for an update, absolutely! Let's start with the main spar which is not entirely correct in shape. If you leave it as it is, the gear bay will be losing a lot of its depth... So I started with this... and ended up here: Then I tried to add further improvements to the engine: I cut small pieces of injection needle, glued them into a shaped piece of sheet styrene and then made twelve copies from UV glue: Added some paint... ...and glued them in place. So here ist my almost finished kit engine with the oil wash still wet... Well, that's the state of my build now. Hmm, no chance at all to hit the deadline... Eeh...HUHU........Dear Mr. Admin......Sir! May I kindly ask you to extend this GB by about.........THREE YEARS??????????? Thanks for looking in Chris Edited February 27, 2021 by Chris Wimmer Landrotten Highlander, Martinnfb, LSP_Kevin and 11 others 9 5
LSP_Kevin Posted February 27, 2021 Posted February 27, 2021 Superb work, Chris! And still an inspiration for my own effort. Should we move your build over to the WiP forum? Kev Chris Wimmer 1
Chris Wimmer Posted February 28, 2021 Author Posted February 28, 2021 7 hours ago, LSP_Kevin said: Superb work, Chris! And still an inspiration for my own effort. Should we move your build over to the WiP forum? Kev I agree with you, Kev. Definately want to carry on with this one. Also many Thanks for the kind words! cheers Chris
Alain Gadbois Posted February 28, 2021 Posted February 28, 2021 Excellent work Chris! Nice improvements in the wheel well. Alain Chris Wimmer 1
Chris Wimmer Posted February 28, 2021 Author Posted February 28, 2021 25 minutes ago, Alain Gadbois said: Excellent work Chris! Nice improvements in the wheel well. Alain Thank you very much, Alain. I'm happy you like it!
