REJ Posted August 3, 2020 Author Share Posted August 3, 2020 (edited) Started experimenting with color and distressing the rudder bars. This is Mr. Paint blue grey and comes pretty darn close. I will probably darken the rudder a touch more, but I believe this is close. I also went back and researched VMSB 241 more and it appears they loaded out for the Midway attack on the Japanese fleet with a single 500 lb bomb only. Since the Marines had almost no time in SBDs, they decided to make gliding attacks such as they trained extensively in the Vindicators. 2106's pilot Iverson, missed on his run and received over 200 holes in 2106 wounding his gunner badly. So no wing bomb racks...they would have been left off as not needed on this mission. Edited August 3, 2020 by REJ TenSeven, Landrotten Highlander, LSP_Kevin and 1 other 4 Link to comment Share on other sites More sharing options...
REJ Posted August 3, 2020 Author Share Posted August 3, 2020 The cockpit tub is now one whole unit. I finally joined the myriad of individual components together. Here I have inserted the tub into the fuselage and I'm checking that everything is still lining up properly. The worst section is the firewall to fuselage halves junction. They're just enough off to be a headache, but nothing that can't be conquered with a little planning and patience. Whitey, Lothar, TenSeven and 4 others 7 Link to comment Share on other sites More sharing options...
Lothar Posted August 3, 2020 Share Posted August 3, 2020 Excellent work so far, your cockpit is simply beautiful Lothar REJ 1 Link to comment Share on other sites More sharing options...
REJ Posted August 3, 2020 Author Share Posted August 3, 2020 Thank you Lothar...I am working hard to make the rest of this kit as well. TenSeven, scvrobeson, coogrfan and 2 others 5 Link to comment Share on other sites More sharing options...
REJ Posted August 7, 2020 Author Share Posted August 7, 2020 Got the compass and power line mounted inside the forward canopy. Brett M, Landrotten Highlander, Lothar and 1 other 4 Link to comment Share on other sites More sharing options...
RadBaron Posted August 7, 2020 Share Posted August 7, 2020 that all looks Brilliant! REJ 1 Link to comment Share on other sites More sharing options...
REJ Posted August 7, 2020 Author Share Posted August 7, 2020 Thank you sir...always a welcome comment from such talented people such as yourself and others on this forum. RadBaron 1 Link to comment Share on other sites More sharing options...
REJ Posted August 21, 2020 Author Share Posted August 21, 2020 It's been awhile but here's the latest update. The fuselage halves have finally been joined together. I have started to work on seams and small details before I prime her. I have three different makes of intermediate blue for the upper camo and light grey for the underside camo. Any suggestions for a good insignia blue for the circles and stars? Looking to get something I can "sun bleach" a little. D.B. Andrus, LSP_Kevin and Landrotten Highlander 3 Link to comment Share on other sites More sharing options...
REJ Posted August 22, 2020 Author Share Posted August 22, 2020 Got some color on 2106 finally. Most all the seams are done, so I decided to spend the afternoon preping her for her first real color coat. I used AK intermediate blue and it worked out great. After a little thinning, it shot smooth and evenly. The color I believe is also near perfect. turbo, LSP_Kevin and Landrotten Highlander 3 Link to comment Share on other sites More sharing options...
REJ Posted August 22, 2020 Author Share Posted August 22, 2020 With the help of my beautiful wife (my arms aren't long enough), here's a couple of pics of the near complete top and bottom paint. Beginning to shape up good. Only some minor touch ups left and then gloss clear coats for decals, weathering, and staining. Moving right along... Lothar, Trak-Tor, LSP_Kevin and 6 others 9 Link to comment Share on other sites More sharing options...
Brett M Posted August 23, 2020 Share Posted August 23, 2020 Looking great.....and BIG! Can’t wait for more progress. REJ 1 Link to comment Share on other sites More sharing options...
REJ Posted August 24, 2020 Author Share Posted August 24, 2020 Well...minor setback. Upon careful examination, I had neglected to fill a hole under each wing for the surface radar antenna posts not used on the SBD-2s. Also, a hole in the lower fuselage for a small stub antenna didn't look good enough to me, so it gets more attention too. When all is done, it should be ready for clear coat....unless there's something else I find. Landrotten Highlander, TenSeven and Brett M 3 Link to comment Share on other sites More sharing options...
REJ Posted August 27, 2020 Author Share Posted August 27, 2020 Finally getting down to the clear coats. I javelin two marks in the paint that require attention and all is ready. All the holes are filled and gone. The bomb cradle was added as well as the tie-down cleats. A little paint was applied and the lower half is ready for clear coating. TenSeven, D.B. Andrus, Lothar and 3 others 6 Link to comment Share on other sites More sharing options...
George Posted August 28, 2020 Share Posted August 28, 2020 I read the USMC may have painted over the fabric rudder with existing stocks of insignia blue because of M-485 was not available and the time frame for the directive to paint over the horizontal rudder stripes and insignia red balls was less than one month (after Coral Sea and before Midway). Link to comment Share on other sites More sharing options...
REJ Posted August 28, 2020 Author Share Posted August 28, 2020 (edited) This is a Navy picture taken of the damage to the tail of 2106 after she returned from the Midway attack on the Japanese fleet. As you can see, the stripes on the tail are still visible because of the hasty job done earlier. If the Marines had done a second coat using insignia blue, those stripes would have been pretty well covered. The Marines had less than three weeks to prepare this Navy retired SBD for combat. Edited August 28, 2020 by REJ coogrfan and TenSeven 2 Link to comment Share on other sites More sharing options...
