Wackyracer 2,301 Posted May 29, 2020 Share Posted May 29, 2020 56 minutes ago, MikeMaben said: That sorts the wing to fuse issue! Derek B and MikeMaben 1 1 Link to post Share on other sites
jenshb 868 Posted May 29, 2020 Share Posted May 29, 2020 9 hours ago, LSP_Ron said: With regards to the wings, they were different than other marks previous to the Mk 21 http://spitfiresite.com/2010/04/concise-guide-to-spitfire-wing-types.html/3 Yes, the wing was definitely different, however, the basic planform matched that of the original wing except near the tip. If you look at Sheet no 1 of Arthur Bentley's drawing, the wing planform takes the extended high altitude wing tips, crop them and rounds off the edges to match the wingspan of the elliptical wing tips. The Tamiya wing can therefore be used as a basis for a Mk. 21-24 conversion - as per Jumpei Temma's findings and SEafire 47 conversion. It will need a total rescribe and a fair bit of cut and splice though... https://www.albentley-drawings.com/drawings/british-aircraft/supermarine-spitfire/supermarine-spitfire/ Link to post Share on other sites
pvanroy 145 Posted May 29, 2020 Share Posted May 29, 2020 You may be interested in Phil Listemann's booklet on the Spitfire F.24 (Allied wings 18): https://www.raf-in-combat.com/downloads/aw18-the-supermarine-spitfire-f-24/ This booklet has a photo of VN 496 on p. 21, and a profile of this machine at the end. Also note that late production F.24s used the same gear covers as the Seafire FR.47. Kagemusha 1 Link to post Share on other sites
GrahamF 1,532 Posted May 29, 2020 Share Posted May 29, 2020 The reason for the different wings was because of increased stresses by the higher speeds of the Griffon Engine, two parallel wing studies were carried out one the Spiteful Laminar flow wing and a reinforcement of the original wing, both to achieve a higher rate of role and an aileron reversal speed ofa theoretical 850mph, i.e. the speed at which the wings flex and the Ailerons become ineffective. The Spiteful wings gave an instant 50mph advantage fitted to the Spitfire MK14 but this advantage was whittled away by half by the time alterations to it's low handling speeds were completed. The later MK21 wing was more successful and initially it had the same plan as the high altitude 'pointed tips' winged aircraft with the ailerons further out but these were nicely rounded off later at the production stage. Graham Link to post Share on other sites
Archimedes 210 Posted May 29, 2020 Author Share Posted May 29, 2020 (edited) 6 hours ago, pvanroy said: You may be interested in Phil Listemann's booklet on the Spitfire F.24 (Allied wings 18): https://www.raf-in-combat.com/downloads/aw18-the-supermarine-spitfire-f-24/ This booklet has a photo of VN 496 on p. 21, and a profile of this machine at the end. Also note that late production F.24s used the same gear covers as the Seafire FR.47. Useful - thanks! I compiled what I could of 80 squadron codes but VN496 was the one I could not pin down for sure until Kagemusha found it as T/N but it looks to be as a Royal Auxilliary Airforce airframe in those pictures. THis is what I have so far: 80 Squadron W2-A VN489/VN301 W2-B VN312 W2-C VN311 W2-D VN309/VN319 W2-E VN320 W2-F VN318 W2-G W2-H VN484 W2-J W2-K W2-L VN308 W2-M VN495/PK678 W2-N PK642/PK682 W2-P VN317 W2-Q W2-R W2-S W2-T VN307 W2-U PK*** W2-X W2-Y W2-Z Royal Hong Kong Auxiliary Air Force T/N VN496 I hope that helps someone. All have been verified from photographic evidence not simply profiles. Edited May 29, 2020 by Archimedes Additional information Link to post Share on other sites
GrahamF 1,532 Posted May 29, 2020 Share Posted May 29, 2020 W2-W VN314 Link to post Share on other sites
Archimedes 210 Posted May 30, 2020 Author Share Posted May 30, 2020 4 hours ago, GrahamF said: W2-W VN314 Thanks Graham - one more to add to the files. Link to post Share on other sites
Hacker 348 Posted February 11 Share Posted February 11 On 5/27/2020 at 4:05 PM, Ralph-D said: I remember MasterCasters did also parts for the type 24, who knows more? Is MasterCasters still in business? Been trying to find them. Thanks to Ray l got one of their Mk 22/24 cockpits and wish another one but their site seems to be down Hacker Link to post Share on other sites
thierry laurent 6,977 Posted February 11 Share Posted February 11 Parts are just slightly modified copies of Tamiya cockpit elements. This would not be a problem if the three sets I saw were not underscaled! Hopefully I only purchased one, not the two other ones. So, I would rather recommend starting from a Brassin or Aires cockpit. Troy Molitor 1 Link to post Share on other sites
BloorwestSiR 11,972 Posted February 12 Share Posted February 12 9 hours ago, thierry laurent said: This would not be a problem if the three sets I saw were not underscaled! Thierry, I don't think the parts are underscale so much as the Matchbox fuselage is overscale. My copy of the Mastercasters cockpit set had a few poorly moulded parts to it so I subbed in Tamiya parts and they were equally undersized. I ended up increasing their width by gluing styrene strips along their outer edges. Not prefect but a better fit. I also tried an Aires set meant for the Tamiya kit but it was even smaller. I think that one of the sets designed for the Hasegawa kits might be a better option. Carl Link to post Share on other sites
thierry laurent 6,977 Posted February 12 Share Posted February 12 4 hours ago, BloorwestSiR said: Thierry, I don't think the parts are underscale so much as the Matchbox fuselage is overscale. My copy of the Mastercasters cockpit set had a few poorly moulded parts to it so I subbed in Tamiya parts and they were equally undersized. I ended up increasing their width by gluing styrene strips along their outer edges. Not prefect but a better fit. I also tried an Aires set meant for the Tamiya kit but it was even smaller. I think that one of the sets designed for the Hasegawa kits might be a better option. Carl Possibly but a comparison between the original Tamiya parts and the resin copies showed the latter to be quite smaller (due to mold retraction I guess?). In any case I also added plastic shims on the perimeter. BloorwestSiR 1 Link to post Share on other sites
BloorwestSiR 11,972 Posted February 12 Share Posted February 12 11 hours ago, thierry laurent said: Possibly but a comparison between the original Tamiya parts and the resin copies showed the latter to be quite smaller (due to mold retraction I guess?). In any case I also added plastic shims on the perimeter. There's definitely some shrinkage in the parts. I dug out the Seafire I was doing but gave up on as there's no way to make it accurate. I still have some of the Mastercasters pieces I'd planned to use. Here's the Mastercasters cockpit floor and side panel. The load floor with the Aires (for the Tamiya kit) side panel. And compared to the stock Tamiya side panel. In the end, I got as far as stealing the entire cockpit from a Tamiya kit and shimming it as needed to make it fit. As an aside, I tried the IP from the PCM XIV kit and it's almost a drop fit. Needs a quick sanding towards the bottom edge but it seems to fit nicely. Same goes for the frame the seat attaches to. Carl Out2gtcha, Troy Molitor, Derek B and 1 other 4 Link to post Share on other sites
