Rob Colvin Posted November 21, 2019 Posted November 21, 2019 RoG Eurofighter I seem to recall someone did the extra pylons and some other parts for the eurofighter.....Who was it are they still available? Does anyone know how the Aires engines and cockpit fit? thanks! Marcel111 1
Stokey Pete Posted November 21, 2019 Posted November 21, 2019 If I recall, the cockpit tub fits quite well, but as always, requires lots of sand/test fit/repeat. The aires exhausts were a pain, having to remove material from both kit and exhaust tube. That said, I ended up using both in a Trumpeter kit, which made for interesting fitting. Try Phase Hangar Resin for your extras. https://phasehangarresin.com/collections/32001-1-32
Kagemusha Posted November 21, 2019 Posted November 21, 2019 Tim (Wunwinglow) produces a full pylon set, including the centreline one.
Marcel111 Posted November 21, 2019 Posted November 21, 2019 I built the kit a while back. I found the Aires cockpit, exhausts and wheel wells to fit perfectly. The surface detail of the kit is exceptionally rough though, I regret not filling and rescribing the whole model. Cheers, Marcel
Chek Posted November 22, 2019 Posted November 22, 2019 Marcel's build log over on ARC (back in about 2011 IIRC) is well worth looking up as a reference itself, and fitting those parts you ask about. Marcel111 1
Kagemusha Posted November 22, 2019 Posted November 22, 2019 The nose undercarriage by Aerocraft is highly recommended. wunwinglow 1
otis252 Posted November 23, 2019 Posted November 23, 2019 I wish we could get Brimstone missiles for the Eurofighter. Chuck wunwinglow and Michael931080 2
Michael931080 Posted November 23, 2019 Posted November 23, 2019 Brimstones would be a nice touch but I would rather some for the Tornado myself! otis252 and wunwinglow 2
Tony T Posted November 23, 2019 Posted November 23, 2019 (edited) As well as the Aerocraft brass nose leg, I would recommend the CWS etched inlet part... https://coldwarstudio.com/PE Detail Set 1/32 scale category/ The kit splitter plate is one of the few ghastly elements of the otherwise accurate Revell. Not sure about the way CWS have interpreted the rear fairings, but this set looks great — tucked away ready for use so I cannot comment on fit. Could still use full intake trunking but the intake covers already mentioned look good and add a splash of colour. Tony Edited November 23, 2019 by Tony T clarity
otis252 Posted November 23, 2019 Posted November 23, 2019 I agree, I'd love to see have Brimstones for my Tornado GR4. Chuck thierry laurent and wunwinglow 2
Tony T Posted November 23, 2019 Posted November 23, 2019 Might be in the Italeri Tornado kit, which is still listed as a future release. The two seater Eurofighter kit has more air-to-surface options. Tony
