tchwrma Posted April 29, 2019 Author Share Posted April 29, 2019 Gents, the updates: Kit nº1 panel assembled: nº2: The joint glued, corrected with CA glue, sanded, and rescribed: The front unit glued: Result so far: Now let's bring the 2nd kit up to that point Paulo. Out2gtcha, Alain Gadbois, LSP_Kevin and 9 others 12 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 1, 2019 Share Posted May 1, 2019 Looking good Paulo! tchwrma 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted May 3, 2019 Share Posted May 3, 2019 On 5/1/2019 at 8:17 AM, Out2gtcha said: Looking good Paulo! I agree! Link to comment Share on other sites More sharing options...
tchwrma Posted May 3, 2019 Author Share Posted May 3, 2019 On 5/1/2019 at 12:17 PM, Out2gtcha said: Looking good Paulo! 1 hour ago, LSP_Ray said: I agree! Thanks, Friends. Paulo. Link to comment Share on other sites More sharing options...
tchwrma Posted July 12, 2019 Author Share Posted July 12, 2019 Hi, guys! After some time in posting the updates of the kits, besides that I had made progress in the kits, I failed in update the jobs. So let's go: I was unhappy with the Wheel bays, so I decided to made some scratch to get a better results. I sanded the original tubing. and created the tubing of the bays using brass tubes. The results: This work gave me so many troubles, tat I decided to made the scratch in only one kit, leaving the other one OOB. Here the two planes completely assembled: Here a modification (I can't resist). The position lights of the kit are quite ugly, and not create a good shape in the wingtip pod. So I discarded them and made new ones, with colored plastic. Much better, I believe: Here, finally I received the Archer rivets set. One part absent in the kit, as the Kittyhawk kit are not an F-5E, but an F-5N, is the windshield cleaning pod. I copied in resin from the pod included in the hasegawa kit. Here applied: So after the correction of some issues, finally I started to paint them. First color in the two(Brown in the 4870 and grey in the 4857) Soon, more updates. Cheers, Paulo. Gazzas, Out2gtcha, Alain Gadbois and 5 others 8 Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 12, 2019 Share Posted July 12, 2019 Lovely work Paulo! tchwrma 1 Link to comment Share on other sites More sharing options...
tchwrma Posted July 12, 2019 Author Share Posted July 12, 2019 32 minutes ago, Out2gtcha said: Lovely work Paulo! Thanks, Brian! Link to comment Share on other sites More sharing options...
Shujaa Posted July 12, 2019 Share Posted July 12, 2019 Hate to brake it to You but Your modification to (what You call) the wingtip pods has been in vane... These "wingtip pods" are actually missile launchers for the AIM-9 Sidewinder and are not equipped with navigation lights...!!! If You have a good look at the wingtips of the wings, You'll find a hole at each side (which probably need to be filled with a transparent piece). THESE represent the formation lights...!!! (Green on the right side & red on the left side.) Kind regards, Rudy. Link to comment Share on other sites More sharing options...
tchwrma Posted July 13, 2019 Author Share Posted July 13, 2019 13 hours ago, Shujaa said: Hate to brake it to You but Your modification to (what You call) the wingtip pods has been in vane... These "wingtip pods" are actually missile launchers for the AIM-9 Sidewinder and are not equipped with navigation lights...!!! If You have a good look at the wingtips of the wings, You'll find a hole at each side (which probably need to be filled with a transparent piece). THESE represent the formation lights...!!! (Green on the right side & red on the left side.) Kind regards, Rudy. Rudy, thanks for your kind words, but I'm sure of these lights. And a curiosity: The lights on the sidewinder pod are red and green, but the round ligths in the wing are red and blue, in the same way of the ones in the inlets of the fuselage. At least in the Brazilian jets. Cheers, Paulo. BradG, Kagemusha, Gazzas and 1 other 4 Link to comment Share on other sites More sharing options...
themongoose Posted July 15, 2019 Share Posted July 15, 2019 Paulo i had the hardest time trying to make the clear cutout in the wing lights show up well. Mine kept reflecting the light color and i finally gave up. Would be interested in seeing your approach to those Link to comment Share on other sites More sharing options...
tchwrma Posted July 16, 2019 Author Share Posted July 16, 2019 (edited) 16 hours ago, themongoose said: Paulo i had the hardest time trying to make the clear cutout in the wing lights show up well. Mine kept reflecting the light color and i finally gave up. Would be interested in seeing your approach to those I just cut a piece of colored plastic and glued in the place, in the sidewinders pod. Then I sanded with a dremel, to get the approximate size. The final sanding was made with various grains of sandpaper, until finally polishing the part, to get it done. Unfortunately, i did not photographed the process, but I can post pictures of the process made in a wingtips lights in a 1/32 Hellcat. It's the same process, only changing the clear plastic used in the Hellcat one for a colored plastic in the F-5E. Edited July 16, 2019 by tchwrma spell checking Link to comment Share on other sites More sharing options...
tchwrma Posted July 16, 2019 Author Share Posted July 16, 2019 This was the work realized in the Hellcat: Cheers, Paulo. Link to comment Share on other sites More sharing options...
tchwrma Posted July 16, 2019 Author Share Posted July 16, 2019 I just remember that i not made the lights in my third plane, the Hasegawa one. I will do it and will photogaph the process. Then I will post here. Cheers, Paulo. Link to comment Share on other sites More sharing options...
CZPetrP Posted July 16, 2019 Share Posted July 16, 2019 Nice job... Link to comment Share on other sites More sharing options...
tchwrma Posted July 16, 2019 Author Share Posted July 16, 2019 (edited) 3 hours ago, CZPetrP said: Nice job... Thanks, my friend. Just at this point, my compressor blows out. I'm no painting since friday. Tomorrow I believe that the job will be resumed. Cheers, Paulo. Edited July 16, 2019 by tchwrma spell checking Link to comment Share on other sites More sharing options...
