BSteinIPMS Posted December 7, 2018 Author Posted December 7, 2018 9 minutes ago, LSP_Ray said: Damn, that is nice!!! BTW, I am a Facebook member, but neither link works for me, either. Okay, thanks Ray. What seems to work best is to go to my online Google Photo Album where these pics live, right-click the photo, and select "Copy image address" from the drop-down menu, paste it into this post, then - as if by magic - the six or seven line URL converts into an image. Wow! Just like magic! Oh, and this is the Oberürsel UR.2 rotary engine which is installed in the airframe. Jeff, RandyB, LSP_Kevin and 1 other 4
BSteinIPMS Posted December 7, 2018 Author Posted December 7, 2018 9 minutes ago, Out2gtcha said: Wowzers! that is spectacular Thanks, Brian. And I had a great time at the 2017 IPMS/USA Nats in Omaha. Give yourself a pat on the back if you had anything to do with it. Cheers! --Bob Out2gtcha 1
Out2gtcha Posted December 7, 2018 Posted December 7, 2018 8 minutes ago, BSteinIPMS said: Thanks, Brian. And I had a great time at the 2017 IPMS/USA Nats in Omaha. Give yourself a pat on the back if you had anything to do with it. Cheers! --Bob Thanks Bob! Yes, it was our Omaha Fort Crook Cpter IPMS that put in the efforts, and I certainly cant take the credit, but can only hope I did help make it fun! Would have loved to have met you!
BSteinIPMS Posted December 7, 2018 Author Posted December 7, 2018 17 minutes ago, Out2gtcha said: Thanks Bob! Yes, it was our Omaha Fort Crook Cpter IPMS that put in the efforts, and I certainly cant take the credit, but can only hope I did help make it fun! Would have loved to have met you! Me too....I met some very nice folks there. Having seen some spectacular WWI models there, I was inspired to carve my own laminated propeller. I think anyone could do this in this scale if they didn't mind being awash in a sea of sawdust...... The kit provides a plastic propeller which does not capture the ambiance of the laminated original made from walnut and birch. Using cherry and basswood I laminated up seven layers of wood, glued with Titebond and clamped. Titebond is an aliphatic resin glue which when dry can be sanded out to a feather edge, drilled, and carved, unlike rubbery white glue which is a polyvinyl acetate. LSP_Kevin, Out2gtcha, Jeff and 1 other 3 1
Gazzas Posted December 7, 2018 Posted December 7, 2018 That's fricking brilliant, man!! It looks so damn good, that I'm not even going to try to emulate it. Gaz
MikeMaben Posted December 7, 2018 Posted December 7, 2018 23 hours ago, LSP_Kevin said: Your articles for FSM are still among my favourites! Me too Bob. I always knew an issue with your name on it would be a goody . Your builds were always an inspiration to me.
Jeff T Posted December 7, 2018 Posted December 7, 2018 That engine is brilliant Bob! Beautiful work indeed. Cheer's, Jeff.
LSP_Ray Posted December 8, 2018 Posted December 8, 2018 That engine doesn't look like what I saw in the kit... Beautiful job! Same with the prop. Do you have a build article anywhere on this? I would love to print it out and put with my kit for the future. Out2gtcha 1
BiggTim Posted December 8, 2018 Posted December 8, 2018 That is utterly amazing, Bob! Now I want one even more! Alas, I will have to continue with my plans to scratch one in 1/16, as that kit is far out of my financial reach. Should be fun, though!!
