ClumsyDude Posted March 20, 2017 Share Posted March 20, 2017 Nice. Urs 1 Link to comment Share on other sites More sharing options...
Joel_W Posted March 20, 2017 Share Posted March 20, 2017 A most interesting build of a not so popular subject. Like Harv, I'll be pulling up my chair and following your build to it's completion. The finished cockpit is simply outstanding. Those hand holds couldn't possibly look any better, and the wood floor blends in perfectly with your overall weathering scheme. Joel Urs 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted March 20, 2017 Share Posted March 20, 2017 Urs Terrific front office and the weathering is what I would think the Shurmovik would have looked like from heavy combat. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
amurray Posted March 21, 2017 Share Posted March 21, 2017 The cockpit looks great! I like the detail and the wash you did. Looks very realistic! Care to share any of your tips for doing the wash you did? Urs 1 Link to comment Share on other sites More sharing options...
dmthamade Posted March 21, 2017 Share Posted March 21, 2017 Yup!! The finished pit looks great!! What scheme are you going to finish the build? If i can offer some advice, carefully remove the tadpole rudder counterweight and reinstall near the end, it's easily broken off and lost, ask me how i know.... Don Urs 1 Link to comment Share on other sites More sharing options...
Urs Posted March 21, 2017 Author Share Posted March 21, 2017 Dmthamade I'm not not sure up until now, but I tend toward that one. dutik and Shawn M 2 Link to comment Share on other sites More sharing options...
Shawn M Posted March 21, 2017 Share Posted March 21, 2017 love that scheme ^ Link to comment Share on other sites More sharing options...
Joel_W Posted March 21, 2017 Share Posted March 21, 2017 What an unusual camo scheme. Should really make your finished build pop even that much more. Joel Link to comment Share on other sites More sharing options...
Urs Posted April 10, 2017 Author Share Posted April 10, 2017 (edited) Despite the sunny days that WE I found some time for my Iljuschin for further build. I have to admit I've never put that heavy load of metal to an aircraft model. I get the impression my model gained weight by a ton. The Eduard PE-parts worth any penny and turn the outer shape of the Flying Tank into a nice 3D experience. Sadly Eduard external PE-sheet provides too few maintenance hatches and letting out enough EP-hatches for the outer portion of the wings. Maybe Eduards concession to the wooden wing variant produced until 1944, though both wing types were produced for that IL-2 subtype.The kit carbutor intake I cut because it was of unround shape. I replaced it by a Aluminum turn part I made. The mesh for the sandfilter is Eduard too. The facing intake part was fully closed and needed to be drilled out in the ellipsoid appear of the original thing. The kit provides two undercarriage options – that one made of white metal and moulded plastic..The lower wing with tons of hatches to do. I think to use Bare Metal Foil for that to have the same style of hatches over the whole wing. Edited April 10, 2017 by Urs Shaka HI and Whitey 2 Link to comment Share on other sites More sharing options...
Joel_W Posted April 10, 2017 Share Posted April 10, 2017 (edited) That's a lot of Eduard PE hatches, but they do look really quite good, as does that carb intake screen. If you're going to try to use Bare Metal for additional hatches, they're going to be quite a bit thinner then the Eduard PE hatches. As a suggestion, try .040 sheet plastic which should be a lot closer in thickness. Joel Edited April 10, 2017 by Joel_W Urs 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted April 10, 2017 Share Posted April 10, 2017 Link to comment Share on other sites More sharing options...
Martinnfb Posted April 10, 2017 Share Posted April 10, 2017 And here is Karolin with one of his gunners Link to comment Share on other sites More sharing options...
Blackcollar Posted April 11, 2017 Share Posted April 11, 2017 (edited) Hi, I took this photo in Seattle and thought you might get some use out of it. Al https://www.flickr.com/photos/105989555 Edited April 11, 2017 by Blackcollar Urs and Kais 2 Link to comment Share on other sites More sharing options...
Urs Posted April 14, 2017 Author Share Posted April 14, 2017 (edited) Thanks guys for the ideas and the shared pics.🖒🖒🖒 Ideal weather on Good Friday to work a little for the wings and the missing maintenance hatches on the upper and lower wing. Using very thin Greensheetsome copper wire for the joints and some small PE from the junk box for the fasteners. I know the real ones were as prominent as the ones provided by Eduard and the selfmade but they will effect fine with the paintjob. Added the Eduard modyfied rails for the RS-82 rockets. The rockets are aftermarket RES-IM RS-82 made of resine. The railds are just clicked in and will been removed for paintjob. Edited April 14, 2017 by Urs dutik, Joel_W, Kendzior and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Posted April 14, 2017 Share Posted April 14, 2017 Very nice !!......Harv Link to comment Share on other sites More sharing options...
