Shawn M Posted February 8, 2017 Share Posted February 8, 2017 grainy airbrushing...like a pebbly surface or spatter coming out the nozzle? Pebbly surface could be spraying to far from the model and the paint is drying in flight Spatter out the nozzle could be to thick of paint or to low of air pressure or a dirty tip mpk and LSP_K2 2 Link to comment Share on other sites More sharing options...
Shaka HI Posted February 8, 2017 Share Posted February 8, 2017 I had the same issue when applying metal finishes, Dale. That's not the AB's fault. I was advised to lower the pressure and spray about a inch from the model and this has helped, but I haven't perfected it well enough to advise you. The community will chime in. Once enclosed, you won't even notice the graininess of the engine. I say move on with regards to wiring up the engine. There's momentum and this is really your first build in years? But it's all up to you -- it's what I would do. mpk 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted February 8, 2017 Share Posted February 8, 2017 Oh, subsequent clears/washes will help with graininess...it did with my Peashooter (and this sucker's engine is practically exposed)! mpk 1 Link to comment Share on other sites More sharing options...
ClumsyDude Posted February 8, 2017 Share Posted February 8, 2017 Looking good Dale. I say add the wiring, I find I never regret farting around to add more detail ... Jim mpk 1 Link to comment Share on other sites More sharing options...
mpk Posted February 8, 2017 Author Share Posted February 8, 2017 (edited) grainy airbrushing...like a pebbly surface or spatter coming out the nozzle? Pebbly surface could be spraying to far from the model and the paint is drying in flight Spatter out the nozzle could be to thick of paint or to low of air pressure or a dirty tip Okay, great. The graininess can be seen on the cowling. I had the same issue when applying metal finishes, Dale. That's not the AB's fault. I was advised to lower the pressure and spray about a inch from the model and this has helped, but I haven't perfected it well enough to advise you. The community will chime in. Once enclosed, you won't even notice the graininess of the engine. I say move on with regards to wiring up the engine. There's momentum and this is really your first build in years? But it's all up to you -- it's what I would do. Oh I'm not blaming the tools. Thats like blaming drumsticks for poor technique. Yes, first build since around 1997/98 I believe. I am also looking at affordable cabinets. Not much to choose from really when it must be delivered to my residence. Looking good Dale. I say add the wiring, I find I never regret farting around to add more detail ... Jim Cool. I'll wire up the engine. Thanks guys. Edited February 8, 2017 by mpk Shaka HI 1 Link to comment Share on other sites More sharing options...
mpk Posted February 10, 2017 Author Share Posted February 10, 2017 Well this thread exists for a reason. Often the chemicals take over. I solved the Paasche problem as my mind returned. A lovely man at Hobby Tools Australia is going to look at it and repair it for me. This is however the last day of the cycle. The following is not what I'd call correct. Having looked at the more complex actual wiring of this engine. The wire I chose is deliberately over scale. This is so I can see it later. This is all I can do today. It's not much, but I did it. I also note it was easy to take the engine apart because I forgot to remove the paint before gluing. So it is a good thing I was motivated to do this. Thank you, Sir. Anthony in NZ, Victor K2, Shaka HI and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Posted February 10, 2017 Share Posted February 10, 2017 My friend, for your first try at it, I think it looks great....Harv Link to comment Share on other sites More sharing options...
ClumsyDude Posted February 10, 2017 Share Posted February 10, 2017 wiring looks super, Dale. Jim Shaka HI and mpk 2 Link to comment Share on other sites More sharing options...
mpk Posted February 10, 2017 Author Share Posted February 10, 2017 My friend, for your first try at it, I think it looks great....Harv Thanks mate. It was really just a challenge. I did it! I see this as a win. wiring looks super, Dale. Jim You're both too kind. Shaka HI 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted February 10, 2017 Share Posted February 10, 2017 Small step, big gain, Dale you are big motivation for me , your drive is simply inspiring . Thanks for sharing your insanity with us. Cheers M. Link to comment Share on other sites More sharing options...
LSP_K2 Posted February 10, 2017 Share Posted February 10, 2017 I use a scrap foam "stand" that allows my to flip the model over as well (has a cut out for cowling) That reminds me, I really need to grab a hot wire foam cutter one of these days. mpk and Shaka HI 2 Link to comment Share on other sites More sharing options...
mpk Posted February 10, 2017 Author Share Posted February 10, 2017 Small step, big gain, Dale you are big motivation for me , your drive is simply inspiring . Thanks for sharing your insanity with us. Cheers M. I am just happy to be here. To meet people such as yourself. Everyone. LSP_K2 1 Link to comment Share on other sites More sharing options...
Shawn M Posted February 10, 2017 Share Posted February 10, 2017 looking good Dale, keep up the momentum!! LSP_K2 and mpk 2 Link to comment Share on other sites More sharing options...
Guyman1 Posted February 10, 2017 Share Posted February 10, 2017 Looking good mate the George pit looks very nice. Guy mpk 1 Link to comment Share on other sites More sharing options...
mpk Posted February 10, 2017 Author Share Posted February 10, 2017 Thanks guys. I hope to work on it tomorrow. Depends how hot it is. It's supposed to be 40C today. Link to comment Share on other sites More sharing options...
