Tony T Posted March 6, 2016 Share Posted March 6, 2016 Utterly insane, and yet exquisite Tony Link to comment Share on other sites More sharing options...
pg265 Posted March 6, 2016 Author Share Posted March 6, 2016 Hi, Thank you Mates! The burnishing process is very easy! You just have to use a burnishing agent like the ones from Uschi Van der Rosten, Master Product or Blacken'it... In this case a white metal burnishing agent was used. Small progress on the dash board. Stainless steel pop rivets cut and installed. A little square bracket is fastened to the right side in order to hold the accelerator cable. C'est tout. Pascal LSP_Paul and Fooesboy 2 Link to comment Share on other sites More sharing options...
pg265 Posted March 7, 2016 Author Share Posted March 7, 2016 Hi, Still progressing on the Roooaaaarrring Papaya. Dashboard is finished and instruments are installed: Accelerator OK: I've tried to do the stitching by myself instead of applying decals: Pascal LSP_Paul 1 Link to comment Share on other sites More sharing options...
pg265 Posted March 7, 2016 Author Share Posted March 7, 2016 In the cockpit. A light weathering is started on the seat: Dry fitting: Voilà . Pascal LSP_Paul, ShelbyGT500, ClumsyDude and 2 others 5 Link to comment Share on other sites More sharing options...
Guest Posted March 7, 2016 Share Posted March 7, 2016 WOW ! Just fantastic......Harv Link to comment Share on other sites More sharing options...
ShelbyGT500 Posted March 8, 2016 Share Posted March 8, 2016 I've got the feeling you can start the engine Two words - real thing ClumsyDude 1 Link to comment Share on other sites More sharing options...
Bryan Posted March 9, 2016 Share Posted March 9, 2016 Pascal, Hope this isn't too off-topic... I know you are a fan of the Gravity Paints. I am trying it on my current kit. Seems good but I find the primer dries WAY too fast....so fast that it is hard to get a smooth finish....it wants to go on grainy. Do you have this problem, and if so how do you deal with it? Fantastic work again BTW. Link to comment Share on other sites More sharing options...
pg265 Posted March 12, 2016 Author Share Posted March 12, 2016 Hi, Thanks Mates! The primer is very thin and dries quickly, but if it dries before reaching the part surface, you should have a too high pressure... I use it with 0.15, 0.3 and 0.5 with pressure between 1.8 and 2 Kg... and even with a paint brush. The finish is always very smooth. Time for the clear coat: Modification for the wing support: Shoulder straps done too: More soon. Pascal LSP_Paul and ShelbyGT500 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted March 12, 2016 Share Posted March 12, 2016 Lovely work, Pascal! Kev Link to comment Share on other sites More sharing options...
LSP_Ron Posted March 13, 2016 Share Posted March 13, 2016 Lovely work, Pascal! Kev Ditto Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2016 Share Posted March 13, 2016 BAZINGO......Harv Link to comment Share on other sites More sharing options...
ClumsyDude Posted March 15, 2016 Share Posted March 15, 2016 Wow Pascal, that's super. What are those belts made from? They look (as everything else does) like the real thing! Jim Link to comment Share on other sites More sharing options...
LSP_Paul Posted March 16, 2016 Share Posted March 16, 2016 Simply Outstanding. The farther you go on this the more all of your hard prep work and extra detailing shows off, in the finish for example..meticulous. Paul Link to comment Share on other sites More sharing options...
Wolf Buddee Posted March 16, 2016 Share Posted March 16, 2016 Wow, what an amazing kit and equally amazing build Pascal. Very high "cool factor"! Cheers, Wolf Link to comment Share on other sites More sharing options...
pg265 Posted March 19, 2016 Author Share Posted March 19, 2016 Hi, Thanks very much Mates! Belts are made of lead foil. Small progress with the body installed and some work on the pipes with rubber connections and clamps. bracket for the brakes fittings Pascal Out2gtcha 1 Link to comment Share on other sites More sharing options...
