Babs Posted August 15, 2015 Share Posted August 15, 2015 (edited) Hello, I will try to make the Stearman of the Hatzerim museum This is a resin kit, the engine is not good for the IAF version, it will built in scratch. Not many instruments in the cockpit, the panels are slightly modified. Fuselage and wings are assembled, glued with super glue and to be correct with the dihedral at the first time. Edited February 3, 2019 by Babs Change links of pictures. Lars Befring and Wurzacher 2 Link to comment Share on other sites More sharing options...
Babs Posted August 15, 2015 Author Share Posted August 15, 2015 (edited) Some views of the cockpit: To be continued. Edited February 3, 2019 by Babs Change links of pictures. Lars Befring, Wurzacher, Kagemusha and 1 other 4 Link to comment Share on other sites More sharing options...
Wurzacher Posted August 15, 2015 Share Posted August 15, 2015 (edited) Didn´t know Israel had Stearmans, too. I like this silver colour look with the Israeli stars! Is this the SilverWings kit? Edited August 15, 2015 by Wurzacher Link to comment Share on other sites More sharing options...
Babs Posted August 15, 2015 Author Share Posted August 15, 2015 As is said in the title, this is the Silver wings kit.A good kit, pity the Continental engine is not optional for a PT-17 release. Babs Link to comment Share on other sites More sharing options...
LSP_Ron Posted August 15, 2015 Share Posted August 15, 2015 Nice start, I also have this kit, nice to see how it builds up. Link to comment Share on other sites More sharing options...
Babs Posted August 15, 2015 Author Share Posted August 15, 2015 I did not say, I have no experience with biplanes.I'm more jet aircraft. I will do the best possible. Babs Link to comment Share on other sites More sharing options...
Guest Peterpools Posted August 16, 2015 Share Posted August 16, 2015 Babs Very nice start on the Stearman Looking forward to following your progress. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
wrbrdmech Posted August 16, 2015 Share Posted August 16, 2015 Following this build with much excitement! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 16, 2015 Share Posted August 16, 2015 Cool build! Kev Link to comment Share on other sites More sharing options...
Babs Posted August 23, 2015 Author Share Posted August 23, 2015 (edited) Thanks. A little up with the tail section. The rudder is slightly improved with the light at the top and the trim tab. Tailplane and elevator with some details added,trim tab slightly deflected and reinforced passage for cables. Next stage the lower wing. Edited February 3, 2019 by Babs Change links of pictures. Lars Befring and Whitey 2 Link to comment Share on other sites More sharing options...
Azgaron Posted August 23, 2015 Share Posted August 23, 2015 Looking good! Nice work! HÃ¥kan Link to comment Share on other sites More sharing options...
Kagemusha Posted August 23, 2015 Share Posted August 23, 2015 Nice project. Link to comment Share on other sites More sharing options...
Babs Posted November 17, 2015 Author Share Posted November 17, 2015 (edited) Hello, A little update,with the wings and engine cover. Lower wing, a walkway is created on both sides. As well as a inspection cover. Repairing tip because not enough resin injected. The underside of the fuselage, slightly corrected. An antenna is placed, some details below the engine cover are added. A cut is made to adapt the new engine. Edited February 3, 2019 by Babs Whitey and Lars Befring 2 Link to comment Share on other sites More sharing options...
Babs Posted November 17, 2015 Author Share Posted November 17, 2015 (edited) The following: A scope-shaped air intake is redone with a small grid. The left side of the engine cover is a little different than that proposed by the silver wings kit with among others a new cap. Upper wing, added some details and drill the holes for the struts and the flag mast. Hoping that this update is interesting. Thank you. Edited February 3, 2019 by Babs Whitey, Hubert Boillot and Kagemusha 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 17, 2015 Share Posted November 17, 2015 Great to see this one back, and such fine work, too! Kev Babs 1 Link to comment Share on other sites More sharing options...
