FunkyZeit Posted August 12, 2014 Author Share Posted August 12, 2014 (edited) Jolly Roger, yes sir! If you decide you want to make intake covers I suggest you trace the intake before it's glued onto the fuselage. Trace it from the inside to get a rough idea of the size. Trace onto thin plasticard with a pen or whatever works best for you. When you're at the stage to build the cover, cut it on the pen lines and test fit it. I had to trim mine down quite a bit as when the glove is over top, it will eat up a lot of space. Take a nitrile glove (I used green) and cut a oval piece, wrap it around the plasticard and tape it to the back of the card with tamiya tape. Don't worry too much about it being super secure as the inside of the intake will keep positive pressure on the glove. Then cut 2 strip of tamiya tape, one longer than the other. Take the smaller strip and tape it to the back of the longer strip, leaving a small sticky side on each end of the tape, this is your handle. Tape it down however the handle is oriented on your specific aircraft. Use Tamiya "Italian Red" and spray onto the cover. It took 2 coats for me as the paint does not stick well on the glove, be careful of overspray as the paint will run on the glove. Spray a matte coat after and you're all done! Most people use plastic wrap or tin foil to make the cover, I took a chance and used a glove, this may be an original idea, I'm not sure but I hope it comes of use to more people. I modelled it after the 1900 I fly, and thought it looked realistic. If you've ever seen a 16 up close, you can easily fit two full size men into the intake.. Don't ask me how I know so I'd imagine it's just a red painted board. Hope this helps Justin Edited August 12, 2014 by FunkyZeit Jolly Roger 1 Link to comment Share on other sites More sharing options...
Jolly Roger Posted August 12, 2014 Share Posted August 12, 2014 Thank you for that detailed explanation, sounds relatively easy to do and looks perfect. Thanks again! Link to comment Share on other sites More sharing options...
Mr Smith Posted August 12, 2014 Share Posted August 12, 2014 A real warbird !!!! Nice work with the best scheme ! JL Link to comment Share on other sites More sharing options...
joe Posted August 13, 2014 Share Posted August 13, 2014 Beautiful work it looks fantastic. Link to comment Share on other sites More sharing options...
FunkyZeit Posted August 13, 2014 Author Share Posted August 13, 2014 MrSmith , joe - I really appreciate the kind words! Link to comment Share on other sites More sharing options...
FunkyZeit Posted August 13, 2014 Author Share Posted August 13, 2014 Maru - thanks for stopping in, and thank you! Link to comment Share on other sites More sharing options...
ghatherly Posted August 15, 2014 Share Posted August 15, 2014 Very Very Nice! Link to comment Share on other sites More sharing options...
Babs Posted August 15, 2014 Share Posted August 15, 2014 Nice Barak, only as good. Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 15, 2014 Share Posted August 15, 2014 Lovely work! The paint and weathering really bring it alive Link to comment Share on other sites More sharing options...
Bill Cross Posted August 15, 2014 Share Posted August 15, 2014 As the French say, superbe! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 16, 2014 Share Posted August 16, 2014 And here's the article Justin! http://www.largescaleplanes.com/articles/article.php?aid=2123 Kev Link to comment Share on other sites More sharing options...
SinuheH Posted August 16, 2014 Share Posted August 16, 2014 Great work - and absolute stunner - congrats!!!! Now I wonder where Peter and my IAF F-16's are….. Link to comment Share on other sites More sharing options...
FunkyZeit Posted August 16, 2014 Author Share Posted August 16, 2014 (edited) Kev, thanks so much I'm honoured! Gary, babs, Brian , bill, sinuheh.. Thanks so much you guys keep me motivated! Peter said his sufa is back on the bench soon! Edited August 16, 2014 by FunkyZeit Uncarina 1 Link to comment Share on other sites More sharing options...
