Hubert Boillot Posted February 8, 2014 Posted February 8, 2014 (edited) The T2 Buckeye was conceived as an adanced jet trainer for the US Navy, on a 1956 requirement that called for an aircraft able to train the new pilots to the specificities of jets and to qualify them for carriers. North-American's offer was chosen to build this new trainer, designated the T2J-1. It thus followed a long line of trainers developed by NAA for the US Navy, starting with the SNJ-1 (T-6) and continuing with the T-28. In some aspects, the T-2 was en evolution rather than a completely new airframe, using for instance the wing of the FJ-1 Fury, or the control systems of the T-28C, boosted by a new hydraulic system. The first YTJ-2 flew in january 1958 (almost exactly 56 years ago), and the first production trainer was delivered in 1959, becoming the « Buckeye » at that time. Although capable, the single-engined T-2A was underpowered, and in 1962, the T-2B prototype with two J-60 engine made its first flight. It was then replaced in 1968 with the T-2C, powered by 2 GE J-85 engines, of which 231 were built. In 1972, Venezuela ordered 12 de-navalised T-2Cs for the training/strike role, with wing stations for up to 3500 lbs of ordnance. In 1976, Greece acquired 40 T-2Es, generally similar, but for the avioncs suite, to the Venezuelan T-2Cs. Besides my overall preference for non too-military (?) aircrafts, I have always loved the look of the T-2, and longed for a kit of it in a « decent »scale. For many years, the only kit available was the 1/72 Matchbox one. I believe, although I am not too sure, that Collect'Aire offered one in resin in 1/48 th sacle. Then, about 3 years ago, Two Bobs, known for their decals' sets, announced a 1/48th scale T-2C in injected plastic, which was subcontracted to the Czech company Special Hobby as a short run kit. Initially well received, it was then criticised for a somewhat average fit, which could have been expected for a short-run injected plastic kit. The production was then reissued by Special Hobby, under its own label. It is therefore not a complete surprise that Special Hobby capitalised on their 1/48th scale development to catch the train of growing 1/32 kits' demand and be the first to release a 1/32 scale kit of the T-2C, to be followed by an Greek T-2E version. Announced last year, the first pics of the model appeared in the wake of the Nürnberg toy fair end February. The availability of the kit was then announced on MPM/Special Hobby/CMK's e-shop site on February the 1st. I ordered mine on the 2nd (49,90 € + 6,63 € P&P) and received it (in France) on the 6th ! Not bad ! So here are the photos and first impressions after opening the box. The box is a sturdy 46 x26 x 8 cms (18 x 10,5 x 3,2 inches) two-part cardboard box. The boxart is similar the 1/48th scale previous release. Inside the box, you have 7 sprues of parts in injected grey plastic, plus a sprue for the two fuselage halves, bagged in a resealable plastic bag. The transparant canopy is bagged separately, as is another small sprue with the winscreen and the other small transparent parts (lights for the wingtips for instance). This is complemented by two resin ejector seats in a small bag, and another small bag of resin small details (main gear doors retraction links, inside of airbrakes wells, etc.) The decla sheet is in two parts, offering markings for 3 red and white T-2Cs, two for the US Navy, of which one with a shrkmouth on the nose, and one for the US Marines. The instrument panels are also represented on the decal sheet, as well as a comprehensive host of stencils. This is completed by a 16 pages instruction booklet in A5 format, with 39 building steps. I have counted 214 parts (give or take +/- 2 as I have not done a recounting), of which 12 transparent ones and 17 in resin. Some parts are on the sprues for the future T-2E version and should not be used. The first impression is very good, with very fine surface detail, both finely engraved recessed panel lines and flush rivets, and raised panels where necessary. The quality of the engraving is very good, and close to the best you can expect nowadays. The kits is molded with all flying and moving surfaces (flaps, ailerons, rudder, elevators) molded separately. It also features full length intakes (each split in two vertical halves) for the jet engines, ending on a bulkhead with front fan faces. The intake trunks have the correct curved shape. There is also a bulkhead with the exhaust turbines, to which the two tailpipes (each molded in two halves), of apparently the right length, are fixed. The inside structure of the main gear wheel wells is correctly represented, although I am sure some will want to add more details. This wells are only marred by ejectors marks. Fortunately, those are protruding, and can be removed with a small chisel. Filling them in the middle of the detailed ribs' structure would have been more difficult. To be continued on the next post (limited by the number of pics I can post) ... Edited February 8, 2014 by LSP_Kevin Iain 1
Hubert Boillot Posted February 8, 2014 Author Posted February 8, 2014 (edited) The cockpit is nicely represented, with the instrument panels featuring some nicely engraved detail (to the point where I doubt the decals will be able to fit the panels, even with plenty of decal softener). The back of rear instrument panel features the raised instruments, requiring only some cabling for enhanced realism. The rudder pedals are there as well, each individually represented, and the side consoles are moulded with relief details (and separate throttles), although my first impression there was that the detail was a bit soft (and on top of it, I managed to blurr the photo ! ). Careful painting should however do justice to this representation. The side walls of the cockpit have some recessed ejector-pins marks, which should be easy to fill. The « pièce de résistance » of the cockpit are the two resin-molded ejection seats, with very fine details and molded-on harness. I initially felt their proportions (length vs height) were strange, but a rapid look at my available documentation seemed to indicate that SH have done their homework correctly on the subject. The wheels are correctly detailed. I did a very rapid first check of mating the two fuselage halves. The fit, always a delicate issue with Spcial Hobby kits, seems OK, although I could already see that the bottom panel will need some trimming to fit between the two fuselage halves. The wing to fuselage joints appears correct as well, but may require a small dab of filler, nothing to worry about. One potential area of trouble is the jet intakes. Each is represented with 5 parts : two inside trunk halves, two exernal intake halves, completed by a one-piece lip. On some previous SH kits, like the F-80, the fit in this area was ranging from difficult to horrible. I have not tried the fit of the intakes for the T-2C, so cannot prejudge whether this will be a difficult area or not. I just know I will do a lot of dry fitting beforehand, just to be sure everything falls together with minimum filling and sanding. The front gear well is correctly represented, including the rounded rear part that protrudes in the front cockpit. The front gear is also well represented with its leg slightly offset from the center line, as on the real aircraft. The transparent parts, including the windscreen and the huge canopy are thin and very clear, thus enabling a good view on the cockpit, even if you decide to close the canopy. Be careful when manipulating these parts. When I cut the front pouring stub of the canopy to test its fit, I induce a small fatigue crack in the clear plastic. The resin details are very fine, to the point of being fragile. I broke one of the main gear links when putting them back in their bags after making photos. The decal sheet is printed in register, which is a good point. The stencils, although the texts are correct – not always the case on some kits – lack finesse, and the printing of the decals could have been done slightly better, resulting in smaller and finer print for the stencils' texts, and less wavy straight lines. But this is a remark done with my personal professional background in this field, and after I used a 5x magnifying linen-tester. Most will be very happy with what they see. Continuing and concluding in the next post ... Edited February 8, 2014 by MostlyRacers Iain and Derek B 2
Hubert Boillot Posted February 8, 2014 Author Posted February 8, 2014 (edited) A quick accuracy first check. I compared the kit with only one set of drawings, the (almost) 1/72 drawings published in the Steve Ginter #15 Naval fighters, which I blew to 1/32 on a photocopier (which in itself may induce some distortions). I have not checked whether these drawings are themselves accurate, nor have I compared them to other drawings. So any comparison with the drawings must at this stage be taken with a grain of salt. Just to reinforce the « caution » message, the top and bottom plan view of the wings do not exactly match on the drawings. Anyway, the kit compares favorably in both length, span and height with the published dimensions. The side profile checks almost 100 % with the mentioned drawings. The plan view of the kit's wings appear definitely smaller than the drawings, being narrower in chrod, and with a much smaller leading edge apex. As long as I have not found factory dimensions on the true chord of the wing, I cannot say which is right, between the Ginter drawings or the SH kit. Overall though the shapes of the original seem to have been captured, and be a VERY decent scale representation of the original, but for one area wich bears further investigation from my part : The canopy question When I first saw the Nürnberg pics, I thought the canopy looked strangely flattened. Compared to the drawings, here are my first comments: the length and height of both the windscreen and the canopy are consistent with the drawings. The complex shape of the windscreen to fuselage fairing is not completely faitfully represented. If one area of the canopy is to be questioned, it is in terms of width. Compared to the drawings, both the windscreen and the canopy seem about 2 mm too wide, and this may cause the « flattened" first impression. However, as long as some check against direct, or factory, measurements of the real parts has not been done, I cannot affirm with certainty that SH's canopy is wrong. If you have more elements please feel free to add to the comments. Conclusion I was really excited to see a 1/32 kit of the T-2C Buckeye being issued. The overall impression is thatt SH have produced a very good kit, very close to the best standards of the industry. It is very finely detailed, and engraved, and will result in a great looking representation of the T-2C, at a price which remains reasonable for a 1/32 kit. In my view, having many 1/32 Special Hobby kits in my stash, and having seen the building threads of some, the T-2C is probably their best kit to date. Of course, this needs to be confirmed by the actual buildling of the kit, but the first impression is that the fit problems so often associated with these short-run kits should be less present with this new release. The only shortfalls this preliminary review has highlighted are the finesse of the stencils decals, and a question mark about the windscreen/canopy width. All in all, I believe we have a winner here, and my personal opinion is a warm recommendation. Review model courtesy of my wallet. Hubert PS: Sorry that some pics appear rotated 90°. I edited them on PB, but yet they appear this way on the pcitures' links Edits are for my (usual) typos ... Edited February 8, 2014 by MostlyRacers Iain, Derek B, D.B. Andrus and 3 others 6
Iain Posted February 8, 2014 Posted February 8, 2014 Brilliant - thanks Hubert - I think you've just made my decision for me - looks like their best yet! Iain
Guest Peterpools Posted February 8, 2014 Posted February 8, 2014 Hubert Awesome review and sure looks like another must buy. Now, where is all the cash going to come from? Peter
pzcreations Posted February 8, 2014 Posted February 8, 2014 (edited) thankyou..I will certainly be ordering myself one when they reach the states. also wondering about the tires..they look kinda toyish..are they suppose to look that way? Edited February 8, 2014 by pzcreations
Hubert Boillot Posted February 8, 2014 Author Posted February 8, 2014 thankyou..I will certainly be ordering myself one when they reach the states. also wondering about the tires..they look kinda toyish..are they suppose to look that way? As usual, resin replacements could achieve finer results. As for the tires, they were low profile, thin, high pressure elements, mounted on fairly large wheels. I am still chasing some more detailed constructor specs to verify some dimensions. I anyone has a maintenance manual, I'm a taker ... Hubert.
mark31 Posted February 8, 2014 Posted February 8, 2014 thanks for the revieuw. Now know where to look for at the next convention. my poor wallet. Mark
jozef Posted February 8, 2014 Posted February 8, 2014 Thank you a lot for your efforts, Hubert. Really good news. Jozef
Guest Posted February 8, 2014 Posted February 8, 2014 I have been "on the fence" about this one, but thanks to you, leaning a bit more to getting it.........Harv
SinuheH Posted February 8, 2014 Posted February 8, 2014 Looks like a great kit…. hope to see more early jets by SH in this scale. Dream choices would be: MB 326 Narrow wing F-86 sabre F-86K…. Ouragan…. sigh…..
SinuheH Posted February 8, 2014 Posted February 8, 2014 Nice to see that they are also catering for an eggplane version…. D.B. Andrus and LSP_K2 2
Kagemusha Posted February 8, 2014 Posted February 8, 2014 Thanks Hubert, patiently waiting for Hannants to get it in stock...
Hubert Boillot Posted February 8, 2014 Author Posted February 8, 2014 Nice to see that they are also catering for an eggplane version…. I was wondering if it was my iPad ... Need to check what PB's editor did to the original pics ... Hubert SinuheH 1
Hubert Boillot Posted February 8, 2014 Author Posted February 8, 2014 Well, it's even weirder on my computer screen ... The pics are not deformed, but they keep the original orientation. On the iPad, they are rotated but with an "eggplane" look. Definitely something to do with Photobucket's image editor ... Tell me what you see guys, because I do not know anymore what I should see ... Hubert.
