Out2gtcha Posted September 16, 2014 Share Posted September 16, 2014 Simply LOVELY! Any chance of showing a bit of the assembled/finished pit Glenn? Link to comment Share on other sites More sharing options...
alaninaustria Posted September 16, 2014 Share Posted September 16, 2014 Glen, only one observation.... Aren't the PE parts on top of the wings supossed to be 90 degrees to the shown position... Here they look like airbrakes where in actuality they are parallel to the airflow and are wing fences to keep airflow streamlined over the rear of the wing?? Please let us know! Cheers Alan Link to comment Share on other sites More sharing options...
Youngtiger1 Posted September 16, 2014 Share Posted September 16, 2014 Wow, that is some serious modeling porn I'm looking at. Glen, your a bad man for making me watch it Link to comment Share on other sites More sharing options...
Magic Mike Posted September 16, 2014 Share Posted September 16, 2014 MUST....HAVE...NOW!!!!!! MM Link to comment Share on other sites More sharing options...
RNoAF Posted September 16, 2014 Share Posted September 16, 2014 Are there some aftermarket decals on the way? Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted September 17, 2014 Share Posted September 17, 2014 (edited) Alan The model is right They are roll spoilers. They are connected to the ailerons so only one set should be up at a time. Like on the P-61 Black Widow Glen, only one observation.... Aren't the PE parts on top of the wings supossed to be 90 degrees to the shown position... Here they look like airbrakes where in actuality they are parallel to the airflow and are wing fences to keep airflow streamlined over the rear of the wing?? Please let us know!CheersAlan You can see the slots in the top of the wing in these link https://www.google.com/search?q=ov-10+bronco+wing&biw=1708&bih=761&source=lnms&tbm=isch&sa=X&ei=jiQZVLmBAsH6iwKG14CwDw&ved=0CAYQ_AUoAQ&dpr=0.8#tbm=isch&q=ov-10+bronco+&facrc=_&imgdii=_&imgrc=6bVnxXVv00UpWM%253A%3BMXM-Jtyesu1gJM%3Bhttp%253A%252F%252Fwww.ov-10bronco.net%252FPix%252FOBA%252FGermanWing%252Fov-10b_bronco_crash_kemble_uk_2012-07-10_01.jpg%3Bhttp%253A%252F%252Fwww.ov-10bronco.net%252F%3B480%3B360 Cheers Edited September 17, 2014 by Vandy 1 VX 4 Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 17, 2014 Share Posted September 17, 2014 Alan The model is right They are roll spoilers. They are connected to the ailerons so only one set should be up at a time. Like on the P-61 Black Widow You can see the slots in the top of the wing in these link https://www.google.com/search?q=ov-10+bronco+wing&biw=1708&bih=761&source=lnms&tbm=isch&sa=X&ei=jiQZVLmBAsH6iwKG14CwDw&ved=0CAYQ_AUoAQ&dpr=0.8#tbm=isch&q=ov-10+bronco+&facrc=_&imgdii=_&imgrc=6bVnxXVv00UpWM%253A%3BMXM-Jtyesu1gJM%3Bhttp%253A%252F%252Fwww.ov-10bronco.net%252FPix%252FOBA%252FGermanWing%252Fov-10b_bronco_crash_kemble_uk_2012-07-10_01.jpg%3Bhttp%253A%252F%252Fwww.ov-10bronco.net%252F%3B480%3B360 Cheers Indeed they are. Vandy is correct, as you will normally not see them deployed at all while parked if flying surfaces are in the neutral position. Link to comment Share on other sites More sharing options...
alaninaustria Posted September 17, 2014 Share Posted September 17, 2014 Thanks for clarifying that guys!! This is an awesome looking kit -I'll be getting a few of them for sure!! Cheers Alan Out2gtcha 1 Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted September 21, 2014 Share Posted September 21, 2014 (edited) $79.99, due mid Oct.! KittyHawk introduces their newest 1:32 scale kit, the USAF OV-10D "Bronco" light attack/FAC aircraft (KH 32003). This kit is certain to be popular with all the fans of 1:32 scale aircraft and especially USAF aircraft. Many modelers have personal experience with this aircraft. It is complete with a full interior, weapons load and engine detail. The retail price is $79.95 http://www.pacmodelscatalog.com/mm5/merchant.mvc?Screen=PROD&Store_Code=PCM&Product_Code=KH+32003&Category_Code=KH+132 Cheers Edited September 21, 2014 by Vandy 1 VX 4 Harold, Daniel Leduc and Out2gtcha 3 Link to comment Share on other sites More sharing options...
Timmy! Posted September 21, 2014 Share Posted September 21, 2014 Indeed they are. Vandy is correct, as you will normally not see them deployed at all while parked if flying surfaces are in the neutral position. Actually no. The control lock, is a strap that wraps around the stick and connects to the right canopy sill that pulls the stick to the right aft corner of travel. So the with the locks installed you'll see the right aileron full up and full up elevator. Further there are split trim tabs on all three surfaces, ailerons and elevator. One section of the tab is directly connoted to the main surfaces and causes the that portion of the tab to move opposite the surface. The other section of the tab is pilot controlled. Timmy! Link to comment Share on other sites More sharing options...
Radders Posted September 23, 2014 Share Posted September 23, 2014 That looks, fantastic. Properly stunning....! What's next from the KH factory?? Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 23, 2014 Share Posted September 23, 2014 (edited) Actually no. The control lock, is a strap that wraps around the stick and connects to the right canopy sill that pulls the stick to the right aft corner of travel. So the with the locks installed you'll see the right aileron full up and full up elevator. True. However what I was referencing was the fact that almost every one of the later OV-10s I have climbed around of do not seem have the locks engaged, and some like the fire-bombers and one German demonstrator I found dont seem have the locks installed at all and/or have the controls resting completely neutral, thus not letting any of the spoilers show- Edited September 23, 2014 by Out2gtcha Vandy 1 VX 4 1 Link to comment Share on other sites More sharing options...
Timmy! Posted September 23, 2014 Share Posted September 23, 2014 And you sir are correct as well, I don't think it understood your post completely. The spoilers are mechanically connected to the ailerons so if they are in a neutral position then no spoilers would be showing. I am a little biased as the one I built was a Marine bird and as such, the Marine OV-10s would nearly always be seen with the control locks installed. All that aside, personally I think the surfaces displaced on a model adds interest...but there is a right way and a wrong way to do it; which is what you were onto from the beginning. Cheers, Timmy! Harold and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 23, 2014 Share Posted September 23, 2014 All that aside, personally I think the surfaces displaced on a model adds interest...but there is a right way and a wrong way to do it; which is what you were onto from the beginning. I really agree with that! I also think the additions of said spoilers in PE adds all the more realism. I do like the visual interest adding the locks engaged would add as well. Vandy 1 VX 4 and Harold 2 Link to comment Share on other sites More sharing options...
hostage312 Posted May 14, 2015 Share Posted May 14, 2015 Well gents I can comment all day long about marine ov-10s spoilers left up was a no no might get bent or broken when refueling just purchased a d bird now waiting on the alpha birds oorah! Out2gtcha 1 Link to comment Share on other sites More sharing options...
