As per the title! I got a set of lovely ResKit wheels for my 1:24 Mossie, but there doesn't seem to be an obvious way (to a numbskull like me) to remove them without having to do some fairly heavy remedial work post-removal?
Here's one of the wheels in question..
Any suggestions from you clever modelling folk?
Pretty much what Mozart said. Have this area facing the ground, to hide it as much as possible. If you can re-scribe a new tread-pattern in this section that's convincing, then you are a MUCH better modeller than me. Other opinions may differ on the matter...
Good luck.
Chris.
A litle bit of light sanding (not too much!) the tread all round the circumference won't hurt anyway: tyres wear irl, especially aircraft tyres - all those landings ...
Got several sets for different aircraft.
The process is the same- razor saw off the thick stub, then use a razor blade to trim off the thin stub left over.
Finally clean up with a fine sanding stick.
Voila.
Oh- and good luck.
