40 -
Everything posted by AdAstraMasks
Barry, You do not have to purchase 3 sets of masks for the markings that you require. We can provide a custom mask set of roundels, fin flashes and codes plus masks and/or decals for the ROYAL NAVY and serial number for your Martlet III. Our cost for simple custom sets such as this is US$10.00 plus shipping and handling. Please send us an e-mail at this address if you are interested. Best regards, Ian
Tim, John is correct, in addition to vinyl paint masks we can also provide custom colour laser and ALPS printed decals. Lou, we will be delighted to assist you by providing the decals you require. Please e-mail us at this address if you are interested. Best regards, Ian
Hi Picard, We can certainly help you out with both the font and masks. Please send us an e-mail at this e-mail address if you are interested. Best regards, Ian
John, We would be delighted to make you a set of masks for any He-111 markings you require. Please send us an e-mail if you are interested. Best regards, Ian
Hi Collin, We will be delighted to assist you. Please drop me a P.M. or an e-mail at this address and we will be happy to provide you with the markings that you require. Best regards, Ian
Deigs, The masks were originally custom designed for Matt and are not yet on our website. However, if you are interested in a set please send us an e-mail, at this address, and we will be delighted to supply a set to you. Best regards, Ian
Hi TENCH, We would be delighted to supply you with paint masks for those markings. Please send us an e-mail at this address if you are interested. Best regards, Ian
Indeed we could Ron, but we would do the kill markings as decals Al if you are interested please send an e-mail to us at this e-mail address and we will be happy to assist you. Best regards, Ian
LSP Decals , Can you still Get Them ?
AdAstraMasks replied to keith in the uk's topic in LSP Discussion
Keith, We would be delighted to make custom masks/decals for any Mosquito scheme you wish to model. Please send an e-mail to us at this address with your reqiuirements if you are interested. Best regards, Ian -
Guy, We would be very happy to make a set of custom masks/decals of this scheme for you. Please e-mail us at this e-mail address if you are interested. Best regards, Ian
Hi Wolf, We are located a little south and east of Montreal, Quebec. Best regards, Ian
Hi Wolf, We would be very happy to assist you with any of your masking needs. Best regards, Ian
Hi Shane, We'd be delighted to make a set of custom masks of this scheme for you. Please send me an e-mail at this address if you are interested. Best regards, Ian
Geoff, My apologies, there was a typo in the e-mail address of my post above which has now been corrected. @Brian - you are too kind, thank you! Your support is greatly appreciated. Best regards, Ian
Hi Geoff, Have you considered using paint masks for the large markings instead of decals? We can provide you with masks for any scheme you wish. For items that are too small for viable masks we can also offer custom printed decals. If you are interested please e-mail us here Best regards, Ian
3./KG77 unit insignia - anyone make decals for this?
AdAstraMasks replied to nmayhew's topic in LSP Discussion
Hi Nick, We will include two options to achieve the markings :- 1. Masks for the shields and Eule text with a decal overlay for the scroll and eagle 2. Decals for shield (including the eagle), scroll and Eule text This approach will ensure that the colours are consistent between the shield and the Eule text. I'll search our limited Ju-88 references to see if I can unearth some details of this aircraft for you. Best regards, Ian -
Ross. That's a nice scheme - we'd be very happy to do paint masks for you for that scheme. Send us an e-mail at this address if you are interested. Best regards, Ian
Nick, We have designed the artwork for the 3./KG77 insignia you require (Shield, ribbon with text and Eule text). We can supply this as a mask and/or decal and will of course will include it with masks for the other markings (national insignia, codes) on this aircraft. Best regards, Ian -
Ron, I think that the method you have described will work but involves a lot of work and some unnecessary steps. Here is how I recommend you approach the masking & painting:- As the real aircraft was sprayed (High Speed) silver I assume that you will be using Alclad Aluminium and not one of the "high shine" shades (Chrome, Polished and Airframe Aluminium) so a gloss black primer coat is not required as Phil mentioned. Prime model using your primer of choice (I use Alclad grey primer which is wonderful stuff) Spray model with Alcad Aluminium Apply masks for roundels, serials Sqn leader pennant and fin flashes Spray masked markings per instuctions replacing the blue mask elements of the roundels on model when the blue paint is dry/cured. Remove outer roundel masks leaving the roundel masks in place (totally covering the painted roundels) Apply red stripe masks Remove the white mask element of the Cross of Lorraine marking and spray the white of this marking replacing white mask element when the white paint is dry/cured Remove the red elements of the stripe and badge markings from the model Spray the red over the Alclad Aluminium (the silver will provide a perfectly good base coat for the red) Remove masking when red paint is dry. Regarding the "sandwich" effect mentioned by Johan and Phil - this is a common problem with masks that are misaligned when applied or re-applied to the model. The method we outline in our instructions (applying the complete mask to the model and removing the lightest colour element, spraying and then replacing the mask element before removing the mask element for the next colour) eliminates this issue because the mask alignment is maintained at all times during the masking/painting process. To use Phil's "Blue Peter" flag on his superb Hurricane to illustrate my point (I hope that you don't mind Phil) - There would have been no white border to the flag if Phil had applied the whole mask and then removed only the white element, sprayed the white portion and replaced the white mask element before removing the blue mask element and spraying the blue. I hope that the above helps Ron and anyone else using masks. Best regards, Ian
Ron, We'd be very happy to do masks for this scheme (or any other) for you. We have all the necessary details as another client requires a mask set for this scheme in 1/24th scale. Please send an e-mail to this address if you are interested. Best regards, Ian
James, As Nick said we'd be happy to make you masks for these scheme. If you are interested drop us an e-mail at this address. Best regards, Ian
Masks for the Tornado F.3 Retirement Scheme rolled out at Leuchars yesterday (4th March) are now available in 1/48th and 1/32nd scales on our website. Ian
We have updated our website with two new product introductions:- RAF/FAA MARKINGS Supermarine Spitfire • Spitfire Mk. VIII – 43 Sqn, France 1944 • Spitfire Mk.1 – Battle of Britain, 610 Sqn – August 1940 We hope that you like our new products and we welcome any suggestions that you have for future products. Please let us know what you want to see and we’ll incorporate your needs into our product development and release programme. Ian
We have updated our website and introduced some new products to our range. The new products introduced in this update are:- RAF/FAA MARKINGS DeHavilland Mosquito • Mosquito FB.VI - BOAC Livery • Mosquito FB.VI - Post War Republic P-47 Thunderbolt • P47D-30-RE Thunderbolt Mk.II - SEAC Markings Supermarine Spitfire • Spitfire VIII - SEAC Markings US MARKINGS Republic P-47 Thunderbolt • P47M Thunderbolt - 63rd FS, 56th FG, 8th AF - 4421112, UN-Z - George Bostwick GERMAN MARKINGS Junkers Ju88 • Junkers Ju88D-2 - F6+CN Russian Front - 1942-43 Messerschmitt Bf109 • Messerschmitt Bf109F-4 Trop - Yellow 14 (Red Rudder) - Hans Joachim Marseilles We are also adding 4 view profiles of each scheme to all of our product descriptions:- We have also added a Customer Feedback section containing comments and feedback received from our customers about our products. We'll be adding a Customer Builds section in the next update to showcase models made by our customers which have been painted using our masks. Finally for this update, we've added a Product Reviews section containing reviews of our products which have been published in printed and on-line magazines. We hope that you like our new products and we welcome any suggestions that you have for future products. Please let us know what you want to see and we’ll incorporate your needs into our product development and release programme. Ian
