LSP_K2 Posted September 14, 2016 Author Share Posted September 14, 2016 Spare the very end of the pipe, would the other pin marks even be visible? I wouldn't make more work than necessary out of it, but I understand the frustration, too! Great start, Kev. Looking forward to watching this one. John And speaking of the exhaust end tip, it's as wrong as it can possibly be; too "thick and chunky", though it does have a slight taper on the outside, which is correct, end is squared off and blunt, whereas it should be rounded off significantly. None of these things are deal breakers to me, and I won't rail against Trump for it like some others might do, but the whole area will require some thought. Also, the aft fuselage areas, are as smooth as silk, so some ribbing and formers will need to be added, as it would certainly look odd without them. Shawn M 1 Link to comment Share on other sites More sharing options...
Shawn M Posted September 14, 2016 Share Posted September 14, 2016 yeah, the box is miselading in regards to the canopy. Correct for the UTI but not the BIS Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 14, 2016 Author Share Posted September 14, 2016 OK, the long OOP CE splitter plate arrived today, compliments of a forum friend. Thanks a bunch, you're awesome. jgrease and Zero77 2 Link to comment Share on other sites More sharing options...
Guest Posted September 14, 2016 Share Posted September 14, 2016 Yep, thats it !......Harv Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 14, 2016 Author Share Posted September 14, 2016 And these are going to be a great addition. They're outstanding, just gorgeous. Shawn M, mywifehatesmodels, Telepatu and 1 other 4 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted September 14, 2016 Share Posted September 14, 2016 Kev Enjoying the start of the Mig project ... going to a nice journey to follow and learn from Keep 'em coming Peter Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 15, 2016 Author Share Posted September 15, 2016 Keeping things moving along, I've went ahead and glued the front and rear fuselage halves together, These will be reinforced on the inside, then puttied and cleaned up. I also photographed the BB 'pit set today (twice!), so I can now begin fitting that stuff up, and hopefully get on with some painting. blackbetty, dutik, Zero77 and 2 others 5 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted September 15, 2016 Share Posted September 15, 2016 Great start Kev! Looking forward to seeing this finished! Link to comment Share on other sites More sharing options...
blackbetty Posted September 15, 2016 Share Posted September 15, 2016 you will have a fun time fitting the wings to the fuse.....i sure know i did Link to comment Share on other sites More sharing options...
Shawn M Posted September 15, 2016 Share Posted September 15, 2016 Kev, any chance you could do a side by side of the kit splitter versus the CE unit? I too have the master barrel set and they are breathe taking! Also come with replacement ant. base. I was going to follow the same main sequence you are as well, join the fuse halves (per side) then mate together. Seemed like less chance of gaps/mis alignment Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 15, 2016 Author Share Posted September 15, 2016 Kev, any chance you could do a side by side of the kit splitter versus the CE unit? Sure, I can do that this afternoon, hopefully. Shawn M 1 Link to comment Share on other sites More sharing options...
Shawn M Posted September 15, 2016 Share Posted September 15, 2016 thks, wondering how far "off" the kit bit is. How are you going to tackle the intake? Found this build with a "decent" solution. http://www.hyperscale.com/features/2000/mig15mh_1.htm Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 15, 2016 Author Share Posted September 15, 2016 I don't think the kit part is off so much, as that it's just too shallow, front to back. Shawn M 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 15, 2016 Author Share Posted September 15, 2016 Here you go, Shawn. The CE piece, as can be clearly seen, is substantially deeper, front to back, though basically just a knock off of the Trump part, with nose gear well molded integral. Still will save me some work though, and that's a good thing. Shawn M and Zero77 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 16, 2016 Author Share Posted September 16, 2016 Owing to a nice gift from our own Shawn, I now have some P.E. to play with. One of the very noticeable things missing from the BB 'pit, are the two red handles that flank the IP. Thanks to Shawn, I can now add those. Shawn M, mywifehatesmodels and Zero77 3 Link to comment Share on other sites More sharing options...
