Tolga ULGUR Posted September 25, 2017 Author Share Posted September 25, 2017 On the other hand Cockpit parts are painted and ready to be joined Kendzior, Martinnfb, sandokan and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Vincent Posted September 25, 2017 Share Posted September 25, 2017 Aaahh. "Wish you were here" before Vincent. Well, I see what you mean, yes you are right .Front alignment of the windscreen is 2 or 3 mm behind on the fuselage If I moved the windscreen to forward, fitting of the rear part canopy will have problem. It needs to use windscreen and canopy parts separately. And in this option, the gap between the windscreen and opened sliding canopy will be increased. So my options are: 1- Finding a separate Hasegawa windscreen, and re worked the overlap area of the windscreen, at least 1 or 1,5 mm forward. Thus error portion will be reduced. 2- To continue as it is by using the drug of "it is just 2 mm behind not too much" 3- And stopping the project Waiting for your suggestions. Hard to tell I would personnally correct the Trumpeter windshield then vacform a new one over the modified part... On a side note, contrary to what many people suggested in the past years, i would rather go with a Trumpeter kit than with the Hasegawa one... Vincent Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 25, 2017 Author Share Posted September 25, 2017 Hard to tell I would personnally correct the Trumpeter windshield then vacform a new one over the modified part... On a side note, contrary to what many people suggested in the past years, i would rather go with a Trumpeter kit than with the Hasegawa one... Vincent If I am not wrong, all the vacuform canopies in 1/32 scale are made for Hasegawa kit, and also I do not like to work with vacuform canopies, I think it's not my way So I will try to move 1 or 2 mm forward actual Hasegawa windshield. It needs some work of course. Thanks for the advice.. Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted October 1, 2017 Author Share Posted October 1, 2017 Cockpit terminated. Martinnfb, AlexM, Uncarina and 5 others 8 Link to comment Share on other sites More sharing options...
Guest Posted October 1, 2017 Share Posted October 1, 2017 Excellent !!....Harv Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted October 2, 2017 Author Share Posted October 2, 2017 Excellent !!....Harv Thanks Harvey Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted October 23, 2017 Author Share Posted October 23, 2017 Some progress. Before installation of the cockpit into the fuselage, I decided to do some works to shift windscreen forward. It seems that windscreen is 2 or 3 mm backwards. As a result of these works on windshield fitting area, it was shifted forward by 1.5 or 2 mm. Although the current position is not entirely correct ( still 1 mm backward) I think I can live and continue with this LSP_Kevin, jgrease, sandokan and 3 others 6 Link to comment Share on other sites More sharing options...
dennismcc Posted October 23, 2017 Share Posted October 23, 2017 What a pain, just when you think you've go it cracked you have to start out afresh, but I'm glad you persevered and did not waste the time and work that you have out into it. Cheers Dennis Martinnfb and Tolga ULGUR 2 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted October 24, 2017 Author Share Posted October 24, 2017 What a pain, just when you think you've go it cracked you have to start out afresh, but I'm glad you persevered and did not waste the time and work that you have out into it. Cheers Dennis Thank you Dennis. Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted October 24, 2017 Author Share Posted October 24, 2017 Fuselage halves are ready to be glued sandokan and Martinnfb 2 Link to comment Share on other sites More sharing options...
Martinnfb Posted October 26, 2017 Share Posted October 26, 2017 Tolga , nice work as usually . Just one note, before you put the seat in, The seatbelt supposed to go over the bar behind the seat, otherwise they would slip in on the floor. Please check the picture below. Cheers Martin Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted October 27, 2017 Author Share Posted October 27, 2017 Tolga , nice work as usually . Just one note, before you put the seat in, The seatbelt supposed to go over the bar behind the seat, otherwise they would slip in on the floor. Please check the picture below. Cheers Martin Thanks for the warning Martin Seatbelts already glued to the back of the seat. I will try to fix the seatbelts without damaging them If I can not, noted for the next projects Martinnfb 1 Link to comment Share on other sites More sharing options...
nmayhew Posted December 17, 2017 Share Posted December 17, 2017 Hi Is there any update on this project? I was learning a lot! Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted December 17, 2017 Author Share Posted December 17, 2017 Hi Is there any update on this project? I was learning a lot! Yes I took a break in this project for a while I started again last week. I am working on the wings. I will post some pictures soon Thanks for your interest Vandy 1 VX 4, RLWP, Kagemusha and 1 other 4 Link to comment Share on other sites More sharing options...
Kendzior Posted December 17, 2017 Share Posted December 17, 2017 [...] So my options are: 1- Finding a separate Hasegawa windscreen, and re worked the overlap area of the windscreen, at least 1 or 1,5 mm forward. Thus error portion will be reduced. 2- To continue as it is by using the drug of "it is just 2 mm behind not too much" 3- And stopping the project Waiting for your suggestions. Vote for option #2! Best regards Hubert Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
