FunkyZeit Posted January 13, 2014 Author Share Posted January 13, 2014 (edited) Quick update: I did some work in the pit.. I'm really not good at all painting the pit details, I like to cheat and use PE.... I'm going to slightly darken down the pit and spice up the driver. I think I can make the PE seatbelts in the kit work, If not, the tamiya f-16 belts look to be long enough. To create the pilot I used a Tamiya f-4J pilot, with some modifications to their wrists to make it look like the pilot was holding the controls / throttle. After much speculation, i'll be building a late CF-104 in metal, with the new Leading Edge Decals that Ron just reviewed. Thanks so much for all the help guys! Criticisms welcome. Funky Edited January 13, 2014 by FunkyZeit SinuheH 1 Link to comment Share on other sites More sharing options...
ScoobyDoo Posted January 13, 2014 Share Posted January 13, 2014 You'll need to change the helmet on that pilot, there is a resin 1/32 pilot that has the correct style helmet. I will have to look it up though to see who makes it. Silver 104s did fly with the gun after the nuke strike role was ended. Link to comment Share on other sites More sharing options...
FunkyZeit Posted January 13, 2014 Author Share Posted January 13, 2014 (edited) Sure let me know what you find I don't need a helmet just yet. I did some more research and I decided to do some plastic surgery.. I sanded off some of the straps and scribbled on with a tiny black sharpie where the extra details should be... http://www.flightgear.ch/Other_CAF_DH_41_2/other_caf_DH_41_2.htm Modified Side Non-Modified Side Ideas, comments?? Edited January 13, 2014 by FunkyZeit Link to comment Share on other sites More sharing options...
Guest Jessie_C Posted January 13, 2014 Share Posted January 13, 2014 The bottom edge of the visor went straight across rather than coming to a point like the US helmets did. The ear cups were slightly inset and not part of the outer shell. I think that's what you've got your cross-hatching for. 104 drivers didn't wear a survival vest covered with pockets, wearing an orange Mae West instead. Here's your typical flight suit and jacket. The Mae West is on the bottom of that helmet page you linked to. It had a "keyhole" collar that went right around the pilot's neck so that when inflated it supported the back of his head. Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 13, 2014 Share Posted January 13, 2014 Funky Nice work on the front office and working the pilots 'head and helmet' into RCAF style. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
FunkyZeit Posted January 13, 2014 Author Share Posted January 13, 2014 (edited) Super frustrating part of the build.. The kit has no pilot and the belts werent made to fit the pilot... slowly getting there,,, Made a life vest out of masking tap... it's a simple design that I'm looking to get somewhere close to what they actually look like.. I've scoured the internet and there isn't a RCAF pilot that will work for this machine.. The pilot has a nice dry brush to make the details pop but my tiny iphone doesnt want to pick it up. Funky Edited January 13, 2014 by FunkyZeit Link to comment Share on other sites More sharing options...
Guest Jessie_C Posted January 13, 2014 Share Posted January 13, 2014 His gloves ought to be brown, and the green is a bit too olive. Link to comment Share on other sites More sharing options...
FunkyZeit Posted January 13, 2014 Author Share Posted January 13, 2014 He's glued in place so his green will have to do the gloves I can fix! Link to comment Share on other sites More sharing options...
Guest Jessie_C Posted January 13, 2014 Share Posted January 13, 2014 Perhaps some drybrushing can help? Here's a shoulder patch he could wear. That would usually go on his left shoulder. Or he might wear this one. Perhaps this one on the other shoulder. Link to comment Share on other sites More sharing options...
LSP_Ron Posted January 14, 2014 Share Posted January 14, 2014 Hey Justin, keep the fun in the build also bud, no need to get too wound up in accuracy, it can backfire on you by taking the fun out of it or it can put the fun into it, its really all about what is important to you. I can't believe this is only your forth model! I've been doing this most of my life and trust me, you appear to be a fast learner. Very well done so far. Keep it up! Ron Link to comment Share on other sites More sharing options...
LSP_K2 Posted January 14, 2014 Share Posted January 14, 2014 Yep, looks good to me too. Nice work so far. Link to comment Share on other sites More sharing options...
FunkyZeit Posted January 14, 2014 Author Share Posted January 14, 2014 Quick update.. Thanks for the kind words guys. I'm not going to lose sleep over a few kinks and creases that may not be 100% accurate. As you said, It needs to be fun still. So I really appreciate it guys. Pit is done I say... just need to finish the helmet.. Build the brace for the carbon rod that will fit inside the square styrene. This is the first set of epoxy, there is even more that I added later. It's very strong stuff, and smells awful. This is my first experience with epoxy. Big thanks to jmreed for the help. Here's the hole I cut out for the carbon rod Here's the "stance" it will have once mounted. 20 degrees nose up, slight left bank The engine needed to be cut in half to build the flight stand brace.. too be painted next with various alclad Enjoy! D.B. Andrus 1 Link to comment Share on other sites More sharing options...
LSP_Matt Posted January 14, 2014 Share Posted January 14, 2014 Love your pit. The IP looks wicked and your painting is great on the switches and dials. Nice detail on the inside of the engine as well. Usually we get injector pin marks and a flat surface instead. Looks like a fun build with some cool mods for the inflight pose. Keep up the great work Cheers Matty Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 14, 2014 Share Posted January 14, 2014 Really nice work mate! Looks most impressive. Kev Link to comment Share on other sites More sharing options...
LSP_Ray Posted January 14, 2014 Share Posted January 14, 2014 Can't believe this is just your fourth kit! Nice work! Link to comment Share on other sites More sharing options...
