themongoose Posted January 28, 2018 Share Posted January 28, 2018 So I've painted the red onto the tail of my F-16 Thunderbird. What's left to apply are the stars and the logo(red circle with white star in it). On the decal sheet, pictured below, they are all on the same film. however, ignore the stuff in the bottom right corner and top left corner as it was just captured in the rectangular window for the picture. Should I just cut away the red design on the left side and apply the whole film or should I try to cut out around each star or emblem and apply separately? Is there another alternative I'm not thinking of? Link to comment Share on other sites More sharing options...
Gigant Posted January 29, 2018 Share Posted January 29, 2018 Have you got picture of what you want it to look like when done? Link to comment Share on other sites More sharing options...
themongoose Posted January 29, 2018 Author Share Posted January 29, 2018 Gigant I sure do...the red i have air brushed. All the stars and complete logo are on the decal sheet. Gigant 1 Link to comment Share on other sites More sharing options...
red Dog Posted January 29, 2018 Share Posted January 29, 2018 what i would do is to create masks with tamiya tape for the two sized star and airbrush them multiple times in blue, at their correct location , cut the decal around the thunderbird squadron logo and use only that as decals. but i understand masking the stars and defining their correct placement is not easy. nevertheless, that's what i would try. I'd be too concerned with such a large film CANicoll and Gigant 2 Link to comment Share on other sites More sharing options...
Gigant Posted January 29, 2018 Share Posted January 29, 2018 (edited) I totally agree with Red Dog's assessment, especially with small stars, your having to decide basically between having clear film "filling in" between their points if you don't cut exactly around each one, or having them tending to fold, flop, double-up and curl up on you if you do, becoming nasty little rolled up bits of decal film in your trash container. I would trace or copy the decal sheet pattern onto a plain sheet of paper to become a placement template for the stars as well, cutting them out with a hobby knife, as well as the scalloped design by the red trim. Using the scalloped pattern as your placement guide, pencil trace the stars onto the masking tapes, and then cut them out and "spray-away". Edited January 29, 2018 by Gigant Shawn M 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 29, 2018 Share Posted January 29, 2018 This is one of those times a mask cutter like one of the Silhouettes would be just the ticket. The software allows for placement of each item relative to the others, and normally all it would take is scanning in the decals, and depending on how dark/contrast the colors are to one another, wouldn't take much get the proper placement and cutouts, save the logo, which I would still use in decal form. Minus the cutter/plotter, I would do what RD suggests, and utilize rice paper tape to make a mask for the two sizes, then use the decal for the logo. DesTROYer, Gigant and CANicoll 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 29, 2018 Share Posted January 29, 2018 Just to offer an alternative view, the stars on the cowling below were individually cut from the decal sheet and applied one at a time: The red, white, and blue were painted, as there was simply no way the full decal was ever going to conform to the cowling properly. Kev Zero77 and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Gigant Posted January 29, 2018 Share Posted January 29, 2018 Just to offer an alternative view, the stars on the cowling below were individually cut from the decal sheet and applied one at a time: The red, white, and blue were painted, as there was simply no way the full decal was ever going to conform to the cowling properly. Kev Did you know that you can touch-up and or correct typical red-white-& blue insignia decals with MM "Insignia" color acrylic paints? themongoose 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 30, 2018 Share Posted January 30, 2018 Did you know that you can touch-up and or correct typical red-white-& blue insignia decals with MM "Insignia" color acrylic paints? Maybe so, but there was no fixing this with paint touch-ups: Kev Gigant, CANicoll, Zero77 and 1 other 4 Link to comment Share on other sites More sharing options...
Gigant Posted January 30, 2018 Share Posted January 30, 2018 Maybe so, but there was no fixing this with paint touch-ups: Kev LOL! If what I see is that your final finished job is the correct pattern, then essentially the decals' star-pattern being "out of sync" were a waste of money and time. Were you able to salvage anything from them? Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 31, 2018 Share Posted January 31, 2018 LOL! If what I see is that your final finished job is the correct pattern, then essentially the decals' star-pattern being "out of sync" were a waste of money and time. Were you able to salvage anything from them? Just the stars. I cut them out individually from a spare set that some kind soul sent me, and applied them over the painted blue areas. A blessing in disguise, really, because as you note, the pattern on the decals is wrong, so I was able to lay them out accurately in the end, and they look pretty good. And getting back to the OP's question, I figured this might work for him, too. Kev Gigant 1 Link to comment Share on other sites More sharing options...
Gigant Posted January 31, 2018 Share Posted January 31, 2018 Just the stars. I cut them out individually from a spare set that some kind soul sent me, and applied them over the painted blue areas. A blessing in disguise, really, because as you note, the pattern on the decals is wrong, so I was able to lay them out accurately in the end, and they look pretty good. And getting back to the OP's question, I figured this might work for him, too. Kev Wow-What did you use to cut them with? *************subject change****************** On the "other hand", in 'Mongoose' case, unlike yours, his is a much flatter surface and far fewer stars, therefore the template/spray paint option should be less work all the way around. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 31, 2018 Share Posted January 31, 2018 Wow-What did you use to cut them with? Just a #11 blade, pressed along each edge of the decal. I can't remember how many there were, but I did count them at the time. I had to do it in stages to preserve my sanity! Kev Link to comment Share on other sites More sharing options...
themongoose Posted February 1, 2018 Author Share Posted February 1, 2018 (edited) Ok, i started with Kevin's approach. Originally was going to do the tracing suggested on mask, but I found i was out of mask. After the first rolled up log of decal star I decided on a hybrid approach lol I cut them into sections that would keep the alignment but minimize the decal film. I made 6 groups out of it. I cut around the red logo star and kept it separate since it has to go over the bird logo. Edited February 1, 2018 by themongoose Shaka HI, LSP_Kevin and CANicoll 3 Link to comment Share on other sites More sharing options...
Gerhard Posted February 1, 2018 Share Posted February 1, 2018 Just a #11 blade, pressed along each edge of the decal. I can't remember how many there were, but I did count them at the time. I had to do it in stages to preserve my sanity! Kev Did it work? Link to comment Share on other sites More sharing options...
