MikeMaben Posted August 28, 2010 Share Posted August 28, 2010 You bet Nick, and I agree. It's quintessential "the few". Glad to help Phil Link to comment Share on other sites More sharing options...
PhilB Posted August 30, 2010 Author Share Posted August 30, 2010 Right, as we have now established its a Rotol prop, I've done some work rounding off the squared off tips on the kit blades. There has been some discussion about this in other build threads and it is possible apparently for some later marks to have the "flat" tips but not on a mark 1. I looked at many photos of rotol props and its difficult to get the right shape unless you have a view completely opposite the flat blade of the prop. I eventually found one so here's my effort: I have been gluing as many pieces together as I can, including the exhausts. I've thinned these out quite a bit but may do a little bit more: Done the rear control surfaces but there will be a few bits to scratch such as rudder actuating horns and cables and trim tab actuators. Cut the hole in the seat for the harness and thinned it down a bit: More soon but I must do some work on the 109! Phil Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 30, 2010 Share Posted August 30, 2010 Once again stellar work my friend! Cant wait to see some paint.......... Brian Link to comment Share on other sites More sharing options...
PhilB Posted September 1, 2010 Author Share Posted September 1, 2010 Thank you Brian, I can't wait to start painting too! In the meantime I was staring at the kit control column and it looked too "clunky" to me. The Hurri joy stick pivots port and starboard only at the top. It has a small bicycle chain and connecting rods. The kit ones looked too thick. The grip appears to have string/cord wound round it before being sealed presumably for better grip. I've seen this replicated before but I wanted to ensure the scale looked right. Sooo I wound the handle with 0.08mm stainless steel wire. I was going to use a nice long hair from my daughters head but I couldn't catch the little blighter. (Damn quick these five year olds!) Only kidding! This was the finest wire I have and being steel it had plenty of strength. I also replaced the link rods with 0.5mm brass. Drilled out some 1mm rod for the connectors and flattened a bit of lead wire to give the impression of the bike chain at the top. Used black coated wire for the cables which I believe are hydraulic cables for the guns??? I stand to be corrected. I'm hoping it will look Ok after a bit of paint. I wasn't going to do much detailing on this one but I think I will just go with the flow and do what I think is needed. Phil Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 1, 2010 Share Posted September 1, 2010 I must confess as to being a little annoyed with myself. After reading comment upon comment regarding the poor fit of the wing LE gun inserts, in haste I just glued mine on flush at the top. I guess I'll have to drag out the epoxy! On the plus side, the fit on the IID is not really all that bad. Link to comment Share on other sites More sharing options...
PhilB Posted September 2, 2010 Author Share Posted September 2, 2010 I must confess as to being a little annoyed with myself. After reading comment upon comment regarding the poor fit of the wing LE gun inserts, in haste I just glued mine on flush at the top. I guess I'll have to drag out the epoxy! On the plus side, the fit on the IID is not really all that bad. I know the feeling Kev! Funnily enough on the IIc the fairings are "short" of the leading edge so you have to put card in to bring them out. On the Mk 1 the leading edge fit is ok but the profile is too thin so you have to spread them. Looks like they may have got it near enough right with the IID! I wanted to see how my wiring on the grip would look with some paint: Looks pretty much to scale I think. Phil Link to comment Share on other sites More sharing options...
LDSmodeller Posted September 2, 2010 Share Posted September 2, 2010 Phil That is awesome work Really like the hand grip. Look forward to more Regards Alan Link to comment Share on other sites More sharing options...
PhilB Posted September 9, 2010 Author Share Posted September 9, 2010 That is awesome work Really like the hand grip. Look forward to more Thanks Alan for the kind words. Today I have a little bit more to show you but first I need to talk about sperm. Yes I said sperm! Actually giant blunt-headed sperm. There that's better! I have discovered that I have several of these inhabiting the inside of the fuse: There's one of the buggers under the top cowling. There's two more here: And one on here! What's this all about! Well actually the ones on the fuse are supposed to be instrument panel lights and the one on the small panel on the fuse frame is the socket for the pilot's microphone. Well I'm not having it, they've got to go! Taking some sanding and gouging materials I removed them. The Hurricane is largely wood around the cockpit area so any instruments are mounted on plywood discs to attach them to the sidewalls same as in the Mosquito. The Trumpy one's were a bit thin after all the sanding and some weren't there for the lights so I punched discs from 5 thou card. You can see the filler from my hamfisted gouging to get rid of the sperm. More in a minute. Phil Link to comment Share on other sites More sharing options...
PhilB Posted September 9, 2010 Author Share Posted September 9, 2010 This morning I had a cockpit light making session. I had to make 4 and worked out they should be about 1.2mm wide and around 4mm long for scale. I had to make 4 as apart from the three on the fuse there is another which sits above the compass just below the ip. Trumpy haven't replicated that in the kit. Soooo I took some 1.2 rod, drilled one end for the wire, sanded it to a roundish shape and glued in the wire which is black coated copper 0.3mm which is again hopefully ok in scale. I then drilled out the other end and glued some 1.0mm aftermarket lenses in to simulate the bulbs. For the radio socket, I just drilled out the end. Got to make or simulate clips for them on the mounting disc on the fuse wall. This is how small they really are: Please don't suggest I could have used real bulbs and lit the bloody thing!!! Least I got rid of the sperm! Going to lie down for a bit now. Phil Link to comment Share on other sites More sharing options...
Shawn M Posted September 9, 2010 Share Posted September 9, 2010 What..they dont work? Link to comment Share on other sites More sharing options...
PhilB Posted September 9, 2010 Author Share Posted September 9, 2010 What..they dont work? Shawn, Phil Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 9, 2010 Share Posted September 9, 2010 Shawn, Phil Ever seen "Hot Fuzz" Phil? (I love English comedies)...... "Jog on!" Brian Link to comment Share on other sites More sharing options...
Butler Posted September 10, 2010 Share Posted September 10, 2010 Nice work The internet is full of photos of people putting sperm on a model so it's nice to see it the otherway round! Link to comment Share on other sites More sharing options...
Shawn M Posted September 10, 2010 Share Posted September 10, 2010 roflmao glad you have a sense of humor Link to comment Share on other sites More sharing options...
Allok Posted September 10, 2010 Share Posted September 10, 2010 Goodness. I just laughed so much, I think a little wee came out. Terrific work, Phil. Looks like a nice kit. Link to comment Share on other sites More sharing options...
