dutik Posted September 11, 2016 Author Share Posted September 11, 2016 Good question. Well, there are ribs which are well visible with BMF or gloss finished Texans, but they are less prominent and narrower. This is not so much a concern with my intended multicolored disruptive camouflage, but I think I will sand them a little bit down for a better look. For a BMF or glossy Texan I would prefer to sand them off and to replace them with strip styrene, sanded/tapered a bit to blend smooth into the surface. Just like modelers do with WW1 aircraft. Regards - dutik mozart 1 Link to comment Share on other sites More sharing options...
dutik Posted November 22, 2016 Author Share Posted November 22, 2016 With the lower side near completion it is time to take a final look at the cockpit. Still lacking are the rear IP and the radios. Made a set of comm boxex for the rear shelf: Some paint, some wiring, a placard or two and I am ready. Well, I have no clue what radios were used in Biafra. Some of the portugese Texans show a collection of 4 devices instead of the two parts provided with the kit, so I go this way. Maybe some new images of the Biafran Texans will appear when I finished the kit, but until that happens my guess is as good as yours. Enjoy - dutik Shaka HI 1 Link to comment Share on other sites More sharing options...
dutik Posted November 30, 2016 Author Share Posted November 30, 2016 "Hear you 10 out of 10": Regards - dutik blackbetty, Shaka HI, KiwiZac and 2 others 5 Link to comment Share on other sites More sharing options...
dutik Posted December 3, 2016 Author Share Posted December 3, 2016 (edited) Well, photos of the wireless equipment are hard to find. Of the real old military stuff, not the modern warbird radios. Guess I looked at 1.000+ images. 550 at a single french homepage about the Armee de l'air. Most cockpit photos focus on the pits and the instruments and stop at the back of the rear seat... Same to get the external antenna wiring right. Got one image of the radios from a Portugese homepage, so I made my radios to look like these. Dunno if this was a Harvard or a Texan, but they look nice to me. The color images of the French Texans also revealed that the safety frame above the sidewalls was not painted green (or chromate), but in a dark grey or black color. Next was to add wiring to the back of the rear IP which is well visible and to add the IP and the overroll safety frame: Now looking for a proper sight and mount, the the last piece of cockpit equipment needed. Regards - dutik Edited December 3, 2016 by dutik KiwiZac, Anthony in NZ, tucohoward and 2 others 5 Link to comment Share on other sites More sharing options...
dutik Posted December 12, 2016 Author Share Posted December 12, 2016 Made a sight from scratch. This is one part Kitty Hawk missed, and it is a serious omission. The armed Texans had one, and your armed Texan has to have one. KH, you missed the standards! Images to follow. Slipped when adding a new blade into my scalpel handle and cut into a finger. Have to clean up the scratchbuild sight as well as to wait a little bit until both of my hands are ready again to handle such delicate small parts. Will you also provide with links to images of the real deal. Regards - dutik Link to comment Share on other sites More sharing options...
dutik Posted December 12, 2016 Author Share Posted December 12, 2016 The sight with the mount: Hard to photograph. Took a fistful of ima ges to get a decent one. Drilled and cut a slot into the IP cover, inserted the mounting arm and glued the sight on top. The sight is mounted upside down, so the clear "screen" part is at the lower side (aka invisible in the photo). Pic of the sight. Front view. Click image to enlarge! Rear view. Click image to enlarge! They have a lot more interesting images at both homepages Regards - dutik Link to comment Share on other sites More sharing options...
dutik Posted December 15, 2016 Author Share Posted December 15, 2016 The sight is in place and painted: Adding the canopy sections as the last step before painting. Drilled a hole into the rear window and glued a wire loop in place to support the antenna wires (the copper colored thingee in front). Regards - dutik Link to comment Share on other sites More sharing options...
dutik Posted December 19, 2016 Author Share Posted December 19, 2016 My heart so dark... Citadel Chaos Black primer and some Humbrol Maskol. Regards - dutik AndersN, tucohoward and Anthony in NZ 3 Link to comment Share on other sites More sharing options...
dutik Posted December 24, 2016 Author Share Posted December 24, 2016 I like my Splinter camo ..with a little help by my friends. Or ...with a help by my little friends? Merry Christmas! Regards! - dutik ShotMagnet, Out2gtcha, tucohoward and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 24, 2016 Share Posted December 24, 2016 Cant wait to see the unwrap! dutik 1 Link to comment Share on other sites More sharing options...
dutik Posted December 25, 2016 Author Share Posted December 25, 2016 Me too! But it will take a day or another. Tamiyas Buff is clogging the airbrush like hell. The muzzle tip is buried under paint within only 5 minutes, despite using the large nozzle, high pressure and 50 percent of thinner... The green went on so-so, the Buff is just a nightmare. Regards - dutik Link to comment Share on other sites More sharing options...
dutik Posted December 25, 2016 Author Share Posted December 25, 2016 Was able to overcome the Buff issue. Airbrushed the remaining spots and peeled the masks off (only peeling off took me an hour or two). Here we go: Not too shabby all in all. Missed the outline at a few places. Thinned paint creaped under the masking here and there. Most can be corrected with a brushstroke of black or green. Made a major mistake with the black outlines at the bottom and the cowl. They didn't match for a two-tone camo. Will paint some new outlines around the buff, mask the buff spots and airbrush some green to wipe out the surplus black lines. The green just works better with the airbrush. Guess I will not be able to finish it this year, but we come closer... Regards - dutik ShotMagnet, KiwiZac and tucohoward 3 Link to comment Share on other sites More sharing options...
ShotMagnet Posted December 25, 2016 Share Posted December 25, 2016 Love the camouflage. Now all of a sudden I have a reason to build a Texan. Shot dutik 1 Link to comment Share on other sites More sharing options...
dutik Posted December 29, 2016 Author Share Posted December 29, 2016 Corrected the masking errors, the overspray, the outlines. Added walkways at the wingroots. They are well visible in the image of the Biafran Texans, but the color is your own guess. Much lighter than the black outlines and darker camo, not as bright as the bare metal canopy frames. White or grey maybe? So I went with some kind of light gray... Next steps are a clear coat and wheatering with oils. Enjoy - dutik tucohoward, Anthony in NZ, Pfuf and 2 others 5 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 29, 2016 Share Posted December 29, 2016 Nice work, dutik! That's officially one of the strangest camouflage schemes I've ever seen. Kev The Dude 1 Link to comment Share on other sites More sharing options...
