ChuckT Posted January 30, 2023 Posted January 30, 2023 I've done a search on how to solve this issue and so far no luck. Does anyone have some suggestions on the best way to add very thin yellow lines to an aircraft canopy? I'm referring to the yellow band that you often see separating the clear part of the canopy from the frame. I'm guessing masking, but I have no clue on how to mask such a thin line. Any suggestions? Thanks in advance.
Isar 30/07 Posted January 30, 2023 Posted January 30, 2023 Interesting question as I'm facing the same. By now, I would cut thin lines of Tamiya masking tape which is of an yellow/orange colour and put them on the inside of the canopy. Looking from the outside you should see the yellow/orange sealing 'putty' (that's what it is) and it should be very close to the real thing. Haven't tried it so far, but I think it could work. Now, I'm curious how other modelers will do this. Reimund MikeC 1
dmthamade Posted January 31, 2023 Posted January 31, 2023 I've used really thin masking tape, IIRC the brand name was Aizu. Applied as needed on the inside, then carefully applied flat black to seal it and ensure it wouldn't peel off later. Looks far more realistic than sealer applied to the outside. Don
dmthamade Posted January 31, 2023 Posted January 31, 2023 (edited) Edited January 31, 2023 by dmthamade Stevepd, chukw and Greg W 3
dmthamade Posted January 31, 2023 Posted January 31, 2023 Haven't posted pics in a while, the Phantom is the closest i got. Don
dmthamade Posted January 31, 2023 Posted January 31, 2023 https://hosting.photobucket.com/albums/i280/dmthamade/.highres/IMG_4988a.jpg
phasephantomphixer Posted January 31, 2023 Posted January 31, 2023 (edited) The beige trim you see is a fiberglass strip protecting the acrylic canopy ends. It shows up on some more than others. I mask up canopy as usual for clear areas, then first paint the beige, then mask again - enough to just cover beige trim, paint model, then remove masks. HTH Nice F-4 Edited January 31, 2023 by phasephantomphixer Greg W and MikeC 2
ChuckT Posted January 31, 2023 Author Posted January 31, 2023 Thanks guys for the ideas phasephantomphixer 1
Stevepd Posted January 31, 2023 Posted January 31, 2023 I also just mask the outside with 1mm tamiya tape using the moulded side of the frame as a guide. Usually works well. Greg W 1
blackbetty Posted January 31, 2023 Posted January 31, 2023 (edited) i used decal strips Edited January 31, 2023 by blackbetty Greg W 1
ChuckT Posted February 1, 2023 Author Posted February 1, 2023 When using decal strip, do you cut it thin and apply or have you found thin strips?
blackbetty Posted February 1, 2023 Posted February 1, 2023 i cut it from solid material i find on old decal sheets or print them
thierry laurent Posted February 1, 2023 Posted February 1, 2023 Some companies such as Hasegawa or Fantasy Printshop released sets of colored stripes. And you can still cut them yourself out of the largest width ones.
