sandbagger Posted September 1, 2022 Author Posted September 1, 2022 Hi all, I'm intending to add a flare and a grenade ammunition rack. So I thought I ought to add the flare and grenade pistols to the gunners cockpit. Both 'spares' from previous 'Wingnut Wings' models. The stowage containers were made from photo-etch and 1.4 mm diameter tube. I also added a map, Mike Rockie Yarwood, blackbetty, scvrobeson and 3 others 6
Rockie Yarwood Posted September 2, 2022 Posted September 2, 2022 Just keeps getting better and better, Mike!
sandbagger Posted September 2, 2022 Author Posted September 2, 2022 Hi all, Fuselage closed up now, then and the throttle control rod added (0.4 mm Nickel-Silver tube), Mike scvrobeson, blackbetty, Rockie Yarwood and 3 others 6
sandbagger Posted September 20, 2022 Author Posted September 20, 2022 Hi all, I've not posted in the last few weeks, as we took a holiday abroad. The first time in three years due to the Covid restrictions etc. The four of us arrived home yesterday. Yes, you guessed it!! I have Covid, so does my wife and the wife of our friends we went with. Anyway, once we're back to normal I'll crack on with the Lloyd model. Mike Landrotten Highlander, LSP_Kevin, blackbetty and 1 other 2 2
LSP_Kevin Posted September 20, 2022 Posted September 20, 2022 Sorry to hear that, Mike. Hope you're not suffering too badly. Get well soon. The model can wait! Kev
europapete Posted September 23, 2022 Posted September 23, 2022 Get well soon Mike, hope you all had a great holiday in spite of that. Regards, Pete in RI
sandbagger Posted September 23, 2022 Author Posted September 23, 2022 Hi all, After closing up the fuselage I found a problem with the rear fuselage cabane struts. The two rear struts on each side were slightly bowed due to the angle they were fitted. The bottom of two struts had also cracked (3D printed and not reinforced with rods). Therefore, I cut the struts away and replaced them with shaped Brass tube and internal rod. This also makes the struts stronger for bearing the weight of the upper wing halves, Mike LSP_Kevin, Fanes, Rockie Yarwood and 2 others 5
sandbagger Posted September 26, 2022 Author Posted September 26, 2022 Hi all, I've prepared the fitting of the upper and lower wings, including test fitting of the six interplane struts. I found the best way to do this was to permanently fit the lower wings first. The lower wings have only one integral locating rod and no location for the rod into the fuselage. Having only one rod meant that the wings would pivot in the fuselage, making wing alignment a problem. Also, the rod in the right lower wing is located farther rearwards than that in the left wing. Therefore, the rod would be visible inside the cockpit. I chose to cut away that rod flush to the wing root. I then drilled an extra 1.0 mm hole in the left wing root and two holes in the right wing root. Into these I secured 1.0 mm diameter Brass locating rods. The fuselage was then marked and holes drilled through the sides of the fuselage. Both wing locating rods are now not visible from inside the cockpit and the wings are positively located in the fuselage. The upper wing halves needed to be drilled for 1.0 mm diameter joining rods that locate into the two slots in the top of the fuselage cabane strut assembly. The locating holes for the six interplane struts were then drilled into, but not through their location points in the wings. The integral strut rods were cut to 2.0 mm length as they were too long. The struts were then temporarily held in their locating holes in the upper wing, which was then test fitted into the lower wings and cabane strut slots. All in all not an easy wing installation, but rigid enough when test fitted. I've also prepared the tail unit, as all of the parts have no locating rods. I've added location rods of 0.5 mm and 0.8 mm diameter Brass rods. I cut the elevators from the tailplanes in order to have them angled down slightly. Now it's onto preparing the landing gear, Mike Paulpk, LSP_Kevin, Rockie Yarwood and 3 others 6
sandbagger Posted September 28, 2022 Author Posted September 28, 2022 Hi all, The landing gear has been prepared now. I've added the following: 1.4 mm diameter Brass tube into the drilled through wheels to provide a more positive fit onto the integral 1.2 mm diameter axle rods. 'EZ' heavy white stretch line to represent the 'Bungee' type suspension cords. 0.4 mm diameter Nickel-Silver tube, bent and fitted to represent the axle restraining cables. Flattened 0.6 mm diameter Brass tube with integral 0.4 mm diameter Brass rod to represent the crew footstep. I've also made two crew steps from flattened 0.5 mm diameter Brass tube. These were fitted to the fuselage left side at the observer's cockpit and to the fuselage right side below the engine. Now it's onto preparing the tail skid, Mike scvrobeson, Landrotten Highlander, Rockie Yarwood and 4 others 7
sandbagger Posted September 29, 2022 Author Posted September 29, 2022 Hi all, The resin used for the 3D printed parts tends to be very brittle. The tail skid bracing bars need to take the weight of the model. Also, the tail skid has no integral strengthening rods or any location into the fuselage. As I wasn't sure if the bracing bars were strong enough, I replaced the rear bracing bar with 0.8 mm diameter Brass rod. This was bent at one end to fit into a drilled hole in the underside of the fuselage. Now onto how to fit the upper wing ailerons onto the wing, Mike Landrotten Highlander, Paulpk, LSP_Kevin and 4 others 7
sandbagger Posted September 29, 2022 Author Posted September 29, 2022 Hi all, The ailerons on the upper wing can't be attached with rods as the trailing edge of the upper wing is too thin to drill. The kit supplies photo-etch 'hinges', which are flimsy and may not adhere well to an oil painted wood effect surface. Therefore, I decided to modify the hinges by cutting away the hinge arms and drilling 0.5 mm diameter holes through the body of the hinges. Brass tube of 0.4 mm diameter were inserted through the hinge bodies and holes drilled through the ailerons. The tubes were bent forwards above and below the upper wing trailing edge. Holes were drilled through the wing and the top tubes bent to fit into the holes. The underside tubes were cut to end at the wing holes on the underside. Doing this allows the ailerons to be angled on the upper wing and should provide a sturdier attachment. The aileron control horns will be fitted into 0.4 mm wide slots, drilled though the ailerons inside the photo-etch mounting plates. Now onto preparing for pre-rigging the model, Mike Landrotten Highlander, blackbetty, LSP_Kevin and 7 others 10
sandbagger Posted October 10, 2022 Author Posted October 10, 2022 Hi all, It's been a while since I updated this build. The fuselage, wings, gun cannister and landing gear axle fairing were airbrushed with 'Tamiya' Dark Yellow (XF60). The flight control surfaces were primed white. These were pre-shaded with 'Tamiya' Smoke (X19). The flight control surfaces are covered with ‘Aviattic’ Clear Doped Linen (ATT32097) decal. The wood effects were brush painted using a mix of Windsor & Newton’ Griffin (Alkyd) Vandyke Brown and Burnt Sienna. Grey areas are ‘Tamiya’ Neutral Grey (XF53) or Dark Sea Grey (XF54). Metallic surfaces are ‘Alclad’ Steel (ALC112) or 'Mr. Colour' Stainless Steel (213). Decal areas were airbrushed with 'Alclad' Aqua Gloss 600. All parts were then airbrushed with 'Alclad' Light Sheen (ALC311) in preparation for applying weathering effects, Mike Archimedes, LSP_Kevin, Landrotten Highlander and 3 others 6
sandbagger Posted October 12, 2022 Author Posted October 12, 2022 Hi all, Just a few updates. Propeller base coated with 'Tamiya' Dark Yellow (XF60) then brushed with Windsor & Newton (Alkyd) Burnt Sienna oil paint. 'Lohner' propeller logos applied from the 'LF Models' Austro-Hungarian set then sealed with 'Alclad' Light Sheen (ALC311). Radiator assembly treated with 'Flory Models' Dark Dirt clay wash with the 'Number '7' decals (modified) from the 'Xtradecal' RAF set. 'Flory Models' Dark Dirt wash also applied to the wings, fuselage flight control surfaces and landing gear. Now it's onto pre-rigging the model before assembly, Mike LSP_Kevin, Fanes, Rockie Yarwood and 4 others 7
sandbagger Posted October 12, 2022 Author Posted October 12, 2022 Hi all, The observer/gunners machine gun. I chose to replace the kit supplied 3D printed machine gun parts. I used the more refined resin ‘Schwarzlose’ 07-12 unjacketed weapon (17-32112) from ‘Gaspatch’. The ammunition drum was a spare from a previous 'Wingnut Wings' build. The kit supplied gun mount needed to be modified with a 0.4 mm diameter rod to fit the weapon to the mount firmly. 'Alclad' Gun Metal (ALC120) was airbrushed over the machine gun. 'Alclad' Steel (ALC112) was airbrushed over the ring mounting rails and lightly over the machine gun. 'Tamiya' Hull Red (XF9) was brush painted over the trigger handles. 'Tamiya' Weathering Master (Set B - Soot) was sponged around the muzzle of the barrel. Ammunition belt was brush painted with 'Tamiya' Desert Yellow (XF59), 'Mr. Colour Brass (219) and Copper (215). Mike Rockie Yarwood, Archimedes, Jim Barry and 5 others 8
