mattcour Posted March 10, 2022 Share Posted March 10, 2022 That's good! Link to comment Share on other sites More sharing options...
Dekon Posted March 29, 2022 Author Share Posted March 29, 2022 Thanks for the compliments everyone. So work has slowed to a crawl on this but I am still at it. I finished off the upper and lower fins. After I sanded them down, I replaced the raised ribs on them with Tamiya tape. They need to be cleaned as you can see. themongoose, Landrotten Highlander, scvrobeson and 1 other 4 Link to comment Share on other sites More sharing options...
Dekon Posted March 29, 2022 Author Share Posted March 29, 2022 Next up was work on the upper and lower fuselages. The upper had the cockpit tub glued in. and the lower had the tube for the mount epoxied in. Inside the lower half. Exterior of the lower half. This needs a little putty work to smooth it in. scvrobeson, themongoose, Landrotten Highlander and 1 other 4 Link to comment Share on other sites More sharing options...
Dekon Posted March 29, 2022 Author Share Posted March 29, 2022 And then finally, the most daunting task so far in this build, gluing the fuselages together. First I glued the upper pieces together, then the lower pieces. Puttied them, might need some more work after I prime it. Then glue the whole thing together. Finally together. Man this thing is huge. That's all for now. scvrobeson, Treehugger, Landrotten Highlander and 8 others 11 Link to comment Share on other sites More sharing options...
Dekon Posted June 27, 2022 Author Share Posted June 27, 2022 1 hour ago, MARU5137 said: Good job. Thanks. I haven't forgot about this. Adulting stuff getting in the way, baseball and softball games to be at. I was actually working on a few hours ago as we are getting a good soaking here. Got the pilot in and am in the process of masking the windows. I really hate masking curves in the windows. Hope to have the fuselage in primer by tomorrow. Troy Molitor 1 Link to comment Share on other sites More sharing options...
Dekon Posted July 1, 2022 Author Share Posted July 1, 2022 OK, so I have a couple of issues and would like some input from follow modelers. I have a couple of gaps and was wondering how you would handle them. For this one I was thinking of using plastic sheet and filling the gap and then trim and sand down. How else could it be done? I hate when model manufacturers make open panels on kits, make scribe marks in the back of the panel and if I want to open it I'll scribe it out. Sorry for the rant. This one, I am thinking of just using some water based putty to fill it in; makes it easier to remove with a cotton bud. How would you do it? Thanks Richard Link to comment Share on other sites More sharing options...
Alex Posted July 1, 2022 Share Posted July 1, 2022 4 hours ago, Dekon said: OK, so I have a couple of issues and would like some input from follow modelers. I have a couple of gaps and was wondering how you would handle them. For this one I was thinking of using plastic sheet and filling the gap and then trim and sand down. How else could it be done? I hate when model manufacturers make open panels on kits, make scribe marks in the back of the panel and if I want to open it I'll scribe it out. Sorry for the rant. This one, I am thinking of just using some water based putty to fill it in; makes it easier to remove with a cotton bud. How would you do it? I would think about plastic sheet for both of them. I worry about the strength of especially water based putty in a place like that. If the wing flexes at all once it is dried the putty will probably crack. Link to comment Share on other sites More sharing options...
themongoose Posted July 2, 2022 Share Posted July 2, 2022 16 hours ago, Alex said: I would think about plastic sheet for both of them. I worry about the strength of especially water based putty in a place like that. If the wing flexes at all once it is dried the putty will probably crack. I’m with Alex on this. I’d put something solid in those gaps 1st. I see what looks like an orange filler. Is that bondo spot putty? If so that would be good to put around the plasticard you fill with. A little Tamiya lacquer thinner on a cotton bud will clean it up. Link to comment Share on other sites More sharing options...
ScottsGT Posted July 2, 2022 Share Posted July 2, 2022 Couple pics for inspiration Alex, Dekon, F`s are my favs and 2 others 5 Link to comment Share on other sites More sharing options...
Dekon Posted July 2, 2022 Author Share Posted July 2, 2022 Thanks for those Scott. Nice close ups of it. Link to comment Share on other sites More sharing options...
