Neo 1,554 Posted December 30, 2020 Share Posted December 30, 2020 HI guys my compressor is gona die any minute now, started to make weird bearing sound today, originally it was on a tank, last year the tak started leaking and modified it to work tankless, but now its giving up. it had a ok life i guess its one of those tcp global/master tc-20 lated 7years looking around to get a new one with a tank, i was going to buy "Master Airbrush 1/5 HP Cool Runner II" a last year when my tank busted but now amazon.ca dosent have them anymore i saw this guy California Air Tools CAT-1P1060S https://www.amazon.ca/California-Air-Tools-CAT-1P1060S-Compressor/dp/B01LYHYHEA/ref=sr_1_17?dchild=1&keywords=airbrush%2Bcompressor&qid=1609288682&sr=8-17&th=1 i know their compressors are great but i feel its a bit loud what are you guys using these days? Link to post Share on other sites
Daywalker 778 Posted December 30, 2020 Share Posted December 30, 2020 Mine died a couple of weeks ago, bought this one on Amazon and so far seems to be working well. https://www.amazon.com/gp/product/B07VT2F5N9/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 Link to post Share on other sites
Jennings Heilig 15,126 Posted December 30, 2020 Share Posted December 30, 2020 Once again, I can’t recommend getting a CO2 setup highly enough. I have literally never met or heard of a single person who switched from a compressor to CO2 who has regretted it, or who didn’t wish they’d done it years before. CO2 has no moving parts aside from a valve, zero moisture, zero noise. There is no down side to it at all. Link to post Share on other sites
D.B. Andrus 4,724 Posted December 30, 2020 Share Posted December 30, 2020 How much does it cost to refill the tank? Reasonable? Link to post Share on other sites
J.C. 243 Posted December 30, 2020 Share Posted December 30, 2020 32 minutes ago, Jennings Heilig said: Once again, I can’t recommend getting a CO2 setup highly enough. I have literally never met or heard of a single person who switched from a compressor to CO2 who has regretted it, or who didn’t wish they’d done it years before. CO2 has no moving parts aside from a valve, zero moisture, zero noise. There is no down side to it at all. Jennings; Do you mean directly from a Co2 cannister such as one might use in a planted fish tank to supplement the available Co2 for the plants? If so, what kind of adaptor are you using? Thanks in advance!! Link to post Share on other sites
J.C. 243 Posted December 30, 2020 Share Posted December 30, 2020 30 minutes ago, D.B. Andrus said: How much does it cost to refill the tank? Reasonable? If the Co2 tanks Jennings is referring to is what I am thinking of, it should be quite inexpensive (depending on where you live). Be aware, that Co2 tanks do have a limited life span and must be tested and certified safe (again, depending on the local regs where you live) after every so many refills. There is cost involved, especially if the tank can no longer be certified. In my area, most dealers are willing to offer you deals, however, when you need to replace the tank. Hope this helps a little. Link to post Share on other sites
Jennings Heilig 15,126 Posted December 30, 2020 Share Posted December 30, 2020 You need a CO2 cylinder (I use a 20 lb size) and a regulator. That’s it. That’s all you need. Contrary to what some people will try to tell you, you do *not* need a two-stage regulator. I bought mine for like $65 on Amazon. I purchased the cylinder, and when it runs dry, I take it to a welding/gas supply and trade it for a newly inspected and filled tank. A 20# tank will paint a LOT of models. J.C. and AlbertD 1 1 Link to post Share on other sites
Neo 1,554 Posted December 30, 2020 Author Share Posted December 30, 2020 11 hours ago, Daywalker said: Mine died a couple of weeks ago, bought this one on Amazon and so far seems to be working well. https://www.amazon.com/gp/product/B07VT2F5N9/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 Thats like the one i have. Lasted quite some time. Make sure you drain the tank. Mine rusted from the interior and started leaking Link to post Share on other sites
Neo 1,554 Posted December 30, 2020 Author Share Posted December 30, 2020 10 hours ago, Jennings Heilig said: You need a CO2 cylinder (I use a 20 lb size) and a regulator. That’s it. That’s all you need. Contrary to what some people will try to tell you, you do *not* need a two-stage regulator. I bought mine for like $65 on Amazon. I purchased the cylinder, and when it runs dry, I take it to a welding/gas supply and trade it for a newly inspected and filled tank. A 20# tank will paint a LOT of models. I remember you mentioning this before. Ill take a look at the availability around here. Also have to find where i would put it Link to post Share on other sites
denders 454 Posted December 30, 2020 Share Posted December 30, 2020 I have a similar (to the California) Fortress model from Harbor Freight. It is advertised as 56db. It sits at my feet while I'm painting. IMHO it isn't too loud. I got it for around $110 when it was on 'sale' and a $20 coupon. Link to post Share on other sites
thierry laurent 6,839 Posted January 1 Share Posted January 1 As most of my close friends I'm using a Werther Sil Air. This is really the top end of Italian compressors. This suitcase-shaped oil bath compressor works totally silently, can run for hours, has an easy pressure ajustement knob and moisture control system. I do not know anyone who had a breakdown even after decades of use. HOWEVER, not surprisingly, they are quite expensive. Maintenance is very simple. Just drain the tank sometimes (very easy) and after some years of use replace the fine-grade oil (less easy but not that terrible). Hth Thierry monthebiff 1 Link to post Share on other sites
DeanKB 164 Posted January 1 Share Posted January 1 Jun Air, 6-15, with a 15 litre tank attached. Quiet, reliable and built like a tank - it's very heavy & will outlive me & my kids. Requires zero maintenance. Originally used extensively in dental surgeries, mine was being used to open doors. Oil lubricated - hence 45 dB(A) sound - but so well engineered zero gets into the air line. EBay tends to have a few for sale, at least in the UK. Brand new they cost thousands, but used ones can be had for less than £100. Link to post Share on other sites
Alex 2,220 Posted January 2 Share Posted January 2 I have a California Air Tools compressor and it's great. MUCH quieter than the Porter-Cable unit it replaced. If I was just doing airbrushing I suppose I might switch to a CO2 cylinder, but the CO2 cylinder can't fill up your car tires or operate a nail gun... Link to post Share on other sites
monthebiff 6,844 Posted January 4 Share Posted January 4 Go for a Werther Sil Air as Thierry mentioned above, well worth the money and runs almost silently. You would not be disappointed, had mine for a few years now and very happy with it. Regards. Andy Link to post Share on other sites
Hawkwrench 1,585 Posted January 6 Share Posted January 6 CO2 is the way to go. SOOOO much easier to work with. I use a 5 lb tank and it costs about $25 to fill. I built a tank support from scrap metal from work and had one of our welders weld the 2 circle straps on and then I painted it and screwed it into the side of my modeling bench. I bought a kegerator regulator off of Ebay and it works perfect for me. Tim Tim Link to post Share on other sites
