DrDave Posted May 26, 2020 Share Posted May 26, 2020 (edited) Made good progress The surface detail is raised and refined The cockpit opening large with rather a Spartan cockpit contains seat, PE belts, joystick and pedals with front and rear bulkhead The instruments are injection moulded with decals or a choice of layered PE Overall fit is pretty good once surfaces are scraped a little The wing to fuselage has needed a little settling on one side necessitating creating a small gap below to avoid one at the wing root on top It’s easily filled below The exhausts are not hollow and a bit crude I have used copper tube The only real issues I can see are the prop and spinner, not totally wrong per se, but many had a thicker wooden 2 blade with no spinner or a blunt spinner This spinner is pointy and the props have too narrow a root Edited May 26, 2020 by DrDave Typo scvrobeson, Landrotten Highlander, Jan_G and 6 others 9 Link to comment Share on other sites More sharing options...
DrDave Posted May 26, 2020 Author Share Posted May 26, 2020 Very very reminiscent of special hobby A very good first effort in 1/32 which would benefit from a resin cockpit, exhaust, nose cone and prop to make it excellent. Hope they are working on those, or someone is very enjoyable Out2gtcha 1 Link to comment Share on other sites More sharing options...
DrDave Posted May 26, 2020 Author Share Posted May 26, 2020 Out2gtcha, alain11, scvrobeson and 2 others 5 Link to comment Share on other sites More sharing options...
alain11 Posted May 26, 2020 Share Posted May 26, 2020 hi the kit looks nice , this will be a quick build of an interesting AC , I will follow your thread , thank you for sharing !!!!!! .... Alain Link to comment Share on other sites More sharing options...
hopkinspeter Posted May 26, 2020 Share Posted May 26, 2020 That looks nice, do you have any pictures of the interior before you closed up the fuselage? Does your reference to it being 'spartan' refer to what's provided in the kit or the fact that there wasn't much in the real thing anyway? I have one of the Dora Wings kits on the way to me but haven't received it yet; for some reason the D.500/501/510 series has always been a favourite of mine ever since I built the Heller 1/72 ones ages ago...actually, on reflection, it was more than 30 years ago.....help! Link to comment Share on other sites More sharing options...
DrDave Posted May 26, 2020 Author Share Posted May 26, 2020 I can’t find any ref pics of the cockpit, so it may well be spartan in reality. No throttle quadrant, levers etc. hopkinspeter 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted May 26, 2020 Share Posted May 26, 2020 I'm glad to see this build of an interesting (if somewhat obscure) aircraft. Would look great next to an Amiot 143... Alain Link to comment Share on other sites More sharing options...
quang Posted May 26, 2020 Share Posted May 26, 2020 Spartan is the word HTH Quang dutik, scvrobeson, Iain and 1 other 4 Link to comment Share on other sites More sharing options...
quang Posted May 26, 2020 Share Posted May 26, 2020 1 hour ago, DrDave said: The only real issues I can see are the prop and spinner, not totally wrong per se, but many had a thicker wooden 2 blade with no spinner or a blunt spinner This spinner is pointy and the props have too narrow a root. The thicker wooden 2-blade sans spinner is for the D.501. The 3-metal blade blunt spinner is the D.510. Both versions are to be released next. I admit that the prop included in the D.500 is none too convincing. Good luck with your build, Cheers, Quang Link to comment Share on other sites More sharing options...
DrDave Posted May 26, 2020 Author Share Posted May 26, 2020 Cockpit looks realistic then! i might see if I can make a spare wnw prop fit the spinner. Link to comment Share on other sites More sharing options...
hopkinspeter Posted May 26, 2020 Share Posted May 26, 2020 1 hour ago, quang said: Spartan is the word HTH Quang It certainly looks pretty basic alright. Thanks for that, it will certainly be helpful when my kit arrives.....I did try looking online, but could find very little about the D.500 in general and almost nothing about its interior. Link to comment Share on other sites More sharing options...
Iain Posted May 26, 2020 Share Posted May 26, 2020 Ace to see one of these getting built! Looks really nice... Iain Link to comment Share on other sites More sharing options...
