It seems like a bunch of us have the same story of getting back into modeling after many years. It looks like your off to a great start.
On 6/2/2019 at 2:15 AM, CANicoll said:
Looking good Sepp, your work is terrific and I'm envious of the Cricut.  LOVE those muzzles.  Who makes those please?
Chris
Thanks, Chris. The muzzles are made by Master who do an extensive range including full-length barrels.  They're widely available via on-line stores :)
Yes indeed! It's good to see so many people taking it up again.
Another very busy week has provided only limited opportunities to make any progress on this project, so the planned work on the tub has given way to beginning painting various parts - yes, actual paint on the actual model - no more mule!  Awful pictures I'm afraid.
All will eventually receive a coat of gloss then some light dirtying up, to various degrees.
Firstly, the gear legs are assembled and painted.
The rudder has its basic scheme on
The gear doors are painted inside and out (no pics of the main doors or the outsides, we've all seen blue paint). One inner, to illustrate...
and I had a play with some BMF, which I really like using.  Not sure how good it'll be for a metal finish bird as it has a noticable grain... some experimentation with micromesh and wire wool is in order, I think - ditto kitchen foil - as I'm currently intending learning curve subject #3 to be NMF. Still have to trim the edges of this one, but in the flesh, the polished scuff plates look great.
The gear bay is done - except the reservoir in the right-hand side, which I need to paint yellow and I might change the colour of the (few) wires, just for some contrast.
and finally the prop and spinner have received their basic scheme
I'm quite pleased with how the spinner turned out - should look OK with a wash to bring out the detail.
So, not the week I had planned, but progress nevertheless and the education continues!
Tub next, definitely.
Sepp
Great work!   I like the scheme so far for sure.     Yes, BMF has a noticeable pattern to it ( I wouldn't even call it a grain, as it seems to run in various directions on some sheets) and is thin enough as to be problematic to apply over an entire airframe.  The adhesive on BMF is also lacking IMHO, and is not nearly strong enough to hold permanently on small sized sections applied to the model.
Kitchen foil with sprayed on MS foil glue holds like gangbusters, and you can grain the foil (thick/heavy duty Reynolds Wrap can be sanded down easily) in any direction you want after smoothing by using low tack masking tape to mask off the adjoining panel, and applying some XXX steel wool.
Thanks for the advice, Brian! :)
I can see I'm going to have to invest in various makes/grades of foil and have a nice long play with them. Of all the firsts, I think it's the one I'm most looking forward to, whilst at the same time being the one that seems most daunting.
Indeed. In this case like with most any new technique, practice does make perfect.    Do exactly that, get yourself as many different types, grades and makes of foil as you can get your hands on...................you will start to get a tactile feel for how each performs, how it looks once burnished down, and (most importantly IMHO) what the properties of each are, and how far you can push graining, burnishing and sanding. Once applied, you ARE going to get wrinkles if you foil an entire model.   Its just a fact that everyone who foils or works with sheet metal on models will have to deal with, and using the right foil (AKA thicker or more heavy duty) in certain spots will go a long way to making the experience much more enjoyable, as you will be able to sand out wrinkles that you can anticipate happening in certain spots (convex/concave areas). That has always been my issue with BMF (along with several others actually) that it is virtually impossible to sand out any imperfections once applied, and if a very small section of BMF is applied you even risk pulling it up, as the adhesive is rather poor IMHO.
All good stuff to ponder!  Thanks again for the advice, and also for the encouragement. :)
Edited by Sepp
  • 4 months later...
Well, that was a longer than expected absence!
I injured my back at the beginning of July and sitting down for any length of time was excruciating for twelve weeks or so. The enforced horizontal rest has meant that life, work etc. has pretty much been on hold. Now I'm just about back on top of everything else, I can try to pick up where I left this build. Picking the positives out of the nightmare, it did give me ample time to think about where and how I do things - so gone is the board on the coffee table in my lounge, the dining table has been pressed into service and now does something useful rather than just giving me something else to keep dust-free (I live on my own, so no annoyed other half to worry about) and I now have a proper, organised space to potter about in.   Plastic sheet over the table so I can scribble notes to myself and wipe them away when done, white disposable paper sheet that is remarkably good at stopping tiny bits travelling too far, and storage on the left for major things that doubles as a pin board. I bought a couple of cheap tool chests (there's another one behind where I'm standing, next to a beer fridge) so I can organise the plethora of smaller tools, parts, decals etc. that don't need large shelves.  The sharp-eyed might notice that I'm already looking ahead to build no. 2....
With little else to do other than plan and plot, the shelf of doom has swelled into a room of doom, lol.... I have enough in there now to keep me going for a good long while.
So. what progress?  Well, "progress" pretty much means stripping some of what I'd already done, because I wasn't happy with it.  The new spinner is much better - the stripe actually gets to the tip now, and ends in a reasonable 'dot'.  The prop is pretty much done and both have had a coat of satin varnish.
I might give the inner rubber boots a glossier finish and/or treat the outer part of the blades to a tiny bit of leading edge weathering (it is supposed to represent a restored and cared for warbird, after all) once the whole thing is done, just for some contrast.  We'll see.
Not much to show at the moment, but at least I'm back on it!
Edited by Sepp
16 hours ago, LSP_Kevin said:
Good to see you back, Sepp!
Kev
Thanks, Kev!  Good to be back :)
15 hours ago, bdthoresen said:
Looking great so far. I like the premise, looking forward to more posts!
THOR    :ph34r:
Thank you!
