Stevepd Posted October 10, 2018 Share Posted October 10, 2018 I’m doing the 1/32 Revell Tornado at the mo. Construction of the tail planes has show that one sides trailing edge is lovely and thin, but the other sides trailing edge is vert thick. How can I thin this out without creating a wedge and loosing all the detail. Steve. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted October 10, 2018 Share Posted October 10, 2018 Here's one potential solution that has worked well for me in the past. The photos in this case are of Monogram's ancient 1/48 scale Wildcat kit, whose trailing edges were not only thick, but a bit wobbly from worn-out moulds. The first thing I did was square up the trailing edge as best I could, and in the process created a bit of a flat spot. I then took some styrene rod of the appropriate thickness (it need to be thicker than the wing), and glued it to the trailing edge with liquid cement: Once this was dry enough, I trimmed the length and then backfilled the area behind the rod with CA. Then it was just a matter of filing and sanding it to a sharp edge: The two main downsides to this approach are that it's not very friendly to surface detail in the area, and it does slightly add to the chord of the wing. Anyway, something to consider! Kev Marcel111, D.B. Andrus, Southern Bandit and 4 others 7 Link to comment Share on other sites More sharing options...
thierry laurent Posted October 10, 2018 Share Posted October 10, 2018 Another approach is to sand the internal side of the rear edge of the wing. alaninaustria, Stevepd, Daniel Leduc and 4 others 7 Link to comment Share on other sites More sharing options...
alaninaustria Posted October 10, 2018 Share Posted October 10, 2018 1 hour ago, thierry laurent said: Another approach is to sand the internal side of the rear edge of the wing. I agree, this method has served me well too. Just do a lot of test fitting!! Cheers Alan Link to comment Share on other sites More sharing options...
Shawn M Posted October 10, 2018 Share Posted October 10, 2018 if they're one piece you'll have to sand and file it down then restore the detail if two piece thin from the inside as mentioned. Link to comment Share on other sites More sharing options...
Alain Gadbois Posted November 19, 2018 Share Posted November 19, 2018 I usually shave much plastic from the inside, plus some more from the exterior once the halves are glued together. Check your references, as not all aircraft have thin trailing edges. Link to comment Share on other sites More sharing options...
