BloorwestSiR Posted March 17, 2017 Author Share Posted March 17, 2017 Love the idea of bending the flight stand! How are you attaching it to the plane - using the slipper tank? I see it there on the left - Im struggling to work out how to do it without using the tank on my Spitfire VIII too... Thanks Chris! I think if you drill a small hole in the lower wing and securely attach a nut there you should be able to get away with not using the slipper tank. I used the same approach for mounting my X-15. Just make sure it doesn't interfere with the cockpit above. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 17, 2017 Author Share Posted March 17, 2017 Cool. With a twist. Sincerely, Mark Thanks Mark! Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 17, 2017 Author Share Posted March 17, 2017 Great work, Carl! Kev Thanks Kev! Glad you could drop in. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 17, 2017 Author Share Posted March 17, 2017 Carl, Nicely done. The curve adds that little something extra, that makes it look that much more of a natural pose. Joel Thanks Joel! It really is amazing how such a subtle change impacts the look and feel. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 17, 2017 Author Share Posted March 17, 2017 Carl Nice working on doing just enough to the Merlin to hang the cowlings and prop on. I'm glad you included some close up of the Merlin as now that I have a few more Tamiya Spitfires in the stash, the next one down the road will be buttoned up for change. Nice work on the stand - looks so much better with the even bend Keep 'em coming Peter Thanks Peter! It does speed things up when you can leave stuff off knowing it won't be seen. Plus I've got a couple other Spitfires where I have painted and assembled everything. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 17, 2017 Author Share Posted March 17, 2017 For the HF VII, I went ahead and started the assembly of the full engine. I built it up into subassemblies to ease the painting process. I used the Barracudacast rocker covers that have the Rolls Royce nameplate on them. The engine cradle and cowl panel frames were assembled and painted next. 109 and MikeC 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 17, 2017 Author Share Posted March 17, 2017 Back to the Grey Nurse, I installed the gunsight which was the last part of the cockpit. The tailplanes were next in line. Shaka HI, 109 and leitch 3 Link to comment Share on other sites More sharing options...
Joel_W Posted March 17, 2017 Share Posted March 17, 2017 The rocker covers with the name badge really makes quite a difference at least to a guy who used to play around with engines back in his very younger days. And those tail flying surfaces really looks like a miniature assembly line. Sure hope you know which ones goes to which aircraft Joel Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 17, 2017 Author Share Posted March 17, 2017 Thanks Joel! The rocker covers really do add that little bit extra. As for the tailplanes, they're all the same thankfully which lets me get away with doing them all at once. Link to comment Share on other sites More sharing options...
dennismcc Posted March 17, 2017 Share Posted March 17, 2017 Great production line ! Cheers Dennis BloorwestSiR 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 2, 2017 Author Share Posted April 2, 2017 Great production line ! Cheers Dennis Thanks Dennis! Sometimes it really does seem that way. MikeC 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 2, 2017 Author Share Posted April 2, 2017 So, I'm back with an update. I've assembled and painted the props. I did run into an odd issue though. I have three Tamiya Spitfires on the bench but... ... assembled four props! Guess I'll save the spare for a future build. Still don't know where it came from though. Once I had the black painted, I masked off and did the tips in yellow. Shaka HI, mpk and MikeC 3 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted April 2, 2017 Share Posted April 2, 2017 Carl Super work on the Four Props and with only three Spits under way, that mysterious fourth just might be knocking at the door. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Joel_W Posted April 2, 2017 Share Posted April 2, 2017 Carl, your props are certainly nicely painted, even though you seem to have gained one somehow. Looking a the four of them, one seems to have a completely different hub. Odds are that's the black sheep of the lot. Joel BloorwestSiR 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted April 3, 2017 Share Posted April 3, 2017 You are a Spitfire machine! Looks good. BloorwestSiR 1 Link to comment Share on other sites More sharing options...
