I'm following this closely for when I build my 248. I also was undecided whether to paint the stripes before or after, so it will be interesting to see the outcome.
Looking good and I admire your grit!
Best regards;
Steve
Thanks Steve! I'd say do the red first and then the silver if my experience is anything to go on.
Carl
Fingers crossed and a pretty novel approach. The white primer smoothed out should work perfectly and you'll be off and running again
Looking forward to the next update for sure
Keep 'em coming
Peter
Thanks Peter!
So I managed to get the silver sprayed last night.
I then did a flash coat this morning of a very thin mix of paint to thinner.
Once that was dry, I pulled the masking off.
Overall, it's much smoother and best of all, no need for a clear coat. :)
I have to say it was well worth the effort of re-doing the paintwork.
Now onto doing the same with the cowl.
Carl
Guest Peterpools
Carl
Perfecto! Right with you ... absolutely worth the effort and extra work
Keep 'em coming
Peter
Carl
Keep 'em coming
Peter
Thanks Peter! It definitely was worth the time to fix it and get it right.
I got a bit more done in the last couple of days. I installed the fishtail exhausts onto the engine and then finally attached the completed assembly to the fuselage.
I then checked the fit of the cowl panels. They seem to be a bit loose compared to how they usually fit so I'll be taking another look at them. But here's what she looks like now.
At the moment, I think I have decals and landing gear left before she's finished.
Carl
