LSP_K2 Posted June 12, 2018 Author Share Posted June 12, 2018 With all eight pin marks now dealt with to my satisfaction, I've added the cowl/exhaust flaps (the fit was perfect), and sprayed the interior surfaces with Tamiya black lacquer. If you fellas haven't yet tried this paint, grab yourself a bottle; it sprays like a dream. Again, the fit of the exhaust flaps is really as good as it gets, wonderful engineering on the part of Hasegawa. Gazzas, Out2gtcha and coogrfan 3 Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 12, 2018 Author Share Posted June 12, 2018 For whatever bizarre reason, I completely neglected to spray the yellow for the prop tip bands. This has now been done, using Floquil UP Armor yellow, my go-to paint for this sort of thing. Rear of blades were not done to my satisfaction, so I've now resprayed the tips with MM aluminum. Once I then add the brown back, I'll scour it up better than what I'd done previously. MikeMaben, sandokan and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
Gazzas Posted June 12, 2018 Share Posted June 12, 2018 Some very fine work, Kevin. Did you end up using flat sheet to cover the ejector pin mark in the wheel well cover? Pin marks surrounded by detail have always been my worst nightmare. I've generally taken the cowardly way out and left them be. But I will try to cover them with sheet in the future. Gaz LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 12, 2018 Author Share Posted June 12, 2018 Some very fine work, Kevin. Did you end up using flat sheet to cover the ejector pin mark in the wheel well cover? Pin marks surrounded by detail have always been my worst nightmare. I've generally taken the cowardly way out and left them be. But I will try to cover them with sheet in the future. Gaz I haven't done anything at all to them yet, but I'll soon be ordering this Mission Models upgrade kit for my micro chisel, and I''m hoping that'll help me do the trick. If not, yes, I'll cover them with .005 plastic, then fair them in with Mister Surfacer. For a model that's destined for the contest table, I absolutely will eliminate them, one way or another. Gazzas and Out2gtcha 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 12, 2018 Author Share Posted June 12, 2018 I'm just a painting fool today, I guess. Here I've sprayed the acrylic base coat for the oil based woodgraining to follow on the headrest. Spinner backplate sprayed aluminum; needs more work though, as the photo shows. Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 13, 2018 Author Share Posted June 13, 2018 I also went ahead and spritzed some paint on the spinner (after spraying MM aluminum on the inside!). Tires given a coat of Floquil engine black. Some pastels and washes should make them look quite acceptable,... I hope. Dpgsbody55, LSP_Kevin, Gazzas and 2 others 5 Link to comment Share on other sites More sharing options...
Gazzas Posted June 13, 2018 Share Posted June 13, 2018 That is quite a chisel set. I have some wood chisels in my shed and a bench grinder.... see where I'm going? Anyway... The N1K1 is probably my second most favorite aircraft ever and I'm enjoying watching your work. Gaz LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 14, 2018 Author Share Posted June 14, 2018 Still more work here; small stuff, but things that need doing. It's not very likely at all that the rear of the spinner black plate will be visible on the finished kit, but with four ejector pin marks, I needed to be sure, so cut a disk of .010 and glued it in place. Once it's thoroughly dry, I'll clean it up with some surfacer, and paint it aluminum. Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 14, 2018 Author Share Posted June 14, 2018 Gloss Tamiya lacquer (wonderful stuff), spritzed on the cowl in preparation for the Alclad to follow. Out2gtcha 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 14, 2018 Author Share Posted June 14, 2018 More work done to the prop and spinner, and both skanked up some. I'm not 100% pleased with this, but I still have some wiggle room. Parting shot. Out2gtcha, sandokan, LSP_Kevin and 1 other 4 Link to comment Share on other sites More sharing options...
Guest Maxim Posted June 14, 2018 Share Posted June 14, 2018 The prop looks nice! Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 14, 2018 Author Share Posted June 14, 2018 Thanks, fellas, I certainly do appreciate it. Nope, metal blades, at least on the George. I suspect some may have used wooden propellers, but I'd need to look into that. Out2gtcha, CATCplSlade, theseeker and 1 other 4 Link to comment Share on other sites More sharing options...
CATCplSlade Posted June 14, 2018 Share Posted June 14, 2018 Thanks, fellas, I certainly do appreciate it. Nope, metal blades, at least on the George. I suspect some may have used wooden propellers, but I'd need to look into that. Looks like case of severe warpage to me. Probably left it out in the humidity too long. LSP_K2 and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 14, 2018 Share Posted June 14, 2018 Wow, you really have been on a painting kick! Really looks great, and seems progress is progressing for sure I haven't done anything at all to them yet, but I'll soon be ordering this Mission Models upgrade kit for my micro chisel, and I''m hoping that'll help me do the trick. If not, yes, I'll cover them with .005 plastic, then fair them in with Mister Surfacer. For a model that's destined for the contest table, I absolutely will eliminate them, one way or another. That MM chisel set looks quite handy indeed! I made my own from a pin-vice and an extra thick needle I cut and flattened, but having round and various shaped heads could by even better. LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 14, 2018 Author Share Posted June 14, 2018 Wow, you really have been on a painting kick! Really looks great, and seems progress is progressing for sure That MM chisel set looks quite handy indeed! I made my own from a pin-vice and an extra thick needle I cut and flattened, but having round and various shaped heads could by even better. Thanks, Brian. Yes, there are times when I really enjoy airbrushing some stuff. Spraying paint is just a pure joy for me. And the Mission Models set is being purchased primarily for the extra Allen wrench, which is tiny, as I lost my original, plus it won't hurt at all to have those extra narrow chisels either. Out2gtcha 1 Link to comment Share on other sites More sharing options...
