D.B. Andrus Posted February 5, 2016 Share Posted February 5, 2016 I'm looking for the main landing gear oleo full-scale diameter. Am working on 1/32 models of the Revell FW 190F-8 and Hasegawa FW 190A-8 and each kit has different diameter oleos. The Revell oleo is substantially smaller. Any assistance is appreciated.Thanks,D.B. Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 5, 2016 Share Posted February 5, 2016 I saw that too and wondered myself..................but when the G-Factor white brass legs showed up for it, the oleo struts were SO pretty (and much thicker looking than the Revell ones) and were SO easy easy to just polish to a high mirror shine I just had to use them. Chris Wimmer 1 Link to comment Share on other sites More sharing options...
RBrown Posted February 5, 2016 Share Posted February 5, 2016 D.B. Andrus, D Bellis and Thunda 3 Link to comment Share on other sites More sharing options...
stevegallacci Posted February 5, 2016 Share Posted February 5, 2016 Looks like the actual telescoping section is about 7cm in diameter D.B. Andrus 1 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted February 5, 2016 Author Share Posted February 5, 2016 Thanks, Rob and Steve. Cheers, D.B. Link to comment Share on other sites More sharing options...
stevegallacci Posted February 5, 2016 Share Posted February 5, 2016 They had rubber gaiters over them... Except when they didn't Vandy 1 VX 4 and D.B. Andrus 2 Link to comment Share on other sites More sharing options...
Jerry Crandall Posted February 5, 2016 Share Posted February 5, 2016 The correct landing gear leg for the Fw 190 A-8 or F-8 is the one on the right. This diagram that is posted is from my Fw 190 Dora book. Vol. 2 page 202 and 203. More on 204 and 205. Cheers, Jerry Hardcore, D.B. Andrus, Rick Griewski and 1 other 4 Link to comment Share on other sites More sharing options...
RBrown Posted February 6, 2016 Share Posted February 6, 2016 Looks like the actual telescoping section is about 7cm in diameter With some casual measurements taken from a printed copy at 1.5X it get 7.6 cm for the lower telescoping section. Slightly less than 2.4 mm in 1/32 scale, as a rough estimate. D.B. Andrus 1 Link to comment Share on other sites More sharing options...
RBrown Posted February 6, 2016 Share Posted February 6, 2016 They had rubber gaiters over them... Lots of period photos of later models w/o the gaiters, perhaps they were dispensed with at some point? Link to comment Share on other sites More sharing options...
Jerry Crandall Posted February 6, 2016 Share Posted February 6, 2016 Just went out to measure our Fw 190 landing gear leg, and the diameter of the oleo strut is 7 cm Jerry Vandy 1 VX 4, D.B. Andrus and RBrown 3 Link to comment Share on other sites More sharing options...
Jerry Crandall Posted February 6, 2016 Share Posted February 6, 2016 The rubber boots were normally dropped when they went to the thicker leg about the A-5. Jerry RBrown, D.B. Andrus and Rick Griewski 3 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted February 6, 2016 Author Share Posted February 6, 2016 Thanks, Jerry, really appreciate it. Steve, you were on the button. Cheers, D.B. Link to comment Share on other sites More sharing options...
stevegallacci Posted February 6, 2016 Share Posted February 6, 2016 Thanks, Jerry, really appreciate it. Steve, you were on the button. Cheers, D.B. There is a simple trick to that. Providing the drawing is accurate (some may have good numbers but poor proportions) find a dimensioned element and compare it with the detail in question. The drawing doesn't have anything 7cm long or wide, but it did have one at 6.5cm. Eyeball the fraction up and there you go. D.B. Andrus 1 Link to comment Share on other sites More sharing options...
Fenous Posted February 7, 2016 Share Posted February 7, 2016 This is A-7 with rubber boots RBrown and D.B. Andrus 2 Link to comment Share on other sites More sharing options...
