Guest Posted September 14, 2016 Posted September 14, 2016 Good luck David. Hope to see pics soon.....Harv
David Hansen Posted September 14, 2016 Author Posted September 14, 2016 Warping seems to have subsided. Have gone over both sides with some 320 grit (dry of course) and its starting to look nice. Hope to get another couple of coats on the deck before i go on deployment again. -d-
David Hansen Posted September 15, 2016 Author Posted September 15, 2016 Okay, the deck has been primed and sanded out. Looks pretty good, more or less flat with minimal warping. Will be on the road for 11 days but when i come back I will cut it to shape and begin painting. -d-
David Hansen Posted October 5, 2016 Author Posted October 5, 2016 Minor update: The deck has been glued to a piece of 1/2" plywood. I marked out the area that i need and the original 22" X 22 1/2" size is gonna be cut down to about 16" square. Waiting on the base/ deck to be cut. -d-
r0t0rdr1ver Posted October 5, 2016 Posted October 5, 2016 Magnificent work Dave, she's a thing of beauty! I'm sure Bob will be thrilled. Bravo!
David Hansen Posted October 5, 2016 Author Posted October 5, 2016 Harv, i will post some pictures of it in bare form once its been cut to shape. I may have glued the planks together out of sequence, though i did follow the instructions. Need to follow up with Nautilus models on that. Deck was SUPPOSED to be cut by now but...... -d-
David Hansen Posted October 7, 2016 Author Posted October 7, 2016 Update: Deck is now cut. 16" square. Have to wait til i return from my deployment, before i can resume work on it. Sigh..... Next step will be choosing an appropriate edging material; i want the acrylic display case to sit around the edges of the deck; not on top of it. Then will go to Michael's and get some felt for a backing. Then I'll spray adhesive it onto the back of the base. As Rihana would say, "It's all about the Base".... -d-
David Hansen Posted October 19, 2016 Author Posted October 19, 2016 Hi Folks. And, now a long awaited update. Special thanks go out to friend, fellow model builder, and extremely cheap person Terry Schuler, who took my deck to a friends house and did a BRILLIANT job at truing in up and cutting it down to a much more easily manageable 16 X 16" square. And then i felt something. Something i Haven't felt since... Crafty supplies found at your friendly neighbourhood Michaels. a 36" X 36" pack of green felt and a can of Krylon spray adhesive. I rough cut it to shape first. I have enough felt left over to make Kermit the Frog's Evil Twin... This is the bottom surface after the wood had been sprayed and then "plopped" down on the felt which was done on my steel breakfast table. And here it is after its been cut. Felt is actually a real ***** to cut cleanly. My work mat now looks like it has grass growing up thru the cracks. Next came the paint. Craig Pierce, author of the AMM article used craft paints that he got at a craft store, and mixed them to approximate intermediate blue. I took a look at the craft paint selections, said "Meh." and went home. I mixed up my first attempt at Navy 21 Deck Blue stain by mixing mostly Tamiya XF-17 Intermediate Blue with some XF-66, in order to kill the blueness a little bit. I thinned the paint with Tamiya Lacquer thinner, which seems to have completely avoided any potential problems with warping. It takes a LOT of paint to cover a deck this big. Having it done, i feel its a little bit dark, so tomorrow i'm gonna add some white to the deck blue and go over the deck again. Corsair added for dramatic effect. Waiting on some new flame dampening exhausts. To be continued..... d-bot F`s are my favs, alaninaustria, Whitey and 2 others 5
David Hansen Posted October 22, 2016 Author Posted October 22, 2016 And now, another update. Mask mask mask mask..... paint. Here we see the obligatory image of how skillfully (LOL) i have masked the deck... Here we can see that i can actually keep control of an airbrush for limited periods of time.... I did the tie down cleats with the original blue-gray deck colour, but i added some insignia blue (i'd mixed that up back when i painted on the insignias; now i got a whole bottle of the stuff) to improve the contrast. I tried adding in Future to impart some gloss but it didn't seem to work. So, i went back and blasted Future over the deck cleats so they appear glossy, as seen here. Next up are the "Foul Lines". I looked at several photos of ENTERPRISE and they seemed to contrast with the deck pretty good, at least when new. I originally tried to do these with XF-66, but i didn't get the contrast i was looking for. Here is where screwing up the spacing between the rows of deck cleats really shows. The Foul lines are by my estimate, 6 planks wide, and painted between alternating rows of deck cleats. They shouldn't be on the cleats themselves actually. Anyway the proportions and spacing of the stripes is correct, even if the deck cleat rows are not. I added flat white to the gray i had mixed up to get a better, but not too stark contrast between the Foul Lines and the deck. And with that.... It's off to the Pub. Last nite, i went over the deck with 2 passes of a wash of Grumbacher Payne's Gray watercolor. I was worried that i'd have problems with the wood warping or lifting, but as of last nite, so far, so good. Here is a closeup of the deck with the wash applied. This is only the first iteration; then next iteration today will be a low level, high speed pass with Raw Umber. That's all i got for now. Hope you likee. d-smack Shaka HI, Allan Peters, TorbenD and 2 others 5
MustangManiac Posted October 24, 2016 Posted October 24, 2016 Awesome work David and for a great cause! Cheers, Brady
alaninaustria Posted October 24, 2016 Posted October 24, 2016 Damn this is looking just great!! Really really nice work! A good base make a great model even better! Cheers Alan
David Hansen Posted October 25, 2016 Author Posted October 25, 2016 (edited) Hi Alan, i've pushed the weathering of the deck as far as i dare. This morning, i added some fuel and oil spills to the deck and now i regret doing so. Fortunately i only did a few and i think the model will cover them up for the most part. Next step is to put a frame around the base, which will serve as a positive locator for the display case.... -d- Edited October 25, 2016 by David Hansen Whitey, tomv87, Allan Peters and 1 other 4
