Wolf Buddee Posted January 20, 2015 Author Share Posted January 20, 2015 Thanks Peter! Cheers, Wolf Link to comment Share on other sites More sharing options...
crackerjazz Posted January 21, 2015 Share Posted January 21, 2015 Beautiful work!!! BTW I just came across your 1/32 Spitfire shots on the Airscale site and was blown away. Link to comment Share on other sites More sharing options...
Bill_S Posted January 21, 2015 Share Posted January 21, 2015 Incredible stuff here, Wolf! Link to comment Share on other sites More sharing options...
Wolf Buddee Posted January 24, 2015 Author Share Posted January 24, 2015 (edited) The upper cylinder assemblies and valve train are finished. The intake manifold locking rings have been added and so have the spark plugs. These items are all from Taurus Models as are the fuel primer cups added to the intake side of the cylinders. The Taurus Models items are incredibly small and equally incredibly detailed. Well worth the money spent but you definitely need a very good magnifying lamp to paint and install them. To bring out their detail I used my usual wash of a 50/50 mix of black and brown Detailer wash thinned with distilled water and a drop of dish washing liquid to break the surface tension of the mix. The fuel primer cup assemblies were primed with Tamiya's fine white primer and then sprayed with Alclad Polished Brass. They were given a light spray of clear gloss to protect the brass finish and then enhanced with my pin wash. The ignition conduits were painted Tamiya's XF-9 Hull Red after the ends were drilled out to accept the ignition wires that come from the magnetos. The rocker boxes were painted Vallejo's Black Grey and the rocker arms and valve spring assemblies were painted with a 50/50 mix of Citadel BoltGun and Vallejo's Oily Steel. In the last pic you can see the clamps I added for the upper and lower coolant pipes. For those, probably because they'll never bee seen, I used small lengths of silver stripe decal. When I built the Mercedes DIII au engine for my Fokker DVII I used yellow detail wire for the ignition leads. This time I'll use black as I believe from the photos I've seen of unrestored engines that black ignition wires are more period correct. It won't stand out as much or look as cool but that's OK. Thanks for following along. Cheers, Wolf Edited January 25, 2015 by Wolf Buddee Uncarina, Bill_S, Tomek and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 24, 2015 Share Posted January 24, 2015 Astonishing work, Wolf! Terrific painting, as always. Kev Link to comment Share on other sites More sharing options...
Wolf Buddee Posted January 24, 2015 Author Share Posted January 24, 2015 Thanks Kevin, now if I can only figure out why my pictures look so crappy! I'll have to look at my settings again as the pics look too grainy or not quite sharp enough. If I can get that sorted I'll edit the post with better pics. Cheers, Wolf Link to comment Share on other sites More sharing options...
Martinnfb Posted January 24, 2015 Share Posted January 24, 2015 I know how small those pieces are , ALL HIGHLY INHALABLE Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 24, 2015 Share Posted January 24, 2015 Thanks Kevin, now if I can only figure out why my pictures look so crappy! I'll have to look at my settings again as the pics look too grainy or not quite sharp enough. If I can get that sorted I'll edit the post with better pics. Cheers, Wolf They look OK to me Wolf. But then again, I'm half blind these days. Kev Link to comment Share on other sites More sharing options...
Wolf Buddee Posted January 24, 2015 Author Share Posted January 24, 2015 I know how small those pieces are , ALL HIGHLY INHALABLE I know what you mean Martin! Easily done through the nose too............ Cheers, Wolf Link to comment Share on other sites More sharing options...
Wolf Buddee Posted January 24, 2015 Author Share Posted January 24, 2015 They look OK to me Wolf. But then again, I'm half blind these days. Kev Nope, you're not blind at all! Need I remind you of the detail painting you did on the Dornier? You can't do that and be half blind. For some reason the pics don't have the same sharpness as I'd like. I've already replaced two of the previous pics and the new ones look a little better. It's way past my bedtime so I'm going to call it a day and leave the rest alone. Cheers, Wolf Link to comment Share on other sites More sharing options...
geedubelyer Posted January 24, 2015 Share Posted January 24, 2015 FWIW Wolf, your images look pin sharp on my monitor. Stunning detail. Link to comment Share on other sites More sharing options...
dodgem37 Posted January 24, 2015 Share Posted January 24, 2015 Color definition is off the charts, Wolf. Nice details abound. ' . . . black ignition wires . . .' Are they hollow or will they be drilled? Thank you. Sincerely, Mark Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 24, 2015 Share Posted January 24, 2015 HI Wolfe Incredible work and the detail painting is second to none! Just been to the ophthalmologist for a thorough exam and besides the usual beginnings of the normal eye suspects for a modeler in his late 60's, new specs are on the way. I'm also purchasing a new Optivisor with the highest magnification.: 8X, as mine is an OLD 7X, with years of hard service. Peter Link to comment Share on other sites More sharing options...
Guest Posted January 24, 2015 Share Posted January 24, 2015 Very sharp modeling my friend ! And the pics look great to me.......Harv Link to comment Share on other sites More sharing options...
scvrobeson Posted January 25, 2015 Share Posted January 25, 2015 Geez Wolf, your work is always so precise. The engine looks like it could start right up. Can't wait to see more. Matt Link to comment Share on other sites More sharing options...
