Guest Peterpools Posted October 14, 2014 Share Posted October 14, 2014 Hi Mark I've been slowly working the paint back and stripping the Sufa down, much as I did with BBD Mustang. I'm looking forward to your official Sufa start and will be following with wide open eyes and a note pad in hand. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
dodgem37 Posted November 1, 2014 Author Share Posted November 1, 2014 I was getting no-where fast on my SUFA build. The cockpit sidewalls were just killing me. So I decided to bring out the Mustang to see what I could see. I figured that whatever I was to do on this build had to go more smoothly than what was going on with the SUFA. While rummaging around for my references I came upon a publication of which I have no recollection of obtaining. So I leafed thru it and broke the categories (cockpit, wheel wells, etc.) down with labeled post-its. This pub turned out to be a gold mine for me. The publication is AN 01-60JE-4, Airplane Parts Catalogue Army Model P-51D, British Model Mustang IV, 25 July 1944, Revised 25 October 1944, Printed by Wm. B. Burord Printing Co. 10-25-44, if you're so inclined. All cockpit work: Drilled 2 holes. Added a latch. Located 2 rounded cornered triangles to the inside of the rudder pedals. Bolts also. From the front: To the right, as we are looking, of the 2 holes, on the small circular plate, Tamiya molded a small rod, which I chiseled off. It was replaced with an angled fuel line with vent tube. Black neoprene connection is drilled flexible plastic tube, from somewhere, with wire insulation as the hose. The gage has an asymmetrical flange, long flange toward the inside. The fuel inlet is surrounded with 1mm electrical wire heat-shrink tube, representing fastening bands. .010 rod represents band tightening heads. Lots of cool junk here. From the front: The semi-circle is the Filter-Air Vacuum Operated Instrument. It's supposed to have a support. I'll see if I can fit it in. This item actually has 2 outlet line conditions. I chose this one. Next is a hand held signal light, then the relief tube (stretched kit tree, telescoping Albion Alloys aluminum tube, solder), and over toward the top the Handle Assembly-Heating and Ventilating System Cold Air Control. Below the 'T' handle on the semi-circle is a pointer. The handle and pointer are in alignment. The rod is the valve connecting shaft. Not a lot of new stuff here, just a few. Left-most bottom bezel has a button. The other button broke off. Chiseled off the molded-in handle in the center and made one with more relief. Chiseled off the bezel and located a Fuel Filler Pump handle. Tried to make it oval. Finished this up. The Emergency Handle area. There is a small bump on top of the handle, just above the wired box. That represents a spring condition. There is a connection between the Emergency Handle Release located on the outside of the windscreen and the Emergency Handle. That's what that is. Left-most wiring loom has a .005 x .05mm fastener. Other looms and their fasteners are new. Inverted 'T' bracket is unidentified. Unidentified bracket to the left of the bell. Long wired tube to the right of the bell is the Radio Headset Connector, short one is the Microphone Type T-30 Connector. It is good to back in this saddle. Thank you for looking in. Sincerely, Mark red baron, Bill Cross, KiwiZac and 7 others 10 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 1, 2014 Share Posted November 1, 2014 Nice to see an update Mark! With the GB officially closed, I can move this to the WiP forum if you like. Kev dodgem37 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted November 1, 2014 Author Share Posted November 1, 2014 It's nice to finally get back to this model. What I've been doing the past couple of days has been loads of fun. Indeed, please move this to WiP. Thank you. Sincerely, Mark Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 1, 2014 Share Posted November 1, 2014 Indeed, please move this to WiP. Done! Kev dodgem37 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted November 1, 2014 Share Posted November 1, 2014 Brother bear What a great way to start November and to see the Mustang back out and the bench. Amazed as always at the level of detail you are able to create. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Tomek Posted November 2, 2014 Share Posted November 2, 2014 Love it, Mark! As usual, super clean. Can't stop being amaazed how some of you do it. dodgem37 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted November 2, 2014 Share Posted November 2, 2014 x2 Link to comment Share on other sites More sharing options...
Guest Posted November 2, 2014 Share Posted November 2, 2014 She's looking beautiful. Love all the little details.....Harv Link to comment Share on other sites More sharing options...
Loic Posted November 2, 2014 Share Posted November 2, 2014 A . MA . ZING !!! dodgem37 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted November 2, 2014 Author Share Posted November 2, 2014 Hey everyone! Thank you for dropping in and your comments. You know the old saying, 'Monkey see, monkey do!' Just tryin' to do what I see! Sincerely, Mark Link to comment Share on other sites More sharing options...
airscale Posted November 2, 2014 Share Posted November 2, 2014 that is some seriously nice detailing Mark.. ..love it, love watching a master at work on my favourite part of a build Peter dodgem37 1 Link to comment Share on other sites More sharing options...
Mal_Belford Posted November 2, 2014 Share Posted November 2, 2014 I Love that detailing alot... Where the heck ddid you get them ref photos to do that..... /MAl dodgem37 1 Link to comment Share on other sites More sharing options...
pg265 Posted November 2, 2014 Share Posted November 2, 2014 (edited) Hi, You really did a great detailing job!! BRAVO! Pascal Edited November 2, 2014 by pg265 Link to comment Share on other sites More sharing options...
Wolf Buddee Posted November 2, 2014 Share Posted November 2, 2014 Yeah baby! Dr. Mark is back in da house! Glad to see you're back on the Mustang and sorry to hear your frustrations with the SUFA. I ran in to something similar with my own Mustang build and have now started on a WnWs Pfalz. Nothing wrong with the Mustang kit, just my own ineptitude. One thing to watch for Mark, the port rudder cable runs under the trim console assembly. Tamiya has the trim console assembly going all the way to the floor so you'll either have to abbreviate the cable length or trim the console bottom to allow the cable to run underneath. I'm still trying to decide how I'll deal with that. You bein' back on the Mustang should be rear inspiration for me to get back on mine. Kind o' like an early Christmas present! Cheers, Wolf dodgem37 1 Link to comment Share on other sites More sharing options...
