mhorina
LSP_Members
  • Posts
    666
  • Joined
  • Last visited
Everything posted by mhorina
  1. Can anyone tell me the length of the blast tubes from the leading edge of the wing on a P47 Thunderbolt? I glued the receivers in the lower wing to stop the tubes. That way I can glue the top and bottoms together and paint the wings. All the available barrels and tubes on the aftermarket are one length. This is for a Trump Razor. ] Any help appreciated. TIA Mike Horina
  2. Looking at the pic posted above to my eyes it looks like the cable attaches to the frame for the armour glass. Maybe? Mike Horina
  3. Just received my Yak-3 kit ordered on 9/2/16. Cost 67.36 total with shipping to IL. As concerned the fabric surfaces, prime the areas, remove primer from frames that should be all the work needed if that. Photos seen else where showed exaggerated depth of fabric surface. But I don't believe it should be a problem. Of coarse that's my opinion, yours may vary. Mike Horina
  4. If you don't mind using masks for the insignia MAKETAR has all WWII variations and sizes available. Plus some letters and numbers. Mike Horina
  5. 'D' thanks for the link to the earlier color discussion. KEV sent you a PM Mike Horina
  6. Ron, thank you for the LSP links. Jennings, thank you for the paint FS numbers. Kevin, my box art is different then either of the kits in the 2 WIP shortcuts that Ron posted and is a 2003 release with decal as in the release you have in the WIP and has the reworked exhaust.as the other kit WIP Mike Horina
  7. Has anyone built this kit? Any helpful build hints? Is there any hobby paint available now for the orange paint? According to the instructions the FS# is 12197. How much weight do you need so you don't have to use the clear support Revell included? TIA Mike Horina
  8. Just received my order. 11 days Czech Republic to IL
  9. Everyone does things different. While I used the Aires wheel bay I didn't use the Aires Mounting holes for the landing gear. There is a minimal space to fill between the Aires part and the kits sockets for the gear. I found it easy to install doing it that way. But every one has there own way of doing things. Hope this may be of help to someone. Mike Horina
  10. Harold, Please put me on the list for 'the whole ball of wax' also. That's the T28 stuff. Mike Horina
  11. According to the picture posted above of MT 423 it appears to have the 'Erla' version starboard gun cover with 2 bulges. This new kit release then appears to have all the kit specific parts from the G-6 and G-14 kits. Mike Horina
  12. Harold, Anything you would do is very much appreciated. Not only because of the workmanship you do but the outstanding fit of the items you do due. Mike Horina
  13. Bob, I'm sure I and many others here on LSP would appreciate that you would do that. TIA Mike Horina
  14. Not an expert but the Amur sets for the Revell G-6 makes for a easier build and only a few swipes with a sanding stick needed to make a excellent fit. Easy Peasy and looks great. Easiest to use AM set I ever used Mike Horina
  15. Eli, How about 'Iowa Beaut'?
  16. I wasn't sure if I had seen those clips on the wings so I didn't mention them in the earlier post. They can be seen in both photos and in the top picture you can make out the holes in the front and back near the bottom of the brace
  17. If I recall correctly there are what appear to be ropes/cord or? that connect the braces to each other. 1 fore and another aft. Running over the top of the tank. While looking at various photos the braces are never seen alone on the aircraft but are placed on the ground under the wing. Probably bevel edged at least on 1 edge and tightened up on the tank by those devises. And leave when the tanks are dropped. Mike Horina
  18. One item in the P-51D/K Tamiya kit that is in no other kit that I am aware of are the 110 gallon teardrop shaped under wing gas tanks. And while they are included in the kit the wooden sway braces used with them are not included. Mike West has/ had these tanks and the sway braces in his list. Mike Horina
  19. I have a Revell Germany kit Seafire Mk IB kit # 4780, picture is in the Box lid archive, it has an original Revell kit with engraved MkI fuselage and a engraved set of wings. The Seafire kit was a trade and had no instruction sheet. The bottom wing has a number molded on 4555-0620. I don't have ,at present a MkI Spitfire kit had that about 35 years ago, but got the instruction sheet of the original kit and the Seafire kit off the web. Interestingly the part numbers for the kits are the same. Only some are shaded as not for use. The fuselage assembly part numbers and the wing assembly part numbers are the same on the 2 different kits. Old school interior parts, does anyone know if the new MkII Revell interior parts will fit in the old kit fuselage parts. I seem to remember a post about the differences in fuselage shapes between the new MkII and the old MkI kits anyone know were to find that article ? Mike Horina
  20. Harv, Shipped on August 24 invoice in the box. Unlike when I got my Corsair from Hobby Link /Japan, this time its the Export version with the extra clear parts. Mike Horina
  21. Luckey Models $135 and change arrived today at 11:30 AM. 20 miles west of Chicago. Mike Horina
  22. Matt, I thought that most 109 Erla G-10s were delivered with the small wheel well bumps. And if you have both of the Revell 109 releases and some Hase kits there are about 5 or 6 different rudder designs to choose from and both sizes of ww bumps in the Revell kits. Mike Horina
  23. You can find this in the Ready for Inspection forum Operation Torch P-40F-20 Mike Horina
