Harold Posted October 18, 2015 Share Posted October 18, 2015 (edited) Just a bit of cleanup at the rod join and it's ready to be cast. [/url] Edited October 18, 2015 by Harold scvrobeson, Girlscanplay2 and ziggyfoos 3 Link to comment Share on other sites More sharing options...
ssculptor Posted October 18, 2015 Share Posted October 18, 2015 I have a lot of respect for you who use antennae that are made of polystyrene or resin plastic. These things are so fragile that one has to keep them in a case or run the risk of someone touching them and breaking the silly things off. I prefer to use wire that is brazed, soldered or silver soldered together. Then I can relax when transporting them and showing them anywhere. I am of the ham fisted persuasion and I like to touch, handle, lift up and view from many angles the models I make. Thus I take my hat off to you guys who tolerate such fragile plastic things on your models. Of course now they have carbon fiber small diameter rods and I will look into using those. As to the antenna shown above, I would cut off the long small diameter rod, drill out the nice thick base part and insert a metal wire into it. But that is just how I would do things. You guys do whatever you want. Stephen Girlscanplay2 and Harold 2 Link to comment Share on other sites More sharing options...
Martinnfb Posted October 18, 2015 Share Posted October 18, 2015 please excuse my dull question. Is this for A-6 Intruder? Link to comment Share on other sites More sharing options...
Harold Posted October 18, 2015 Author Share Posted October 18, 2015 I have a lot of respect for you who use antennae that are made of polystyrene or resin plastic. These things are so fragile that one has to keep them in a case or run the risk of someone touching them and breaking the silly things off. I prefer to use wire that is brazed, soldered or silver soldered together. Then I can relax when transporting them and showing them anywhere. I am of the ham fisted persuasion and I like to touch, handle, lift up and view from many angles the models I make. Thus I take my hat off to you guys who tolerate such fragile plastic things on your models. Of course now they have carbon fiber small diameter rods and I will look into using those. As to the antenna shown above, I would cut off the long small diameter rod, drill out the nice thick base part and insert a metal wire into it. But that is just how I would do things. You guys do whatever you want. Stephen Could it be possible for them to be inserted into the pylon? There has to be a hole drilled into the pylons anyway, maybe not glue them in, just push them into the holes. (if the holes are very well drilled) Girlscanplay2 1 Link to comment Share on other sites More sharing options...
Harold Posted October 18, 2015 Author Share Posted October 18, 2015 please excuse my dull question. Is this for A-6 Intruder? Yes. Link to comment Share on other sites More sharing options...
ssculptor Posted October 18, 2015 Share Posted October 18, 2015 Could it be possible for them to be inserted into the pylon? There has to be a hole drilled into the pylons anyway, maybe not glue them in, just push them into the holes. (if the holes are very well drilled) It would help if one has a micrometer handy and knows how to read it. You can always buy "drill rod" of various diameters and drill bits down to #60 are readily available. Thus you might be able to select a drill size and drill rod to be able to insert the wire into the hoed without glue. Then you can remove it for travel and transportation. There are many possibilities. I need things like this since I am the proverbial bull in a china shop. Stephen Harold 1 Link to comment Share on other sites More sharing options...
petrov27 Posted October 18, 2015 Share Posted October 18, 2015 (edited) Could it be possible for them to be inserted into the pylon? There has to be a hole drilled into the pylons anyway, maybe not glue them in, just push them into the holes. (if the holes are very well drilled) I think that would probably work but I do not think these should be that fragile even in resin? My pylon leading edges are all ready drilled to accept them - let me know if you want someone to test a set for fit! Edited October 18, 2015 by petrov27 Harold 1 Link to comment Share on other sites More sharing options...
Harold Posted October 19, 2015 Author Share Posted October 19, 2015 I think that would probably work but I do not think these should be that fragile even in resin? My pylon leading edges are all ready drilled to accept them - let me know if you want someone to test a set for fit! There ya go...Looks like tomorrow I will have them in rubber. SOON. Link to comment Share on other sites More sharing options...
Harold Posted October 21, 2015 Author Share Posted October 21, 2015 Master is finished, it will go into rubber today. The pic shows some sanding dust, but is what you will get. I added a scribe mark on the tail end that indicates where it should be in the pylon. allthumbs, Tony T and Zero77 3 Link to comment Share on other sites More sharing options...
Out2gtcha Posted October 21, 2015 Share Posted October 21, 2015 (edited) I have a lot of respect for you who use antennae that are made of polystyrene or resin plastic. These things are so fragile that one has to keep them in a case or run the risk of someone touching them and breaking the silly things off. I prefer to use wire that is brazed, soldered or silver soldered together. Then I can relax when transporting them and showing them anywhere. I am of the ham fisted persuasion and I like to touch, handle, lift up and view from many angles the models I make. Thus I take my hat off to you guys who tolerate such fragile plastic things on your models. Of course now they have carbon fiber small diameter rods and I will look into using those. As to the antenna shown above, I would cut off the long small diameter rod, drill out the nice thick base part and insert a metal wire into it. But that is just how I would do things. You guys do whatever you want. Stephen IM plastic might be, but Resin is not that fragile. Ive been building with, and using it my whole modeling career, an although all resin composition differs from one manu to the next, and sometimes even from one pour to the next, after using Harold's resin and looking at this antenna, I can say with a fair bit of confidence you are NOT going to just snap these off at the drop of a hat. From my experience, Harold's resin is no where near that brittle. Dont get me wrong, this will be delicate and should be handled with care, but there is no need to go to the trouble of inserting metal into the antenna.................... Actually also from my experience, with stuff that sticks out this far occasionally its even better to have something like resin that is a tad flexible VS something like white or yellow brass that is VERY rigid, as if you bumped it really hard, instead of just breaking or bending the antenna, I have found (depending on how/how well its secured) that sometimes if things like this are made with rigid brass, they dont give at ALL and they actually break the wing or pylon its attached to instead. So instead of fixing or making a new pitot tube or antenna, you end up having to patch/fix your wing or fuselage or pylon instead, which most of the time is a LOT more work. ASK ME HOW I KNOW THIS. Edited October 21, 2015 by Out2gtcha Harold 1 Link to comment Share on other sites More sharing options...
Harold Posted October 21, 2015 Author Share Posted October 21, 2015 IM plastic might be, but Resin is not that fragile. Ive been building with, and using it my whole modeling career, an although all resin composition differs from one manu to the next, and sometimes even from one pour to the next, after using Harold's resin and looking at this antenna, I can say with a fair bit of confidence you are NOT going to just snap these off at the drop of a hat. From my experience, Harold's resin is no where near that brittle. Dont get me wrong, this will be delicate and should be handled with care, but there is no need to go to the trouble of inserting metal into the antenna.................... Actually also from my experience, with stuff that sticks out this far occasionally its even better to have something like resin that is a tad flexible VS something like white or yellow brass that is VERY rigid, as if you bumped it really hard, instead of just breaking or bending the antenna, I have found (depending on how/how well its secured) that sometimes if things like this are made with rigid brass, they dont give at ALL and they actually break the wing or pylon its attached to instead. So instead of fixing or making a new pitot tube or antenna, you end up having to patch/fix your wing or fuselage or pylon instead, which most of the time is a LOT more work. ASK ME HOW I KNOW THIS. Just for the heck of it, I tried to break one I have cast. NOPE, it will bend a bit, but it would take several tries by bending back and forth before it gives up. Out2gtcha and Zero77 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted October 21, 2015 Share Posted October 21, 2015 Just for the heck of it, I tried to break one I have cast. NOPE, it will bend a bit, but it would take several tries by bending back and forth before it gives up. Exactly as I figured Harold. Good news! Harold 1 Link to comment Share on other sites More sharing options...
Magic Mike Posted October 22, 2015 Share Posted October 22, 2015 Nice work Harold...as usual! MM Harold 1 Link to comment Share on other sites More sharing options...
ziggyfoos Posted October 27, 2015 Share Posted October 27, 2015 Harold any update on these? thanks Harold 1 Link to comment Share on other sites More sharing options...
Harold Posted October 27, 2015 Author Share Posted October 27, 2015 Harold any update on these? thanks I am casting them now. They are a bit of a pain to get the resin to flow all the way to the end. I think I have it worked out, I will know today. Zero77 1 Link to comment Share on other sites More sharing options...
