LSP_Kevin Posted December 3, 2015 Share Posted December 3, 2015 Ambitious work, John! But I'm sure you'll pull it off. Kev Link to comment Share on other sites More sharing options...
Pastor John Posted December 4, 2015 Author Share Posted December 4, 2015 Think I might be nearly ready to spray interior - just need to add the cross over bracing at back of rear fuel tank and i am done for now mywifehatesmodels, AndersN and Martin388 3 Link to comment Share on other sites More sharing options...
Pastor John Posted December 4, 2015 Author Share Posted December 4, 2015 Dymo tape is a realistic thickness for the rear fuel tank support straps if having the rear hatch open AndersN, mywifehatesmodels and Kagemusha 3 Link to comment Share on other sites More sharing options...
stevegallacci Posted December 6, 2015 Share Posted December 6, 2015 Minor additional info re paint. The whole standard gun nose group was assembled as a unit and made out of steel, with the exception of the nose cone(?) and maybe the gun bay hatches, so would be at least primed, most likely in a lt. grey. The U3 nose was a modified standard nose so would be siimliarly finished. Nose wheel well as likely in a primer color as standard 02. All the gear doors would most likely be painted in 76 inside and out. While the main gear wells would most likley be unpainted, the cockpit tub could be painted as it was a separate sub-assembly. The wing spars were painted as well, as they were made of steel and needed the rust control. Link to comment Share on other sites More sharing options...
stevegallacci Posted December 6, 2015 Share Posted December 6, 2015 A detail FYI- the little round panels on the fuselage sides seem to be fictions. The '262 had little holes for lift slings for the fuel tanks, and the holes simply got doped patches over them, not the riveted mini-panels on the kit. Link to comment Share on other sites More sharing options...
Pastor John Posted December 6, 2015 Author Share Posted December 6, 2015 Many thanks - i had not checked that detail yet and may well have missed it - trying to get inside done first so thanks for colour info. I have been lent the HT Model Special vol and it confirms what you say about colours Best wishes Link to comment Share on other sites More sharing options...
Nigels modelling bench Posted December 6, 2015 Share Posted December 6, 2015 How did you manage to get hold of sprue M John? Link to comment Share on other sites More sharing options...
Pastor John Posted December 6, 2015 Author Share Posted December 6, 2015 Hi Nige, A kind modeller on this forum gave it to me as a gift! Spirit of Christmas and spirit of modelling! LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Guest Posted December 6, 2015 Share Posted December 6, 2015 Looking very good John !......Harv Link to comment Share on other sites More sharing options...
Pastor John Posted December 7, 2015 Author Share Posted December 7, 2015 Ok now i think I have done all I can do before spraying Piprm 1 Link to comment Share on other sites More sharing options...
JRutman Posted December 7, 2015 Share Posted December 7, 2015 Really nice work so far!! J Link to comment Share on other sites More sharing options...
Pastor John Posted December 17, 2015 Author Share Posted December 17, 2015 Wow I do not think I will make many 1/32 Me 262s in my life time - so much work before you can get fuselage together! Enjoying it all the same. Just need to dress the seam between upper and lower cockpit kit parts - remove the lugs etc and then can spray - build and sort out the dreaded plumbing and wiring! Martin388, chukw, tucohoward and 4 others 7 Link to comment Share on other sites More sharing options...
mywifehatesmodels Posted December 17, 2015 Share Posted December 17, 2015 (edited) Have a Trump kit in the stash that I will build someday, but you've set the bar high enough to be intimidating, John! Cheers, John Edited December 17, 2015 by mywifehatesmodels Link to comment Share on other sites More sharing options...
Guest Posted December 17, 2015 Share Posted December 17, 2015 SWEET JESUS ! Thats some good work !......Harv Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 17, 2015 Share Posted December 17, 2015 Yeah, this is some very nice work, John! Kev Link to comment Share on other sites More sharing options...
