Jack Posted May 28, 2007 Share Posted May 28, 2007 ...i knew i've seen this beast somewhere, sometime.......... Keep it up and going Iain.....good show. J. Link to comment Share on other sites More sharing options...
Guest UMIRESIN Posted May 28, 2007 Share Posted May 28, 2007 Morning all Lian ? nevermind what I said before about you having storage issues when your 1/32 Super Constellations all done ( snikker ) Link to comment Share on other sites More sharing options...
Iain Posted May 28, 2007 Author Share Posted May 28, 2007 Crumbs!! See - my project is *much* smaller!! Do you have a link to a build site for that? Iain Uilleann 1 Link to comment Share on other sites More sharing options...
Iain Posted July 26, 2007 Author Share Posted July 26, 2007 Apologies - a bit slow - but tail feathers now had a lot of work... Filled with Polyurethane resin... Cut, sanded, filled, re-shaped... It's getting there... Want to get each component spot on, primered and surface scribed/rivetted - before joining it all together and doing the fillets... As a quick reminder of the size - Trumpeters P-40 again for comparison! Oh - and the build is now in memory of Dave (UMI Resins) RIP - thanks for all the help and inspiration mate! Iain Derek B and Landrotten Highlander 2 Link to comment Share on other sites More sharing options...
Guest Rigor Posted July 28, 2007 Share Posted July 28, 2007 Wow that's hugh can't wait to see this one Link to comment Share on other sites More sharing options...
thierry laurent Posted August 3, 2007 Share Posted August 3, 2007 Iain, I do not know if this may be useful for you but I took some details pics (engines and landing gear) of the Breitling Constellation during the Bourget meeting. Let me know if you want them (just send me a mail). Regards. Link to comment Share on other sites More sharing options...
Iain Posted August 26, 2007 Author Share Posted August 26, 2007 Hi Thierry, Any pix appreciated - several people have already kindly sent me images - including Bruce Radebough who sence me a CD full of the one just outside his office Main area I'm weak on photo's wise is the flap areas - if you have a few shots of that area would be great... Iain Link to comment Share on other sites More sharing options...
Iain Posted January 15, 2009 Author Share Posted January 15, 2009 OK - Cover me - I'm going in (again!) Having just spent some time wading through a rather nice 1:48 B-47 build over on ARC, and a post re scratch building one in 1:48 over on Hyperscale I can feel Connies Mojo coming back... Camera at friends 'till Monday - but I promise to start posting progress again. Perhaps I might avoid all the gentle ribbing I get every year at Telford! Iain 32SIG http://www.skywriters.net Link to comment Share on other sites More sharing options...
Iain Posted May 8, 2011 Author Share Posted May 8, 2011 (edited) OK - as promised - some updates on LSP Today I have mostly been printing out scans of the Heller Constellation - enlarged by 225% - and stuck together to compare with the kit supplied plans and the parts. To be honest I *have* been putting this off because I was concerned about what I'd find. Kit dyelines and the scans. Good news is that the fuselages match very well. 109G is there to give a sense of size (also 1:32). Yup - it's big (kitchen floor safest place to lay everything out). Fuselage half laid over the scans - rather good likeness actually!! Just some tweaks to the rear shape-wise - and I was already expecting this. Will also cure the somewhat 'blunt' ending to the fuselage in plan as moulded. Wings - if you recall I had my doubts as to the span as moulded - and the spacing between cowlings - based upon comparison with the kit drawings. Well, the scans of the Heller kit agree perfectly on how far out the cowl spacing is - but also suggest the outer wing sections are even shorter that first thought. It's also highlighted the tip tanks being way oversize - out with the razor saw! Have already got my 'cut and shut' planned - may perform that this evening. Tail fins had been modded as per photos and drawings - and they match the scaled up Heller items nicely - bar a few tweaks Right - off to do some more measuring - and some cutting... Iain Edited May 8, 2011 by 32SIG Link to comment Share on other sites More sharing options...
Royboy Posted May 8, 2011 Share Posted May 8, 2011 Does one spy a new messybit model in the collection old chap? Looks nice, not sure if I've seen that one before though. Oh, and good luck with your odd trimmings here and there! Roy. Link to comment Share on other sites More sharing options...
Iain Posted May 8, 2011 Author Share Posted May 8, 2011 Does one spy a new messybit model in the collection old chap? Looks nice, not sure if I've seen that one before though. Oh, and good luck with your odd trimmings here and there! Roy. Hiya Roy, 109 you've seen - 21st Century one I had at Telford. Odd trimmings indeedy! But about time I did something concrete - determined to have something that shows good progress by Telford so I can stop the Mickey taking! Iain Link to comment Share on other sites More sharing options...
Iain Posted May 8, 2011 Author Share Posted May 8, 2011 Been carefully marking out positions and sizes of fuselage windows: Holes so far drilled out to 7mm and 8mm - the latter will be opened out to 10mm diameter. Have used wood drills as these give precision placement on the plastic and a power driver as this turns at far lower speeds than a drill and prevents heat/plastic melting around each hole. The nose gear bay all marked out and exactly 2.25 times larger (linear) compared to the Heller 1:72 kit. Need to pour over photos now before I make the cuts to ensure all is good with regard to juxtapositions of windows/doors etc.. More later in the week... Iain Link to comment Share on other sites More sharing options...
Christian Posted May 9, 2011 Share Posted May 9, 2011 Hi Iain, Great to see that you are working on "Connie" again. Will be following this tread. Love seeing vac kits being built. Christian Link to comment Share on other sites More sharing options...
JRutman Posted May 9, 2011 Share Posted May 9, 2011 Nice to see this back in progress. Looking good. J Link to comment Share on other sites More sharing options...
Shawn M Posted May 9, 2011 Share Posted May 9, 2011 very cool....now someone needs to VAC a 1/32 PBM Mariner for me. Derek B 1 Link to comment Share on other sites More sharing options...
