thierry laurent Posted August 10, 2023 Share Posted August 10, 2023 Hi guys, According to a local reseller the Cameo may cut up to 3mm whereas the Portrait is limited to 2mm. I want to use it to cut masks in Oramask or Tamiya-like tape but also thin plastic sheet. Of course the maximum thickness given by the manufacturer is intended for softer materials, not polystyrene. Nonetheless, to make cut into 0.5mm I'm wondering if the portrait will be sufficient? Has anyone experience of such a use and in that case are you using a specific blade and cutting mat or the standard ones? Thanks in advance. Thierry Link to comment Share on other sites More sharing options...
red Dog Posted August 11, 2023 Share Posted August 11, 2023 I regularly cut 0.3mm styrene sheet with my Cameo with a standard blade It requires multiple passes and it's hard on the blade but it always worked for me. 0.5mm never tried They do have specific blades for cutting though thicker material but these blades can't do corners, it's rather for large shapes mozart, chukw and Uncarina 3 Link to comment Share on other sites More sharing options...
thierry laurent Posted August 11, 2023 Author Share Posted August 11, 2023 4 hours ago, red Dog said: I regularly cut 0.3mm styrene sheet with my Cameo with a standard blade It requires multiple passes and it's hard on the blade but it always worked for me. 0.5mm never tried They do have specific blades for cutting though thicker material but these blades can't do corners, it's rather for large shapes Thanks very much Olivier. I could have directly asked you as I'm remembering you made such parts for your A-10! So, it looks the Cameo with some spare blades is probably the best option even if I do not like the fact it is clearly more cumbersome! Where did you get 0.3mm A4 sheets? Recently I could only find some on the Schleiper art store. Link to comment Share on other sites More sharing options...
red Dog Posted August 11, 2023 Share Posted August 11, 2023 Schleiper indeed. Link to comment Share on other sites More sharing options...
mozart Posted August 12, 2023 Share Posted August 12, 2023 (edited) Just another Silhouette Cameo (2) user’s opinion Thierry; I use mine quite regularly to cut 10 thou (0.25mm) plastic sheet and with the heavier blade 20 thou. You have to experiment with settings but it’s all do-able. This is the framing cut from 10 thou for a Harvard: Edited August 12, 2023 by mozart Martinnfb, thierry laurent, chukw and 3 others 5 1 Link to comment Share on other sites More sharing options...
red Dog Posted August 12, 2023 Share Posted August 12, 2023 I tried and I failed Mozart. If you have a few advices or more specifics about using that blade, i'd love to try myself. It makes no point to do this with the standard blade if there's a better way I tried with the orange 2mm blade, so maybe that wasn't the best one? Link to comment Share on other sites More sharing options...
thierry laurent Posted August 12, 2023 Author Share Posted August 12, 2023 59 minutes ago, mozart said: Just another Silhouette Cameo (2) user’s opinion Thierry; I use mine quite regularly to cut 10 thou (0.25mm) plastic sheet and with the heavier blade 20 thou. You have to experiment with settings but it’s all do-able. This is the framing cut from 10 thou for a Harvard: Thanks Max. You confirmed my feeling I need getting the Cameo. As stressed by Olivier, the main question is know which blade to use? P.S. That Harvard is a marvel...! Link to comment Share on other sites More sharing options...
mozart Posted August 12, 2023 Share Posted August 12, 2023 I’m not sure what advice to offer! These are the two blades that I use, the “heavy duty” one on the left and “standard” on the right, both at their fullest settings: These are the settings I use for 10 thou plastic: Hope this helps. red Dog, chukw, LSP_Kevin and 4 others 3 4 Link to comment Share on other sites More sharing options...
denders Posted August 12, 2023 Share Posted August 12, 2023 (edited) I used my cameo 4 to cut rings from 0.010" for this build. Page 3 if it doesn't automatically go there. EdIT: I think I just used the autoblade. Edited August 12, 2023 by denders thierry laurent 1 Link to comment Share on other sites More sharing options...
mozart Posted August 14, 2023 Share Posted August 14, 2023 Also see here. thierry laurent 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted August 17, 2023 Author Share Posted August 17, 2023 Thanks very much guys. I ordered a Cameo with different blades and should get it next week! Link to comment Share on other sites More sharing options...
thierry laurent Posted September 3, 2023 Author Share Posted September 3, 2023 When you start creating parts it is hard to stop... I've already created more than 100 parts for the interior of my Japanese Learjet! LSP_Kevin, mozart and chaos07 3 Link to comment Share on other sites More sharing options...
mozart Posted September 4, 2023 Share Posted September 4, 2023 21 hours ago, thierry laurent said: When you start creating parts it is hard to stop... I've already created more than 100 parts for the interior of my Japanese Learjet! …..and it shows that with a bit of thought and experimentation a Silhouette machine is more than just a mask cutter. I’ve even used it to cut out sections of Bare Metal Foil to apply to my Fury: TankBuster and thierry laurent 2 Link to comment Share on other sites More sharing options...
