LSP_K2 Posted April 28, 2022 Share Posted April 28, 2022 Regarding the WNW Albatros D.V and D.Va kits, are there parts in both kits to do either the D.V or D.Va aircraft? Thanks a bunch. Link to comment Share on other sites More sharing options...
vince14 Posted April 28, 2022 Share Posted April 28, 2022 It depends on what boxing you have. If it's one of the later 'brown box' kits, then parts for both types are included. If it's one of the earlier, original boxings then the parts are specific to that version. LSP_K2, scvrobeson, Gary Needham and 1 other 4 Link to comment Share on other sites More sharing options...
phasephantomphixer Posted April 28, 2022 Share Posted April 28, 2022 Short answer is No from the two I have, but it is a small no as it is only due to a sprue gate change for sprue A which has slightly different ailerons and control stick. Looks to me if you were to add the horn fairings (check the instructions for the Richthofen kit #32601) and a small round part at end of stick, could pass. Otherwise, all plastic is identical between kit 32047 D.Va and kit 32601 D.V that I can see. HTH LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted April 29, 2022 Author Share Posted April 29, 2022 Thanks for the answers, fellas. Looks like brown box it will be then (assuming I can find one at a decent price). phasephantomphixer 1 Link to comment Share on other sites More sharing options...
jeroen_R90S Posted May 3, 2022 Share Posted May 3, 2022 (edited) On 4/28/2022 at 11:22 PM, vince14 said: It depends on what boxing you have. If it's one of the later 'brown box' kits, then parts for both types are included. If it's one of the earlier, original boxings then the parts are specific to that version. The oddball in-between Jasta 5 boxing has the same sprues containing both versions. (I split one with another modeller, which made selecting decals easier as both versions were included. We sold the 3rd model later giving both of us a very economic Albatros) Given the current WNW state splitting up a J5 box probably isn't very viable any more The PE sheet is different as well between the older, specific boxings, and the Jasta 5 and brown boxes. Jeroen Edited May 3, 2022 by jeroen_R90S LSP_K2 1 Link to comment Share on other sites More sharing options...
Dave J Posted May 3, 2022 Share Posted May 3, 2022 If you are looking for a Albatros kit that has both DV & D.Va parts within it, you will need a Jasta 5 or one of the Brown kit boxings. The Manfred and the Standard releases only contain the parts for the stated variant on the box. Iain and LSP_K2 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 3, 2022 Author Share Posted May 3, 2022 13 hours ago, jeroen_R90S said: The oddball in-between Jasta 5 boxing has the same sprues containing both versions. (I split one with another modeller, which made selecting decals easier as both versions were included. We sold the 3rd model later giving both of us a very economic Albatros) Given the current WNW state splitting up a J5 box probably isn't very viable any more The PE sheet is different as well between the older, specific boxings, and the Jasta 5 and brown boxes. Jeroen Excellent. Thanks. 11 hours ago, Dave J said: If you are looking for a Albatros kit that has both DV & D.Va parts within it, you will need a Jasta 5 or one of the Brown kit boxings. The Manfred and the Standard releases only contain the parts for the stated variant on the box. Thanks a bunch, Dave. You doing OK? Link to comment Share on other sites More sharing options...
