LSP_Kevin Posted May 30, 2021 Share Posted May 30, 2021 It's a shame about the paint issues, but it's still looking pretty good, Alex. In, fact the tail looks amazing! I'm sure you'll come up with a workable solution. Kev Alex 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted May 30, 2021 Share Posted May 30, 2021 It is looking good, even with the paint issues. To keep that from happening, I always try and remove masks as soon as possible after airbrushing. Masks will cut through the paint much more cleanly when the paint has not cured yet. LSP_K2 and Alex 2 Link to comment Share on other sites More sharing options...
Alex Posted May 30, 2021 Author Share Posted May 30, 2021 1 hour ago, LSP_Ray said: It is looking good, even with the paint issues. To keep that from happening, I always try and remove masks as soon as possible after airbrushing. Masks will cut through the paint much more cleanly when the paint has not cured yet. And that's the funny thing - I pulled the "AeroPeru" mask off not 15 minutes after painting (for exactly the reason you state, plus impatience). And paint came off with it. I think it must have been something greasy I got on the white layer and failed to clean off. Link to comment Share on other sites More sharing options...
LSP_Ray Posted May 30, 2021 Share Posted May 30, 2021 In that case, you could be right. Alex 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 31, 2021 Share Posted May 31, 2021 Still looks damn nice......and looks like most of those seem like correctable issues too. Alex 1 Link to comment Share on other sites More sharing options...
Alex Posted May 31, 2021 Author Share Posted May 31, 2021 Masked up to try & fix the stripes on the port side. Starboard side is good enough I decided to leave it alone. I wiped it down with soapy water beforehand to remove anything greasy. After: Maybe not perfect but definitely better. I'll wait a day and then decide if I'm going to try and repaint the AreoPeru logos (both sides are bad) or give the decals a shot. Brett M, Jeff T and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
Alex Posted June 1, 2021 Author Share Posted June 1, 2021 I opted for the decal route to address the logos. It worked out OK - the decal over paint results in a darker red, but it's similar to the darker red accent on the rudder, so it's not visually disruptive, even if perhaps not optimally accurate. Overall this was an OK kit to build - no more than the expected amount of "proper modeling" for a short-run kit, with the overly deep and wide panel lines being probably the most obvious issue - a more ambitious modeler than I might have filled them in and re-scribed much finer lines. I used a combo of the AM Nazca decals and the kit decals, and both performed quite nicely - no issues/complaints. One thing I clearly did do wrong was to put the gray/white border too high up on the fuselage, which led to the red stripe being too high up and running afoul of the cockpit windows. Nothing to do about it now... The variation in metallic tones on the engine nacelles doesn't *exactly* match the photos I saw, but I think it does give a good impression of the way they are - zonally different in shade and luster from front to back. And importantly, with this wrapped up the decks are now officially clear to start the next warbird model for the Target for Today GB. Jeff T, The Madhatter, D.B. Andrus and 8 others 11 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 1, 2021 Share Posted June 1, 2021 That looks fantastic, Alex! Congrats on another super build. Kev Alex 1 Link to comment Share on other sites More sharing options...
Alex Posted June 1, 2021 Author Share Posted June 1, 2021 3 minutes ago, LSP_Kevin said: That looks fantastic, Alex! Congrats on another super build. Kev Thanks Kev. I’m already chewing over what the next 1:144 build should be. Thinking perhaps a small prop liner since I’ve done a couple of big jets recently. Going to hold off until I’ve got some good traction on my GB Airacobra though - too confusing to start two projects in parallel... LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 1, 2021 Share Posted June 1, 2021 31 minutes ago, Alex said: Thanks Kev. I’m already chewing over what the next 1:144 build should be. Thinking perhaps a small prop liner since I’ve done a couple of big jets recently. I wouldn't recommend the Minicraft Electra! Kev Alex 1 Link to comment Share on other sites More sharing options...
Alex Posted June 2, 2021 Author Share Posted June 2, 2021 2 hours ago, LSP_Kevin said: I wouldn't recommend the Minicraft Electra! Kev I actually have one on the shelf. I'll heed your warning and steer clear for now! LSP_Kevin 1 Link to comment Share on other sites More sharing options...
