Paul2660 Posted February 2, 2021 Posted February 2, 2021 Title says it all. What PSI setting do you recommend for Me Paint acrylic lacquers. I am using a .03 nozzle. Thanks Paul C Out2gtcha 1
Giorgos Posted February 20, 2021 Posted February 20, 2021 I spray them around 10psi and the results it's good.
Woody V Posted February 20, 2021 Posted February 20, 2021 Air pressure and paint viscosity are variables, the same as shutter speed and aperture in photography, so there is no "correct" air pressure for spraying paint just like there is no "correct" shutter speed when taking photographs. A-10LOADER and scvrobeson 2
Greif8 Posted February 21, 2021 Posted February 21, 2021 I generally spray them at 10-15 psi and get good results. Ernest
CraigC Posted January 15, 2022 Posted January 15, 2022 Just wondering if anyone uses additional MRP thinners or the MRP retarding thinners. If so in what circumstances?
Woody V Posted January 19, 2022 Posted January 19, 2022 (edited) On 1/15/2022 at 7:19 AM, CraigC said: Just wondering if anyone uses additional MRP thinners or the MRP retarding thinners. If so in what circumstances? I generally thin 50/50 Mr. Paint with Leveling Thinner for basic painting but I mix by eye and might add more just because it doesn't look right. I have found that sometimes the paint in the jar is thicker than it should be. Adding much more thinner would be the ticket if you wanted very light coverage like to slightly post shade panel lines, etc. Edited January 20, 2022 by Archer Fine Transfers Clarified that I'm referring to Mr. Paint
BarryWilliams Posted January 19, 2022 Posted January 19, 2022 11 minutes ago, Archer Fine Transfers said: I generally thin 50/50 with Leveling Thinner for basic painting but I mix by eye and might add more just because it doesn't look right. I have found that sometimes the paint in the jar is thicker than it should be. Adding much more thinner would be the ticket if you wanted very light coverage like to slightly post shade panel lines, etc. I have never thinned MRP and have never seen the need to do so. They spray fine right out of the bottle even when spraying fine lines or shading. I have used them for 5 years exclusively through the airbrush. Out2gtcha and ivanmoe 2
Out2gtcha Posted January 19, 2022 Posted January 19, 2022 1 hour ago, BarryWilliams said: I have never thinned MRP and have never seen the need to do so. They spray fine right out of the bottle even when spraying fine lines or shading. I have used them for 5 years exclusively through the airbrush. This is me to a tee. Same, same, I have honestly never yet found a need to thin them. From everything from ultra fine line mottling work, to large overall bodies of paint at the same time, I've found MRP sprays perfectly right OOB. I normally spray anywhere from 10 to 20 lbs pressure depending on if I'm doing fine line work or large blocks of color. ivanmoe, BarryWilliams and Paul2660 3
CraigC Posted January 20, 2022 Posted January 20, 2022 thanks for your replies Disappointed that paint isn't available in Australia now.
Woody V Posted January 20, 2022 Posted January 20, 2022 (edited) 17 hours ago, BarryWilliams said: I have never thinned MRP and have never seen the need to do so. They spray fine right out of the bottle even when spraying fine lines or shading. I have used them for 5 years exclusively through the airbrush. This thread has gone off-topic. MRP and Mr. Paint are two entirely different paint lines, but Mr. Paint is sometimes referred to as MRP due to the naming history of MRP. My comments are regarding Mr. Paint. Edited January 20, 2022 by Archer Fine Transfers
LSP_Kevin Posted January 20, 2022 Posted January 20, 2022 8 hours ago, Archer Fine Transfers said: This thread has gone off-topic. MRP and Mr. Paint are two entirely different paint lines, but Mr. Paint is sometimes referred to as MRP due to the naming history of MRP. My comments are regarding Mr. Paint. I think you've confused things a little here, Woody. MRP is simply a rebranding of Mr. Paint, since people were confusing it with the Mr. Color range from Gunze (which is an entirely different line). Kev ivanmoe 1
Woody V Posted January 21, 2022 Posted January 21, 2022 14 hours ago, LSP_Kevin said: I think you've confused things a little here, Woody. Right you are and I stand corrected. LSP_Kevin and ivanmoe 2
BarryWilliams Posted January 22, 2022 Posted January 22, 2022 On 1/20/2022 at 10:44 AM, Archer Fine Transfers said: This thread has gone off-topic. MRP and Mr. Paint are two entirely different paint lines, but Mr. Paint is sometimes referred to as MRP due to the naming history of MRP. My comments are regarding Mr. Paint. On the contrary. Mr Paint was the original name for MRP and was changed to MRP because of confusion with the Mr Color range from Gunze. I still have a couple of old MRP bottles branded Mr Paint.
